#15 | |
12% Done with the car.
Drives: FRS
EL headers are for more performance oriented builds, but you will lose most of your "boxer rumble". UEL headers will still give you great gains, but not as much as EL. Of course, it always varies, but the majority of UELs won't touch ELs. UELs will keep your "boxer rumble" though. And yes, UEL does sound better than EL. AND the question about a catted UEL for you nobody else can answer for you. If you replace all piping with aftermarket (headers,overpipe,frontpipe,midpipe,catback), it will be loud. A couple cats here and there will lessen the overall sound, but you won't have as much power as a loud uncatted setup. It comes down to what YOU want.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
#16 |
Drives: I own an FR-S. . . whatelse!
They seemed too good to be true. When most companies had their headers at the 1k mark, borla was at around 600 bucks. Either way, uels definitely eliminate the torque curve, not sure about the top end though. I have only taken my data from FT86speedfactory. I do like the sound better though, it sounds cool!
Also I can handle loud. I think. I had an Invidia N1 for a bit and I was completely fine with it, and that droned like a mofo. |
#17 | |
Drives: FRS
#18 |
Drives: 2013 Subie BRZ Limited, black, 6MT
The headers by FA20Club are nice in that they stay in place if you go turbo from them. I'm considering this path myself. Just don't want SUPER loud as it's my wife's daily driver.
Have: Full header back Nameless Performance exhaust Want: FA20Club UEL headers, then maybe FA20Club turbo |
#19 |
Sideways and Smiling!
Drives: Scion FR-S
Ive had my borla uel header on my vortech frs for over 3000 miles and have had no problems. Got it from Ft-86 speed factory and have had no issues. My header is by no means crap and all those who have had theirs installed by the shop that put mine on had no issues after install. With a lifetime warranty im confident with my choice.
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
#21 |
Drives: 2013 FRS
What about uels putting pressure on cylinder 4?
#22 |
They don't. Subaru has been using UEL's for years on cars going 200,000+ miles. I had a concern before buying my UEL header but all it really does is adjust the exhaust pulse and sound. Not only does it sound badass, but my JDL UEL doesn't mess around when it comes to power either. Best of both worlds.
| The Following 3 Users Say Thank You to FR-S Matt For This Useful Post: |
#23 |
Drives: FR-S 10 #103 AT
This is more likely an example of how bad Borla's EL header is than proof that UELs are better than ELs.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#24 |
Drives: Pavement MT GR86
Both the hks el and t1r made more than either borla or JDL uel header.
It's design of the header. Runner length. Primary diameter. Merge collector. And so on, not necessarily el vs uel. Like mentioned above I wouldn't worry about a cat in either location for longevity but rather if they use quality parts and have any kind of warranty. So far it seems a header cat limits power somewhat but also keeps the noise down. I'd follow the latest version under development.
GR86 MT premium
#25 |
It's personal preference. EL headers make more power in theory, certainly in the case of a turbo setup. Tests have shown the difference is minimal at the power levels were seeing now. It comes down to sound then, which frankly I think uel's sound like garbage, raspy and farty. Others love them. It's all about personal preference.
#26 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#27 |
This is probably true. But UELS aren't bad either. You might lose 3 or 4 horsepower uptop but you get dat noise. Plus from searching the forums, the tend to make a bit more power lower down than the EL offerings.
#28 | |
| Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic | ecko04 | Electronics | Audio | NAV | Infotainment | 10 | 05-05-2018 03:47 PM |
| 225/45/18 Bad Idea? | alex88 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 04-22-2014 11:25 AM |
| Is it a bad idea to run headers without a tune?? | Mike86 | Engine, Exhaust, Transmission | 48 | 09-06-2013 03:31 PM |
| Any idea what this is? | idreamofdrifting | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 02-08-2013 10:50 PM |
| Best idea for a bed ever! | dorifuto | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-19-2012 10:34 AM |
