View Poll Results: What are you opinions on negative camber, from a looks perspective?
Looks great 23 52.27%
Looks ugly 21 47.73%
Voters: 44. You may not vote on this poll
Old 12-26-2013, 03:54 AM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I'm running -2 front -1.5 rear... is that too much?
-alex
Old 12-26-2013, 04:57 AM   #16
fatoni
anything more or less than what is optimal for the given setup to be fast or feel good is pretty tacky imo
Old 12-26-2013, 08:02 AM   #17
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
-2.5ish + 9.5" wide = sex
Old 12-26-2013, 08:28 AM   #18
JHarperFRS
JHarperFRS's Avatar
Drives: 2013 Scion FR-S "White Out"
I hate negative camber...it's pointless. Only time I would even consider it appropriate, is when it's done on a show car...For a DD or track car...it NEVER should be done.
JHarperFRS is offline   Reply With Quote
Old 12-26-2013, 09:12 AM   #19
s2d4
s2d4's Avatar
ummmm, it's called function.
Old 12-26-2013, 11:47 AM   #20
ML
ML's Avatar
Drives: 13 White MT FR-S
Are trolling? If not, just stop.
"Camber angle alters the handling qualities of a particular suspension design; in particular, negative camber improves grip when cornering. This is because it places the tire at a better angle to the road, transmitting the forces through the vertical plane of the tire rather than through a shear force across it. Another reason for negative camber is that a rubber tire tends to roll on itself while cornering. The inside edge of the contact patch would begin to lift off of the ground if the tire had zero camber, reducing the area of the contact patch. This effect is compensated for by applying negative camber, maximizing the contact patch area...
On the other hand, for maximum straight-line acceleration, the greatest traction will be attained when the camber angle is zero and the tread is flat on the road. Proper management of camber angle is a major factor in suspension design, and must incorporate not only idealized geometric models, but also real-life behavior of the components; flex, distortion, elasticity, etc."
Old 12-26-2013, 12:35 PM   #21
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Why are we all trying to bang out the details of what I'm trying to get at? Negative camber is functional. But at some point it becomes non functional, and for looks/fitment.
86-tundra is offline   Reply With Quote
Old 12-26-2013, 12:37 PM   #22
s2d4
s2d4's Avatar
define that point?
Old 12-26-2013, 12:39 PM   #23
86-tundra
Troll Hunter
86-tundra's Avatar
Originally Posted by s2d4 View Post
define that point?
I just did.
When it's non functional. When you are pushing negative camber for looks. When you have to use more negative camber for fitment.
Old 12-26-2013, 12:44 PM   #24
s2d4
s2d4's Avatar
I just did.
Well, you thanked the guy that said track car shouldn't have negative camber.
In addition, the topic of thread/poll doesn't specify for function or form.
Old 12-26-2013, 12:58 PM   #25
mav1178
mav1178's Avatar
I think you should evaluate this statement in the context of:
V8 Supercars
F1
Formula Drift
NASA
SCCA
-alex
Old 12-26-2013, 01:08 PM   #26
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
In the software development world it is a giant no-no to say things like this.
"I want it better"
"It needs to be Faster"
"I KNOW IT WHEN I SEE IT!"
can we just close the thread so people will quit QQing over what "too much" is and if they what they have is "useful" for what they do? it a giant can or worms that has no correct answer.
people like different things. /end thread stop raging
G-Man is offline   Reply With Quote
Old 12-26-2013, 01:29 PM   #27
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
This thread sucks lol.
Redstar is offline   Reply With Quote
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
Advice on negative rear camber Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-27-2013 10:38 PM
86 vs. 2013 STI - a DD perspective. Jar FR-S / BRZ vs.... 22 07-10-2013 02:04 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
A different perspective on price. Hanzo BRZ First-Gen (2012+) — General Topics 19 06-11-2012 09:07 PM
