Old 12-23-2013, 10:16 AM   #141
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by kask2_6.0 View Post
Oh man that sucks. The plastidip alone won't cover it but if you are painting it anyway a very small amount of bondo would do the trick.
x2
Plastidip will not fill it at all. Try a bit of body filler and it should be okay...
djdnz is offline   Reply With Quote
Old 12-24-2013, 09:19 PM   #142
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Got my lip today. I was expecting it to be a lot thicker than it is. I feel like one scrape and it'll break. But still, for $85 bucks I can't complain. I hope they come with a polyurethane version soon, and that the holes match so I don't have to drill new ones
eSOLOR is offline   Reply With Quote
Old 12-25-2013, 04:41 PM   #143
uEih
Drives: CBS Subaru BRZ Limited
Originally Posted by monisan View Post
Enjoy the pics! I like the front lip a lot on the car For around 85 dollars I think it's a good investment
About to bite on a front lip, did you use 3M tape? How is it holding up so far and is the fit good?
Don't know how thin the genuine ones are but I think this was made to absorb the impact and protect your bumper also. Use 3M tape so you don't have to drill.
uEih is offline   Reply With Quote
Old 12-25-2013, 09:27 PM   #144
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
It will absorb the impact and protect the bumper but will shatter while doing so since it's ABS plastic. I don't think I'll even scrape it hard enough for that to happen being lowered one inch. The main reason I got it was for protection (I love the way it looks as well) so as long as it does it's job, I'll be satisfied
Old 12-26-2013, 07:02 AM   #145
monisan
Drives: 14' SWP BRZ Limited
Yup I used 3M tape for the areas I didn't drill. So far it's actually holding up really good and the fit is snug. Just don't push up the lip too far up on the sides when installing if you do go for the 3M tape route or it might scratch your paint. I don't track my car, it's more of a daily drive vehicle for me. I've been driving it mostly local lately due to staying home for the holidays, but the tape seems to be strong enough even at high speeds on the freeway which I've driven a few times.
I've also driven it in the rain and the tape seems to be holding up too, so I'd say the tape is pretty durable. I got the tape from Home Depot and got the heavy duty one that holds up to 10 lbs. Might be overkill but I don't want the lip falling off anytime soon
While the fit is good, the lip is still fragile and I feel like it could potentially crack if you do hit it head on. I thought it would be a heavier product but it's actually extremely light. It is plastic after all!
monisan is offline   Reply With Quote
The Following User Says Thank You to monisan For This Useful Post:
uEih (12-26-2013)
Old 12-26-2013, 07:07 AM   #146
monisan
Also, thank you guys for the tips regarding my side skirts. I decided to just return it to BaysonR and ask for an exchange since they offered me free return shipping. Will update once I get them installed and post pictures
Old 12-26-2013, 04:48 PM   #147
uEih
Sounds good, I was gonna use the automotive 3M tape. I think i'll go ahead and order it now since it seems like the fit is good also. As long as there are no gaps I'm happy. The only thing I'm gonna worry about now is scratching the paint since I read someone scratch theirs installing the lip already, i'll be extra careful not to push the lip up too much I guess.
Old 12-26-2013, 04:53 PM   #148
sirsol66
Drives: 2013 FRS- Hot Lava
Can anybody with the side skirts put up some underbody photos? I'm curious to see what the brackets attach to.
sirsol66 is offline   Reply With Quote
Old 01-01-2014, 04:31 PM   #149
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Originally Posted by JPxM0Dz View Post
Here's a couple of pics of the rear spats to see finish that can be expected on the side skirts
Which area in the interior part of the rear spats do you have to apply double sided tape to ?
Thanks
ucsmfu is offline   Reply With Quote
Old 01-01-2014, 04:45 PM   #150
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Thanks
Along the upper edge just under the rubber weather strip and down the outer edges
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 01-01-2014, 05:25 PM   #151
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
For the weather strip. Do you apply tha onto the spats prior tto install or after when you have the rear spats installed
thanks
Old 01-01-2014, 07:29 PM   #152
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
thanks
Everything got applied to the rear spat before install. I cleaned the surface with alcohol, then applied the weather strip, then attached the 3M
Sent from Note III on BoBCaTROM
2URGSE
Old 01-01-2014, 07:45 PM   #153
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
The sticky side of the weather strips go on the top edge of the rear spats right?
Will it hold once it's applied onto the car ?
Also how is the weatherstrip applied on the side skirts ?
Along the top ?
Thanks
Old 01-01-2014, 07:55 PM   #154
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Along the top ?
Thanks
Yes weather strip goes to top yes. It sticks to the spat and there is a edge that slightly overhangs the top of the spat. It's pushed up against car body and seals once applied. It will stay once applied, part of the strip is 3M'd to the spat and part of it overhangs and seals against car
2URGSE
STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 31 12-03-2013 10:57 PM
CS Style Polyurethane Side Skirts Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 14 11-04-2013 09:49 PM
WTB CHARGESPEED STYLE SIDE SKIRTS. bahanii Want-To-Buy Requests 1 10-18-2013 02:06 PM
FS: CS Style Side Skirts and Rear Spats FRS2000 Exterior Parts (Aero, Lighting, Etc.) 4 09-23-2013 12:15 PM
2013 SUBARU BRZ J STYLE PU SIDE SKIRTS JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 7 05-10-2013 11:29 AM
