Old 12-20-2013, 09:34 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Vortech boost at different rpms?
Just wondering what boost should be generated at 3000rpms 4000rpms and so forth?
Also i have the max blow off valve and wondering if it needs to be adjusted to get proper boost at different rpms?
Thanks
Frs32907 is offline   Reply With Quote
Old 12-25-2013, 08:40 PM   #2
Cal3000
Drives: Panda FR-S
3000rpm~2psi
4000rpm~3psi
5000rpm~4.5-5psi
6000rpm~6psi
7000rpm~8psi
7400rpm~9psi
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
avishenoy1 (04-19-2016)
Old 12-25-2013, 08:45 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
Bpv should need no adjustment... went from stock pulley to 3.125" pulley and the maxflow didn't seem to care much
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 12-25-2013, 11:29 PM   #4
FA20Club.com
Drives: 2013 White Out FR-S
The Vortech is linear in power delivery so the higher you rev the more the boost will increase.
FA20Club.com is offline   Reply With Quote
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 04:42 PM
Rattling in 2nd or 3rd at low rpms BigFatFlip Engine, Exhaust, Transmission 54 09-07-2015 09:54 PM
boost gauge vortech help ft86me Forced Induction 47 07-06-2015 11:50 AM
Where are your RPMS Dragon86 CANADA 13 07-26-2012 11:43 AM
RPMS!! Spencer Strayer Engine, Exhaust, Transmission 82 09-15-2011 10:51 AM
