Old 12-25-2013, 11:02 AM   #141
nelsmar
I bought my belts and idlers from a local auto parts store. Litterally every store in a 5 mile Radius had them in stock. Do not be overly concerned with this old thread afaik I have broken more belts than anyone and I never broke the belt on the stock pulley. Just make sure to inspect that the pulleys are lines up with a straight edge or string from tha alternator to Ac pulley. Install error can add stress to the belt.
My flickr - Canibeat
Local magazine scout
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
HRTROB (12-25-2013), p00mba (12-26-2013)
Old 12-25-2013, 11:06 AM   #142
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by HRTROB View Post
I have a Vortech on order and now I'm getting nervous with all these belts snapping and breaking can somebody post some links on where I can buy spare belts and idler pulleys online for the stock 9psi pulley?
You just want a K060975 belt, either a gates racing version or a standard version.
The Idler pulley is a gates 38006
You can order it from amazon/rockauto.com or your local autoparts store.
After replacing the idler pulley with the gates pulley and a racing belt I didn't have any problems with belts (the only problem I had previously was a squeaking pulley).
I wouldn't be worried.... just replace the pulley when you get the kit, and use the included K060975 or upgrade to a gates racing version of the same belt (K060975RB). I would not be paranoid as long as you do the pulley swap.
I'm actually running a higher PSI pulley with a STANDARD belt with no issues right now and the gates idler pulley 38006.
The most important thing you can do after install is to check all the belt/pulley clearances with your charge pipes and to make sure that all the brackets are installed properly so that the supercharger pulley is aligned correctly with the rest of your belt system.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
HRTROB (12-25-2013)
Old 01-13-2014, 11:35 PM   #143
ft86me
ft86me's Avatar
Drives: 2013 FRS
Was driving home and belt finally gave way today after a pull. Lost one tooth worth. Took the shards off and drove her home nice and slow. Will be replacing belt tomorrow at my shop with the 97 inch vs a 97.5. Thanks to @Rick@Vortech helping me out! You're awesome rick!
Noticed the 97.5 belt was getting loose and a mild squeaking last week.
Pulleys look good with no grease coming from them and not rubbing on anything. Whew !
UPDATE:
97in belt is doing great! no issues and car feels like it has a little more umph. that's what you get when a belt is on the loose side.
ft86me is offline   Reply With Quote
The Following 2 Users Say Thank You to ft86me For This Useful Post:
DJCarbine (01-14-2014), nelsmar (01-13-2014)
Old 01-29-2014, 05:18 PM   #144
Sniper2606
Sniper2606's Avatar
My pulley started making squeaking noises today 5k miles on SC kit, should i make sure the pulley its tight? or should i change the belt?
Is there any way of changing or tightening the pulley with out taking the blower off?
Sniper2606 is offline   Reply With Quote
Old 01-29-2014, 05:24 PM   #145
nelsmar
If you have a long handle wrench, or short socket you can loosen the tensioner and then remove the belt and do what you need.
Old 01-30-2014, 12:28 AM   #146
deange
Drives: Black 2013 BRZ Limited Automatic
I've got a little over 7k on mine since the install in August and it has started making noise now too. My tensioner pully moves a lot (rotates on the tensioner pivot, doesn't wobble). I've got the gates k060970 belt. I'm going to have to do something before it gets worse. I'm wondering if the factory tensioner is up to the task with the additional strain of the blower, a/c, etc...
deange is offline   Reply With Quote
Old 01-30-2014, 12:38 AM   #147
Cal3000
Drives: Panda FR-S
I've got 20K miles on my Vortech as of now. Belt squealing goes on and off. It's weird. Maybe oil from the reservoir vent is getting on the belt. Don't know. Car still runs good.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 02-01-2014, 03:48 PM   #148
Sniper2606
Sniper2606's Avatar
Sooo changing the pulley today with the gates 38006 and the box says not to re use the dust cover because the bearing is already grease? Should I still use the dust cover?
Old 02-01-2014, 10:21 PM   #149
Frs32907
Drives: Asphalt grey, manual Fr-S
So did anyone who had their belt slip or go bad get any dtc codes. Right now when i try to get anyboost my check engine comes on and says my maf voltage is too high and my bank 1 o2 sensor is too rich
Frs32907 is offline   Reply With Quote
Old 02-02-2014, 06:27 PM   #150
charged86
charged86's Avatar
hmm
Old 02-25-2014, 08:53 PM   #151
deange
My car was progressively making more and more noise when cold. I checked out all the pulleys and couldn't find any issue with them. My kit is the 2nd gen kit and came with the Gates K060970 belt. On the advise of a buddy of mine who doesn't think very highly of the Gates belts I thought I'd try using a different brand. He suggested trying Bando. I did a bit of searching and bought a Bando 6PK2475 off of Amazon for 20 bucks. I changed it out (pulled the super charger), and put the Bando belt on. The Bando belt is 4 mm shorter (not enough to notice), and the noise is totally gone.
I can't say that it is a magical Bando belt, or that Gates sucks. It could simply be just a NEW belt was all that the car needed. I'll let you know how things are in another 10,000 miles.
Old 03-19-2014, 02:50 AM   #152
Sniper2606
Sniper2606's Avatar
Was it a chirping noise? i been having some chirping when car is cold and it goes away after car its up normal temps, i have changed the idler pulley once and it stopped for a month now its coming back again, not sure if is the belt or pulley.
Old 03-22-2014, 01:40 AM   #153
deange
Not a chirp. The new belt seems to be what was needed.
Old 04-18-2014, 02:16 PM   #154
415FRS
Drives: Red SCion FRS
I got the idler pulley 38006 and its a little smaller than the one came with the kit. Did i get the correct one?
Sent from my HTC One using Tapatalk
415FRS is offline   Reply With Quote
Kartboy Crank Pulleys 95.00 tom@kartboy Engine, Exhaust, Bolt-Ons 16 06-11-2013 01:06 PM
Crank,Alternator,Waterpump Pulleys etc..? fareastbrz Engine, Exhaust, Transmission 6 05-28-2013 08:46 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 09:57 PM
