| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 86 GTS
Work Wheels.. Disk sizing ?
About to order wheels and have been asked to select disk size,choices are A Disk or O Disk...
I'm still not sure "exactly" what it means.. Googled a shit load of threads about it but they all end up going off topic so no one gets a straight answer ![]() From what I can gather so far is, O less concave and more lip and vice versa.. |
#2 | |
Drives: Fr-s
A-disk is standard sizing. Normal sized lip / brake clearance Hope that helps |
#3 |
Drives: 86 GTS
Cool, thanks.
I'll be keeping standard brake set up hoping O is fine for it. Just got word from my supplier that Work Japan will contact him to find out what they recommend on a 86 and what they've already fitted. Hopefully find out soon.. Thanks again
#4 |
Drives: Fr-s
No problem. If you stick with stock brakes. O-disk is fine, I run O-disk lol
| The Following User Says Thank You to PradiG For This Useful Post: | Juvenile (12-25-2013) |
#5 |
Drives: 2005 Toyota Camry
What wheels?
-alex |
#6 |
Destroyer of Tires
Drives: 2001 Honda Accord, 1997 Lexus ES300
Some wheels have different disk types, for brake clearance. Not all wheels have good brake clearance, so they need thicker back pads to add space. This of course changes the offset.
So for instance, you may notice on Work Wheels USA's website that they have certain wheels that have similar specs but the lip sizing is different. This is due to the change in back pad thickness. One easy way to see the difference in thickness would be to compare the same diameter, width, and lip size. ![]() You'll notice that 19x10.5 +45 (A-disk or regular), 19x10.5 +55 (O-disk or low-disk), and 19x10.5 +28 (R-disk or high-disk) all have 72mm lips. The back pad has 10mm more metal shaved off for the O-disk version compared to the A-disk version, and the R-disk has 17mm material added in comparison to the A-disk version. If you have the clearance, O-disk allows you to simply run bigger lip sizes, by compensating for the difference in backpad thickness (bigger lip = smaller inner barrel for the same width wheels). |
#7 |
Drives: 2015 Ultramarine FR-S
SOOOOOOOOOOOOOO............
im gonna bring this thread back, so from what ive gather, running "O-disk" on our car is completely fine as long as you dont go with a big brake kit?? "A-disk" is fitted like a regular wheel with no deepdish lips? so if i run "O-disk" say dimensions of the wheels are 18x9.5 et39 i will be fine?? |
#8 | |
And yes, that should fit with coilovers but will be very close to your stock suspension. |
| The Following User Says Thank You to Kami Speed For This Useful Post: | SlammedSilly (05-11-2016) |
#9 |
| The Following User Says Thank You to SlammedSilly For This Useful Post: | Kami Speed (05-11-2016) |
| new 2014 Wheels - RAYS VOLK Racing ZE40 | WORK Meister M1 | WORK Seeker Series | RavSpec | Wheels and Tires | 8 | 06-15-2014 11:07 AM |
| Work Wheels new Seeker CX/DX/FX wheels for 2014 | mav1178 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 04-01-2014 12:44 AM |
| WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** | RavSpec | Wheels and Tires | 18 | 12-10-2013 06:19 PM |
| Are 17" wheels too big? Might work 16's work a little better? | rogerdalien | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 46 | 05-10-2012 11:09 PM |
