Old 12-24-2013, 10:42 AM   #29
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
why can't "they" get it in the "center" ...?? ...
People would complain about that too.
Scenic Driver is offline   Reply With Quote
Old 12-24-2013, 10:50 AM   #30
Mikem53
Drives: FR-S 6MT
Originally Posted by dave77 View Post
Hmm thanks that's interesting. I don't quite understand how lowering the clutch pedal would make a "dead spot" on top, and why it would decrease the resistance. So why does that happen?
It creates a void on top when you adjust the pedal lower.. So depending on how low you adjust it, you create more dead space on top. It also lessens the resistance you feel when you depress the clutch. This is due to the fact that some of the spring and internal resistance is already taken up some by the adjustment.
I tried various adjustments and ended up going back to the stock pedal height.
It took a few thousand miles on the car and myself to have it all come together and feel right. Be patient if you just got the car..
Mikem53 is offline   Reply With Quote
Old 12-24-2013, 12:42 PM   #31
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Ok interesting. I can understand now how the resistance is decreased by how you describe it. Still don't understand why there is a dead spot on top when it's adjusted. I'd rather have a dead spot on top than on bottom (if we're talking about the same thing, with stock setup the dead spot is on the bottom which is why the clutch engages late?)
Anyway, still sounds like something I'd prefer, I want the engagement to be straightaway, it suits my driving style.
Yea I've driven 2500 miles on my FRS. I really really like the car, it's smooth when cruising around and really fun when I wanna go faster. I wouldn't mind having the clutch stay as is, UNTIL I learned that it could be adjusted like this.
dave77 is offline   Reply With Quote
Old 12-24-2013, 01:29 PM   #32
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I agree on the "dead spot". The return springs has less tension near the maximum pedal return, sometimes when it's cold the pedals fails to completely return to its resting position (by a fraction of an inch). This affects the pedal only really, the clutch is still fully engaged at that point. I was annoyed by it at first but I like the new grab point now, not going to change it.
Rayme is offline   Reply With Quote
Old 12-24-2013, 01:47 PM   #33
DarkSunrise
DarkSunrise's Avatar
From my personal experience, after adjusting my clutch to catch earlier, it feels slightly lighter than before, but it was so light to begin with I barely notice the difference. I really hated the clutch before, but like it a lot now. Much easier to shift smoothly.
Best way to tell if you'll like it is to try it. It takes less than 5 min. to adjust. If you don't like it, adjust it back.
2022 BRZ Build
2013 FR-S Build
Old 12-25-2013, 10:24 PM   #34
Regalo
Drives: Toyobaru 86
Send a message via AIM to Regalo Send a message via Yahoo to Regalo
At first I would seemingly blip the throttle before launch because I wasn't aware of the high catch point. I learned how to drive manual on a 01 Corolla that I was driving for a couple of years. That one had an incredibly low catch point in comparison to the FRS. If I can't get use to the high catch point, I'll make the adjustment.
Regalo is offline   Reply With Quote
Old 12-26-2013, 10:04 AM   #35
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
The adjustment now gives the clutch a degressive feel, so you can feel now where the disengagement point is when clutching in. Couldn't feel that at stock.
^GT5 Replay Photo Mode^
Old 12-26-2013, 10:39 AM   #36
mmsracing
Drives: 2013 FRS
LOL, I ran a twin disc clutch in my drift car, most humans can't even get it out of 1st gear with out stalling, low engagement, with only 1/2 inch of play from initial engagement to full engagement.
Made for full throttle clutch kickin. FRS clutch is fine for DD
Anyways, Happy Holidays all
mmsracing is offline   Reply With Quote
catching, clutch, point
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
Clutch realeses really high jonbonazza Issues | Warranty | Recalls / TSB 12 12-02-2013 08:12 PM
What are you catching? Amadeus Engine, Exhaust, Transmission 9 05-01-2013 08:47 PM
TriState Toyotas meet sept 9 high point park nj EvilCelica NY / NJ / CT / PA 0 08-25-2012 11:55 PM
