#71 |
Drives: WR blue
Thx so it won't hit between the wheel and the caliper due to the heat expansion right?then from 35-45 which one will give u more clearance? (Just worried that the wheel and the caliper make contact ) by the way,how do u like it on the track w bigger wheels and tires?
#72 |
If you want to clear a bbk you have to +35 in a 17x9 to work for the rpf1. We got sets of silvers in stock.
#73 |
Drives: WR blue
#74 |
Drives: FRS
I have never had dust boots on any of my Brembos on other cars not melt after a track day. As far as I know, on all brake kits and track use, the dust boots typically melt, they are rubber after all.
#75 |
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Just wanted to check did anybody tried using the AP Racing CP3908 rotors meant for the Endurance kit on the Sprint kit?
#76 |
You will need the proper designed hat and bracket from the Endurance kit before bolting it up. The hat allows that ring to float proper and the bracket will bring the caliper outboard to accommodate the larger rotor.
#77 |
So technically its possible with just the rotors and the hats I assume?
Sent from my GT-N7105 using Tapatalk
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
#78 |
Site Moderator
Drives: Stuff
You need the caliper brackets. I'm not sure that hats are actually different, depends on inside diameter of the rotor. The floating feature is built into the rotor (slotted mounting hole), the hole in the hat shouldn't be. I haven't seen an endurance kit in person (except for the caliper bracket) so I can't say for sure that they are the same but I've never seen another floating setup with slots in the hats. That doesn't mean the hats aren't different for other reasons though. For the limited research I did when I considered this you would need brackets, rotors and multiple bits of hardware/bolts. The advice from Jeff at the time was to stay with the Sprint kit, or sell it and buy the endurance kit. The cost of the parts was more than the difference in kit prices.. hell just the rotors were basically the difference in kit price if one tried to convert.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#79 | |
#80 |
Drives: AE86, 2x GT86, TE27
FWIW I use the Wilwood kit, with semi slicks, for 10-15 lap sessions, and they are excellent.
Not doubting the AP kits at all. But most don't need it. |
#81 |
Drives: 2013 Scion FRS
#82 |
#83 |
Drives: Toyota 86
Hi there, I'm in the market to get a BBK for my ZN6, I have a couple of clarification points though that you may enlighten me with:
1. What's the major difference of the AP Racing BBK kit specifically Sprint vs. Endurance? Which is best for my application? More of street and occasional track like once every quarter. 2. Can I upgrade just the front brakes? Thank you very much in advance. Anthony from Manila, Philippines |
#84 | |
Drives: 1980 corvette, 2014 Subaru BRZ
http://www.essexparts.com/shop/compl...86-bundle.html
| Stillen Brakes | jdzumwalt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-15-2013 11:57 PM |
| KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing | vividracing | Brakes, Suspension, Chassis | 5 | 10-15-2012 06:23 PM |
| help on Wilwood brakes brackets | Turbo Den | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-01-2012 08:14 PM |
| OEM Brakes? | marinjim | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-20-2012 10:26 PM |
| GT brakes | jello | AUSTRALIA | 2 | 06-10-2012 09:10 AM |
