Old 12-22-2013, 03:57 PM   #1
anewprelusion
RPM drops twice after shifting to 3nd gear at ~2500 RPM
I'm not sure if it's a real issue, or just my lack of knowledge, but here goes.
I have an AT (...yeah I know), but like to drive it in "M" mode because I like to pretend I have an MT (lol, j/k). Also I like to shift gears as early and quickly as possible (when the conditions permit) in order to save some gas on my daily commute. Anyways, I noticed that when I shift from 2nd to 3rd gear at around 2.5K RPM, the RPM drops twice. Like it shifts from 2nd gear to a nonexisting 2 1/2 gear, and then to 3rd gear. This does not happen when I shift at around 3K RPM (RPM just drops once like normal). Easy solution would be to stop driving like a grandpa and shift at at higher RPM, but I was just wondering if this is normal operation. If so, why is it necessary?
Thanks!
anewprelusion is offline   Reply With Quote
Old 12-23-2013, 01:12 PM   #2
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
It's your lack of knowledge as you put it. The transmission shifts and then the torque converter locks-up. It's not shifting twice.
Subie is offline   Reply With Quote
The Following 2 Users Say Thank You to Subie For This Useful Post:
anewprelusion (01-01-2014), Mr.EvoMR (12-23-2013)
Old 12-23-2013, 01:41 PM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I have the same thing in 4th in my AT. Its normal from what i understand. It happens to me based on throttle input i think.
The Following User Says Thank You to BlueDubbinTDI For This Useful Post:
Old 12-23-2013, 02:42 PM   #4
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
That guy is on the money
cjsporl1996 is offline   Reply With Quote
The Following User Says Thank You to cjsporl1996 For This Useful Post:
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
3rd gear inconsistent shifting mike the snake Issues | Warranty | Recalls / TSB 30 11-22-2013 03:54 PM
Clicking shifting 2nd gear and R radroach Issues | Warranty | Recalls / TSB 0 03-16-2013 11:36 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
