Old 12-16-2013, 11:42 PM   #15
HakunaMiata
HakunaMiata's Avatar
Drives: Scion FR-S
Got it all taken care of guys. if anyone is doing this conversion and has questions let me know I'll be happy to answer them. thanks again for the help!
HakunaMiata is offline   Reply With Quote
Old 12-17-2013, 12:45 AM   #16
Mrazn
Drives: Scion FR-S, Whiteout
Thinking about picking up a set of winjets. I currently run an morimoto hid kit. How'd you end up wiring your hid's?
Mrazn is offline   Reply With Quote
The Following User Says Thank You to Mrazn For This Useful Post:
86SPEED (12-19-2013)
Old 12-18-2013, 11:14 PM   #17
HakunaMiata
Drives: Scion FR-S
All you need to do is take the low beam part of your oem headlight harness off and put it in place of the low beam harness of the winjets. Removing and replacing the pins from the connector is pretty easy, just pull the white insert thingy out and depress the tab for each wire you want to remove and pull it out
Old 12-19-2013, 12:33 AM   #18
BMHumanic
Drives: 2013 Whiteout 6MT FR-S
Just installed my HIDs to the Winjets. No problems at all. Only thing is the wire for my H7 bulbs is really short so I had to relocate the ballast.
BMHumanic is offline   Reply With Quote
Old 12-19-2013, 12:36 AM   #19
BMHumanic
Pic of lights on
The Following User Says Thank You to BMHumanic For This Useful Post:
Old 12-19-2013, 04:00 AM   #20
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Got any pics of the cutoff? Hows the output/beam pattern compared to stock and HID kits in the stock housing?
cdo221 is offline   Reply With Quote
Old 12-19-2013, 04:20 AM   #21
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Check out our thread on how we wired up the morimoto kits -
http://www.ft86club.com/forums/showthread.php?t=52206
http://www.fteightysix.com/pages/win...formation.html
86SPEED is offline   Reply With Quote
The Following User Says Thank You to 86SPEED For This Useful Post:
Mrazn (12-19-2013)
Old 12-19-2013, 09:36 AM   #22
Mrazn
Originally Posted by fteightysix View Post
The image you guys have makes sense for the headlight to the ballast. But what changes did you guys make to the wiring behind the dust cap/cover. Do you guys have any pictures of that? Thanks!
Old 12-19-2013, 10:51 PM   #23
86SPEED
86SPEED's Avatar
Ill post images in our GB thread
Mrazn (12-19-2013)
Old 12-19-2013, 11:43 PM   #24
Mrazn
thanks, appreciate it!
Old 01-06-2014, 12:06 PM   #25
21_nola_05
21_nola_05's Avatar
Drives: 2014 scion FR-S
Hello i just ordered the winjet headlights did youuse a H7 hid kit ?
21_nola_05 is offline   Reply With Quote
Old 04-12-2014, 11:13 PM   #26
Terran
Terran's Avatar
Drives: Raven FR-S 6MT
Had no idea the H7 bulb just pops off... lol. Until I watched this diy vid [ame="https://www.youtube.com/watch?v=EV4x5MH01k0"]Diode Dynamics HID install on Winjet/Spyder Headlights - Scion FRS and Subaru BRZ - YouTube[/ame]
Terran is offline   Reply With Quote
Old 05-05-2014, 09:55 AM   #27
21_nola_05
21_nola_05's Avatar
im having problems with this at first i thought it was the headlight , my right drl works but my left dosent , got headlights replaced and same problem drivers side drl is not working . i also have DD HID KIT
Old 07-18-2017, 11:24 PM   #28
TheeBeard86
Drives: scion frs
We're you able to ever get this resolved? I'm currently having this issue too.
TheeBeard86 is offline   Reply With Quote
*** Winjet Projector Headlights & LED Taillights - IN STOCK @ Sonic Motor *** Sonic Motor Exterior Parts - Lighting 500 07-29-2016 03:15 PM
Winjet Headlights - Installed, Compared, and done up the FT-86 SpeedFactory Way! FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 42 03-25-2014 12:08 AM
Winjet JDM Style Headlights Groupbuy --> Round 2 Now Open!! 86_ZN6 Groupbuys 206 02-13-2014 06:45 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 09:28 AM
Norcal GB: Winjet JDM Style Headlights 86_ZN6 Northern California 2 12-11-2013 04:31 PM
