Old 12-18-2013, 08:06 AM   #99
frslee
Just drive it
Drives: 13' FR-S
I didn't have much problem with stock fluid, all worked well.
frslee is offline   Reply With Quote
Old 12-18-2013, 01:04 PM   #100
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I have a thought but its a bit unorthodox, so bear with me. My winter beater and work horse is a 2005 Ford Ranger FX4 5 speed (M5OD) uses FORD automatic transmission fluid and doesn't suffer any notchyness. Maybe a transmission fluid vendor can speak better about this but maybe automatic fluid can be used in the BRZ tranny. I know they are vastly different in design but principles should be the same? They are both work horse transmissions so don't give me any shit about the truck not being able to handle the work load.
Gords_zenith is offline   Reply With Quote
Old 12-18-2013, 01:22 PM   #101
CoupedUpSubie
Drives: 2013 BRZ Limited
Has anyone dumped the Subaru Extra-S 75W-90 in their car? It can be hard to come by but I have a source for some. Everyone I know that run it in their Subaru's rave about how much better their transmission shifts.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 12-18-2013, 03:26 PM   #102
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
If you haven't had a problem with the stock gear oil, it still needs to be regularly changed and you're going to notice it if you switch to one of the better recommended gear oils mentioned in this and many other threads. It's not that expensive, don't be stubborn and screw yourself and car out of a better product just to save a few bucks.
DoomsdayJesus is offline   Reply With Quote
Old 12-18-2013, 09:50 PM   #103
radroach
Drives: car
This isn't a subaru transmission, being an Aisin transmission, so not sure if it would be applicable to our gearbox.
Old 12-18-2013, 10:50 PM   #104
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
The Subaru Extra-S is GL5, GL5 does not supersede the GL3/GL4 which is required by the FRS/BRZ 6MT transmission. Doing so not only voids your warranty but it will probably hurt your transmission as well.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 12-19-2013, 11:56 AM   #105
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Originally Posted by Darkazn58 View Post
But I don't understand how can a fluid be both GL-4 and GL-5 rated. I thought that the ratings did not supersede one another. As in something that requires GL-3 cannot be replaced with GL-5 instead. Plus, aren't the compositions of GL-4 vs GL-5 different? So how exactly does Motul achieve both ratings?
Your best answer would probably be provided by Motul. You can google Motul in Pomona, CA for the number and they're actually very good at responding to tech questions.
But from what I understand, they use metal deactivators so that the yellow metals in GL4 specced transmissions are not affected by the 30-50% higher levels of extreme pressure additives in GL5 oil.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=508377
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/729255/Gear_Tribology_and_Lubrication#Post729255
-Dennis
bluesubie is offline   Reply With Quote
Old 12-27-2013, 06:57 PM   #106
Dusty
Dusty's Avatar
Drives: 2013 Firestorm FR-S (traded).
I upgraded to Redline MTL today with 2100 miles on the odometer. The difference is immediately noticeable. The shifting went from frustrating notchiness to buttery smooth.
I definitely recommend a good pump to push in the new oil. There isn't much room above the fill hole.
"I'm getting my turtleneck. I'm not defusing a bomb in this!"
Dusty is offline   Reply With Quote
Old 01-07-2014, 04:04 PM   #107
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Same problem here.
I changed to Motul 300 (same spec as stock oil) weeks ago, and realized that it is harder to get in 2nd gear at cold weather. Actually, it's a lot harder than using the stock oil during the first 5 mins every morning (I warm up the car but does not help the transmission much).
Originally Posted by ap5512 View Post
I changed out my tranny fluid towards the end of summer and noticed it being a bit smoother. I used Motul. My only problem now is that getting into first and second are pain due to the cold. It really needs to get warmed up before it becomes smooth again.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 01-07-2014, 06:33 PM   #108
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Yup...2nd is almost impossible if you don't warm the car up. Lately, i've been shifting back and forth 1st-2nd while warming the car and it seems to help. I really wish it was smoother since I don't always have time in the morning to warm it up.
ap5512 is offline   Reply With Quote
Old 01-07-2014, 08:45 PM   #109
BeRZed
Originally Posted by Figo View Post
Same problem here.
I've noticed the same thing after switching to motul
BeRZed is offline   Reply With Quote
Old 01-07-2014, 10:11 PM   #110
Figo
Figo's Avatar
some times even CAN NOT go from 3rd to 2nd.
Old 01-07-2014, 10:12 PM   #111
chas3wba0
chas3wba0's Avatar
Drives: Yes
So I'm getting that the general consensus is... don't go with Motul?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-07-2014, 10:15 PM   #112
Figo
Figo's Avatar
When you said warm up, did u mean start the car and wait for mins? I double that going to help to the transmission a lot. It warm up the engine most likely. I'v tried to warm up until the engine drop to about 800 rpm after 2 mins, and wait for another 3 mins, but it was still hard to get in 2nd gear.
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
