Old 12-17-2013, 11:37 PM   #29
Sh944
Unwashed Heathen
Drives: 2014 Scion FR-S
Here is the Recaro Sportster CS I installed on Monday evening.
As for the passenger side weight sensor, does anyone know if Scion uses the same sensor in other cars besides the FR-S? I spent some time working with a dealership and apparently, the sensor is not available separately, you can only buy the sensor as a part of a seat assembly (ie the entire seat).
While it might be fairly easy to remove the sensor from the factory seat, installing it properly in the Recaros will take quite a bit more effort and I am trading my current FR-S in for a new one in a couple of months and want to be able to swap the Recaros directly into the new car and put the old seats back in. It will be a LOT easier for me to be able to get an extra sensor rather than try and use the one thats in the original passenger seat.
As to the air bag replacement, its not going to explode without applying voltage and isn't inherently dangerous. Without doing some engineering studies to see how it will function in its new installation, its hard to say what might happen (unintended consequences are indeed hard to predict) but I suspect if the new installation mimics the original one, it should be fairly safe as the side impact doesn't fire directly at an occupant.
Sh944 is offline   Reply With Quote
The Following User Says Thank You to Sh944 For This Useful Post:
APS86 (12-18-2013)
Old 12-18-2013, 02:49 AM   #30
APS86
Drives: GTS86 Manual
which seat rails did you use for the recaro's
APS86 is offline   Reply With Quote
Old 12-18-2013, 10:40 AM   #31
utekineir
blowhard
Drives: frs, project forester
Originally Posted by Scooby South View Post
Is that dangerous?? ^^^^ What happens if they go off??
On the table?
I'm not exactly juggling the things around the garage
Swapping the ones in an sg forester into a gr sti seat was actually more complicated than this particular application was.
utekineir is offline   Reply With Quote
Old 12-18-2013, 10:32 PM   #32
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by utekineir View Post
On the table?
Ohhh I thought you were going to leave them like that and put them under the seat.. LOL.. sorry my mistake
Bill
Scooby South is offline   Reply With Quote
Old 12-18-2013, 11:29 PM   #33
Sh944
Unwashed Heathen
I used Recaro seat rails. Expensive but worth it, IMO, unlike the Planted adapter brackets I used to mount the rails to the floor bolt locations, which I was not very impressed with, especially for the price.
APS86 (12-19-2013)
Old 12-20-2013, 02:24 PM   #34
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
recaro pole position. recaro side brackets, planted bases. no sliders
The Following User Says Thank You to spitfire481 For This Useful Post:
humanshield (01-31-2014)
Old 12-20-2013, 11:38 PM   #35
Sh944
Unwashed Heathen
How did you handle the passenger side weight sensor issue?
Old 12-21-2013, 10:25 AM   #36
spitfire481
Drives: 2JZ FRS
Resistors for the airbags, transferred the weight sensor from the factory seat
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
Scooby South (12-27-2013), Sh944 (12-22-2013), WhiteRose (05-28-2014)
Old 12-21-2013, 01:00 PM   #37
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Hey anyone got these http://www.takataracing.com/products/drift-pro-le-seat ?
They look awesome!
Teclis is offline   Reply With Quote
Old 01-26-2014, 10:41 PM   #38
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
Hey guys! Im looking to swap both my seats out and i was worried about the airbag warning. Everyone just puts a sensor in; is there another not so sketch way? or just duck tape it down? also i was wondering will i run into problems swapping the passenger side seat too? Thanks! @spitfire481 did you have to do that?
Thanks!
umpadupa is offline   Reply With Quote
Old 01-27-2014, 12:07 AM   #39
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Thanks!
same question as this guy
Old 01-27-2014, 12:33 AM   #40
spitfire481
Drives: 2JZ FRS
The drivers seat just needs a resistor stuck into the airbag connector that comes out from under the carpet underneath of the seat. Nothing else. The passenger seat needs the same airbag plug resistored, but also needs the weight sensor transferred over into the new seat, underneath of the fabric/lower foam. I think there MIGHT be a way to turn off the passenger weight sensor through Toyota techstream software. More than likely it will still show a fault since it is not plugged in and will still show an open circuit
RehabJeff86 (01-27-2014)
Old 01-27-2014, 01:13 AM   #41
umpadupa
umpadupa's Avatar
Thank you for the clarification!
Old 01-27-2014, 02:40 AM   #42
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
doing a bit of research.. I am trying to figure out what seat brackets to buy for my Corbeau FX1 Seat .. I had some custom ones made that used the stock sliders but the seat was offset to the left about 3inches.. and they sat funny..
It may help if you posted the distance between the mount holes on your seats, this way it can be cross-referenced to other seat rails.
I know Bride seats offers a bracket that allows their rails to be used with Recaro buckets.
I'm running a Zeta III + Bride rail myself.
-alex
Scooby South (01-27-2014)
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 06:45 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 01:37 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
Please post FR-S w/ aftermarket leather seat pics ngabdala Scion FR-S / Toyota 86 GT86 General Forum 6 05-31-2012 09:51 AM
