Old 12-08-2013, 10:46 PM   #43
ThisGuy919
Since datalogging has been enabled I now have the tablet mounted. Was wondering if there is anyway to have it turn off with the car and turn on with the car? The way I mounted mine is very tedious the have to unplug it every time to shut it off.
ThisGuy919 is offline   Reply With Quote
Old 12-08-2013, 10:59 PM   #44
jamesm
E85 knocks on the rich side, but in my brief experience with it is incredibly forgiving of afr. You'll want to target like 12:5-12.8:1 for NA on e85, depending on who you ask.
You adjust the fuel targets in the fuel map. You may want to check and see how far off target you are and why, though. I doubt it's targeting mid 11's. It's very likely that your injector scaler and di flow rate are not properly calibrated for the blend you currently have in the tank (which it won't be if it's your first tank in top of pump gas).
Old 12-09-2013, 04:35 AM   #45
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Thank you. My concern is only premium pump gas - we don't have E85 here.
Which fuel maps did you mean should i adjust to target AFR 12.5?
There are several fuels maps available - which one is affecting AFR rate on WOT?
Ondreiko is offline   Reply With Quote
Old 12-09-2013, 09:03 AM   #46
jamesm
Youre on pump gas? The afr is adjusted using the fuel map, though you shouldn't have to adjust it. You wanna knowing you're off target and if so, why.
Old 12-09-2013, 03:34 PM   #47
Ondreiko
RWD addicted
Ondreiko's Avatar
Exactly want to know why!
But still cannot imagine what could be wrong.
MAF scaling? MAF sensor itself?
OFT doesnot see any errors in ECU...
Old 12-09-2013, 03:42 PM   #48
jamesm
gather data. log stft, ltft, maf v, iat. collect at least 30k rows (probably a half hour drive), and then pm me.
Old 12-10-2013, 12:58 PM   #49
Ondreiko
RWD addicted
Ondreiko's Avatar
So i did - pm sent.
Thank you for your care and support!
The Following User Says Thank You to Ondreiko For This Useful Post:
jamesm (12-10-2013)
Old 12-10-2013, 05:40 PM   #50
sw20kosh
Drives: 2013 Black FR-S
How much max timing advance do you typically see on a stock car on pump gas?
Old 12-11-2013, 02:09 AM   #51
Ondreiko
RWD addicted
Ondreiko's Avatar
As for my log - it shows widely from 10 to 40, while it is 26 - 28 on WOT pull.
Old 12-14-2013, 01:34 AM   #52
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I currently have Motiv Catless front pipe and Nameless 2.5 axleback and stage 1 OFT
I just tried my 1st 3rd gear pull and it seems like AFR is a bit rich??
i just wanna make sure i am running safely.
https://drive.google.com/file/d/0B3T...it?usp=sharing
Old 12-14-2013, 09:35 PM   #53
zc06_kisstherain
Drives: SWP BRZ
@shiv@vishnu
am i safe?
thanks
Old 12-14-2013, 09:37 PM   #54
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
@shiv@vishnu
am i safe?
thanks
Unfortunately, I can't tell from that link. It would be better if you just post up your log at datazap.met.
Shiv@Openflash is offline   Reply With Quote
Old 12-14-2013, 09:40 PM   #55
zc06_kisstherain
Drives: SWP BRZ
sorry about that.
not very familar with it.
http://www.datazap.me/u/zc06kissther...-3rd-gear-pull
this one works?
Old 12-14-2013, 09:45 PM   #56
Shiv@Openflash
Drives: 2013 FRS
sorry about that.
this one works?
Can't say I've ever seen LTFTs that high. Tune is perfectly safe but running rich. Try this: Load up your stock ROM and drive it for a day or two. And then take another datalog so we can see where fuel trims settle. What other modifications do you have?
Also, could you email me (shiv@vishnutuning.com) a copy of the ROM that you are currently running? I'd like to see something.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
zc06_kisstherain (12-14-2013)
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
Now Available: OpenFlash Datalog Viewer and DataZap! Shiv@Openflash Software Tuning 36 12-31-2014 06:59 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
