Old 12-14-2013, 12:24 AM   #15
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by diss7 View Post
Just because it's old school, doesn't make it false. Most JDM 2000cc motors can quite happily be boosted to 400whp unopened, on pump gas. This motor, because of knock, because of its high compression, it limited to 300whp or thereabouts.
Wow! Read into something much? I simply observed that using head gaskets to manipulate compession ratios is a trick that has been around a long time. How you could interpret that as saying the technique is BS is beyond me.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 12-14-2013, 12:30 AM   #16
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Rods ETA before spring
Jason@DSG is offline   Reply With Quote
Old 12-14-2013, 12:40 AM   #17
Jason@DSG
Jason@DSG's Avatar
As to OP, lowering the head can cause potential for big issues with any piston blow by for guys running FI. Getting the head closer under high temps will just increase the chance of the pistons hitting the valves. Clearances on OEM may not allow the old school thinner head gasket drop. Ideally, aftermarket pistons with lower compression is the way to go to keep it more safe then cutting head gasket thickness.
Old 12-14-2013, 01:00 AM   #18
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
I was saying to increase the thickness to lower the compression ratio a little. I know it wouldn't make a huge difference. But could mean a little less stress on the engine (or allow for a little more boost) for guys running mild FI to decrease CR by 0.1-0.4 maybe?
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
Old 12-14-2013, 01:31 AM   #19
diss7
Drives: AE86, 2x GT86, TE27
My bad, I read your post as if it were sarcastic.
diss7 is offline   Reply With Quote
Old 12-14-2013, 02:45 AM   #20
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
some guy is running the hks one i think
Old 12-14-2013, 07:38 AM   #21
zooki
Drives: waiting on a 2021...
I would think too that increasing head gasket thickness would change the "quench" attributes of the piston/head relationship. Too much clearance may actually cause more detonation if the swirl characteristics are altered.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 12-14-2013, 11:31 AM   #22
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Did this on my vw 2l fsi engine. Lowered it about a point from 10.5 to 9.5. Helped keep knock at a minimum on 26-28psi. Car made about 500whp with no issues. Did this versus replacing pistons because the stock ones are pretty rebust.
With all that said you didn't have any of the potential issues you have here with intake/exhaust manifolds.
cruizin01 is offline   Reply With Quote
Old 12-14-2013, 11:52 AM   #23
Team STILLEN
Mark @ STILLEN
So the HKS gaskets
http://www.dynosty.com/2012/06/hks-s...s-for-frs-brz/
Say they increase the thickness by 0.1 mm (0.7 mm thick) to lower compression by 0.1 (12.4:1).
Do you think a head gasket could be made strong enough to hold us to ~300 whp while being maybe just 0.3 mm thicker (total of 0.9 mm thickness) without cause figment issues with the manifolds? That would put the CR closer to 12.2:1 (rough math). Would that be worth it for a little added safety from detonation on FI, or do you think doing head gaskets on a boxer motor is just too much for such a small cushion? Not think for big HP chasers, more for people who want to push a little more out of the stock bottom end.
Old 12-14-2013, 01:00 PM   #24
Calum
That Guy
Drives: 2013 asphalt FRS MT
Give Cometic a call, they already list the FA20 on their site, and if you have any trouble getting the manifolds bolted up, I'm sure you could gain the extra room with a few minutes and a file to the bolt holes.
Old 12-14-2013, 01:16 PM   #25
Jason@DSG
Jason@DSG's Avatar
Oh! My bad, sorry I read it wrong, I thought you were going for a thinner one (which doesn't decrease compression lol).
Yeah, going a bit thicker will be fine for sure. I just don't think it's going to make an enormous difference however.
Old 12-14-2013, 02:56 PM   #26
D K
Stig's dark passenger
Hello.
I'm new on this forum but...
You guys realize that changing valve cover thickness alters cam timing, right?
On the EJ it's a big no no.
One head gets advanced, the other one retarded.
The only correct way to lower static cr, is to change pistons.
David
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
AndMsc (10-03-2021)
Old 12-14-2013, 03:45 PM   #27
zooki
This is where those headers with flex joints come in handy... LOL
The Following User Says Thank You to zooki For This Useful Post:
Calum (12-14-2013)
Old 12-14-2013, 05:49 PM   #28
Calum
That Guy
I'd be curious about the length of the timing belts (chains I think, but either way) and how far off the cam timing would be when adding that much to the gasket thickness.
Anyone know the combustion chamber volume so we can do some calculations to find out how much deck height we'd need to add, otherwise this is just pure speculation.
Originally Posted by D K View Post
Hello.
David
Yup, it's been mentioned.
We do have variable cam phasing but I don't know if the stock ECU can correct the banks individually.
Not that some old school indexing of the cams couldn't fix the issue. Not everything can be fixed with a laptop.
Blown Headgasket ? regal Issues | Warranty | Recalls / TSB 44 07-18-2016 06:09 PM
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
Adjustion compression on a Koni 8612 insert? Evil86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-05-2013 05:01 PM
queston about low compression pistons on stock ECU clayrush Engine, Exhaust, Transmission 1 12-03-2012 11:11 PM
