Old 12-11-2013, 01:12 AM   #169
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by solidONE View Post
moar updates!
New map release and updates tomorrow! Would have been today but our domain server was down
Shiv@Openflash is offline   Reply With Quote
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
086A (12-11-2013), Burn (12-11-2013), solidONE (12-11-2013), WRB5titch (12-11-2013)
Old 12-11-2013, 01:16 AM   #170
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yay!! Booooo. Stupid domain servers.
Intent > Content
Old 12-11-2013, 01:30 AM   #171
WRB5titch
Drives: WRBrz
Woohooo!
Can't wait!
WRB5titch is offline   Reply With Quote
Old 12-11-2013, 02:08 AM   #172
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
What are the updates?
cjsporl1996 is offline   Reply With Quote
Old 12-11-2013, 05:07 PM   #173
Burn
Slack Bum
Burn's Avatar
Drives: FT86
12/11/13
v1.40 Changes:
-Added Stage 1 and Stage 2 map support for ZA1JA01N (Asian market) ROM
-In USDM E85 ROMs (Stage 2 E85 ZA1JA01C and Stage 2 E85 ZA1JA01D), we now differentiate between cars with Equal Length (EL) and Unequal Length (UEL) headers. The Stage 2 EL E85 tune is renamed (formerly Stage 2 E85) but unchanged from the v1.34 release. However, the Stage 2 UEL E85 tune is new and completely different. It js highly developed and has only been tested in cars with the OpenFlash UEL header. It is considered Beta status and should be used only be those who are sufficiently comfortable with data-logging and analysis.
-Stage 2 EL E85 maps have been approved for use in completely stock vehicles running E85.
-All non-USDM and USDM-ZA1JB00C (2014 BRZ/FR-S) tuned ROMs and considered Beta status.
-Adjusted checksum values so all ROMs can be opened in RomRaider without displaying checksum error.
-Re-enabled diagnostics routines for o2 sensor faults in Stage 2 and Stage 2 E85 maps. If you trigger these faults, it is due to an exhaust leak at your header flanges from not replacing gaskets when you installed your header.
its available for downloading in openflashtablet.com webby
Burn is offline   Reply With Quote
Old 12-11-2013, 05:24 PM   #174
DKEddy90
DKEddy90's Avatar
Drives: asphalt grey scion frs
Originally Posted by Burn View Post
12/11/13
v1.40 Changes:
Cant waittt!!
Sent from my SGH-T999 using Tapatalk 2
DKEddy90 is offline   Reply With Quote
Old 12-11-2013, 05:25 PM   #175
DKEddy90
DKEddy90's Avatar
So what are expected gains from stage2 e85 with the uel header?
Old 12-12-2013, 01:18 AM   #176
Rombinhood@OpenFlash
Drives: FRS
http://www.ft86club.com/forums/showp...nt=10:thumbup:
Rombinhood@OpenFlash is offline   Reply With Quote
Old 12-12-2013, 01:19 AM   #177
Drives: FRS
http://www.ft86club.com/forums/showp...1&postcount=10
Old 12-12-2013, 11:05 PM   #178
Sterling Doc
Drives: 2002 911 Targa
2nd tank of E85, and it's been between 0 and 20 degrees out. The car started after sitting outside all day at 0. It did stall once, and require a couple of brief cranks after that. In the teens it starts no problem with the OTS stage 2 E85 on our local blend of E85. At these temps, on E85, it pulls like my old 996 911. : to Vishnu!
The car does some weirds thing on the squishy Blizzaks. when I stand on the throttle in 3rd or 4th, the TC cuts in (no wheelspin), and strangles power all the way up. This goes away if I turn the TC off. Also, if I wiggle the wheel (well short of sliding), the stability control goes nuts. I can only suspect that the tall, squishy tread block allow enough movement (fore/aft and side to side), that it sets off the electronic nannies. Thankfully, we can turn them off!
day
Today's log is below. AFR's go a bit rich at high RPM, and you can see the LTFT swing a bit, but the car looks pretty happy. This may be because my car does not have a header on it? .99 Multiplier, (soo close to 1, LOL).
Sterling Doc is offline   Reply With Quote
Old 12-12-2013, 11:51 PM   #179
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I have General Altimax winter tires on right now and the TC goes nuts with a totally stock car in the dry. Under 30 degrees though those tires grip better than the stock Primacys and they performed insanely well on ice.... with the TC off.
Luckrider is offline   Reply With Quote
Old 12-13-2013, 12:35 AM   #180
Vmax911
Drives: WRB BRZ
I just opened up my OFT and wanted to log with the stock ROM. Setup seemed to go well, but I get no reading for ignition advance multiplier,it just sits at 0. Any ideas on what is wrong?
Vmax911 is offline   Reply With Quote
Old 12-13-2013, 01:23 AM   #181
Shiv@Openflash
Drives: 2013 FRS
With some international ROMs, advance multiplier does not log and displays 0. We will soon get around to addressing this.
Old 12-13-2013, 01:37 AM   #182
Vmax911
Drives: WRB BRZ
ROM is ZA1J700C
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
