Old 12-12-2013, 03:29 AM   #15
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Originally Posted by Fast_Freddy View Post
Stock and modified 86 cars run the same here in the USA. The quickest NA pump gas 86 I've ever seen to date ran 14.56 The lowest I've seen so far is 14.47 but that was on e85. Most struggle to break into the 14's without FI and even then, high 13's is the norm.
As easy as most drag strip newbies think it is, laying down a good 1/4 mile pass isn't that easy. I'm reminded of a time when I met a guy with a 300+ whp turbo Scion TC at the strip and he was running high 14's all day. My boosted AT XB only made ~240whp but ran low 14's all day, every day with 14.1 @98mph as it's best.
yeah... the 1/4 isn't an easy thing as many can imagine, specially when running on a track that has glue on (Track bite). It's very tricky to run street tires on those tracks without trial and error.
I guess with softer compound tires, i might be able to shave a bit of my time
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 12-12-2013, 03:58 AM   #16
Fast_Freddy
Drives: Passat
Many things look easy until you try them.
In your case softer compound tires and a higher rpm clutch drop should help. Since I have an auto I need a shorter FD gear ratio and/or higher stall tq converter.
Fast_Freddy is offline   Reply With Quote
Old 12-12-2013, 04:36 AM   #17
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
has anyone built a higher stall tq converters?
Old 12-12-2013, 04:57 AM   #18
Fast_Freddy
Drives: Passat
Not that I know of but I'm more interested in 4.56 FD gears since it's a DD.
Old 12-12-2013, 10:04 AM   #19
kroyoftheempire
Drives: 2013 Firestorm FR-S
Not to bash or disrespect or anything, but here in Puerto Rico a frind of mine ran 14.7 1/4 mile on a completly stock FRS. I just wished or hoped it would be faster with all those mods........................ guess n/a isnt an option for the FRS
kroyoftheempire is offline   Reply With Quote
Old 12-12-2013, 10:05 AM   #20
zooki
Drives: waiting on a 2021...
I just ran my car last night. Finally managed to break into the 14's. 14.97@97.6mph. It was 45 deg F out, so it helped the MPH, but hurt the traction. My car is standard, stock except for a drop in filter and Nameless axle back. Did get to see a Nissan GT-R run a 10.57@142... Scary fast considering he drove it there.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 12-12-2013, 10:07 AM   #21
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
10.5@142? He must of spun like a bastard
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 12-12-2013, 11:24 AM   #22
Frostyman
Drives: 2013 Raven FRS
There actually is a company that has a thread on these forums. Higher stall TQ converter, Transmission cooler, other goodies.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
The Following User Says Thank You to Frostyman For This Useful Post:
Fast_Freddy (12-12-2013)
Old 12-12-2013, 12:37 PM   #23
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Wow, that's sweet. What 60ft he had? Trap?
Old 12-12-2013, 02:16 PM   #24
1086
1086's Avatar
Drives: UM86 - 6MT
[ame="http://www.youtube.com/watch?v=9P2b_ygxIRY"]The Fast and the Furious - Dominic Toretto - YouTube[/ame]
Vin never goes above a 10 second 1/4 mile....ever.
1086 is offline   Reply With Quote
Old 12-13-2013, 10:22 AM   #25
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
nice. what was your launch rpm?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 12-13-2013, 04:29 PM   #26
diss7
Drives: AE86, 2x GT86, TE27
You don't want to dump the clutch, ever. You want to slip the clutch and slingshot launch. You're only dumping the clutch when the car makes enough power than it needs a brass clutch and you can't slip it. Your time is pretty much determined at the launch. These aren't drag cars, they're street cars.
The other thing I see new people doing at drag strips is shirtig too slow. You should be shifting so fast that you only just raise your foot off the gas, say to 50%.
I had a version 6 sti a few years back, kept it bone stock and demonstrated these techniques in some videos. I have them somewhere on photo bucket or whatever social media was popular at the time.
The launch in particular, dumping the clutch at low revs would bog, too high revs or letting the clutch off too fast would spin all four wheels. Would get mid 13s. Get the lianch perfect and it would do 13 flat. Even got a couple of 12s.
FWIW 14.5 is fucking decent. I had a type R integra that would only do that. I also had a stock s15 silvia that would only do 14.2. But spent $3k on it and it was doing 12.7.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
Bahraini86 (12-13-2013)
Old 12-13-2013, 06:02 PM   #27
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Just a click before 5k
The Following User Says Thank You to Bahraini86 For This Useful Post:
Grip Ronin (12-13-2013)
Old 12-13-2013, 06:08 PM   #28
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
I agree. However, slipping isn't something you learn in a day or so. I'm trying to work it out on my launches. At least, I preload the clutch on my runs by lifting the clutch gradually till the car tends to move. I try to keep some clutch pressed during the initial movement of the vehicle. Somehow, I still get the tendency to let go early. Getting there hopefully
CEL and Slip Light Gums AUSTRALIA 10 01-15-2013 08:42 PM
Is it really a Limited Slip Diff ?? 000 Racing AUSTRALIA 24 11-28-2012 05:56 PM
CEL and slip light? Rob_g Issues | Warranty | Recalls / TSB 2 10-03-2012 04:57 PM
Slip'n Slide! BuBlake Scion FR-S / Toyota 86 GT86 General Forum 45 10-03-2012 07:55 AM
Torsen limited slip BMWDavid BRZ First-Gen (2012+) — General Topics 41 06-12-2012 09:04 PM
