Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 11-27-2012, 08:02 PM   #1
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
Is it really a Limited Slip Diff ??
Just had the suspension in and after getting the 86 GT Manual off the trailer turned from the road into the exhaust shop.. and lost all drive with the clutch fully out ... WTF?? was my first thought .. and then I thought that with a LSD the drive should have been shifted to the wheel under load and still driven forward..
From the outset I have to say ... while I race cars I don't know everything about everything in them.. Am I wrong for being surprised ??? On the track I can't afford to loose grip if I pick up the inside so any suggestions??
000 Racing is offline   Reply With Quote
Old 11-27-2012, 08:10 PM   #2
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
its not a clutch diff, its a torsen diff. if you have one wheel up in the air it will just be like open diff.
sorry, it is a torque multiplier diff.. but 50 x 0 is 0. so yeah.. sorry, maybe not the same sort of LSD you are expecting. but other companies make the ones u are after.
you could have put the handbrake on to apply some torque to the free wheel and that would have got the other wheel moving BTW.
Surok is offline   Reply With Quote
Old 11-27-2012, 08:20 PM   #3
wheelhaus
wheelhaus's Avatar
Torsen = "Torque Sensing" and requires both wheels to have some level of traction or resistance, otherwise you get what Surok described. It has to do with how the orbital worm gears are loaded, if there's no pressure to push back on the worm gears, they spin.
A clutch type LSD is what you were probably expecting, where the diff has two sets of clutch plates with some preload on them. This applies initial resistance while many systems utilize a pin and wedge system that increases pressure on the plates with drive force on the big ring gear. This "wedge" helps reduce slip at low power levels via the initial preload, and strong resistance to slip at high power as the pin tries to split the wedge and compress the plates on each side with increasing force. This clutch style is more popular for motorsports, but requires more maintenance as the clutch plates wear out. It's more tunable, though. The Torsen style is maintenance free, but has some limitations.
wheelhaus is offline   Reply With Quote
Old 11-27-2012, 08:26 PM   #4
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
The traction control should have kicked in and the brake on that wheel should have grabbed to give the other wheel traction..
i know the BRZ does this... (cause mine does) even if the traction control is 'disabled'
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 11-27-2012, 09:54 PM   #5
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
What you're describing fuddbutter sounds like VSC rather than TRC.
For the OP http://www.torsen.com/products/T-2.htm.
Running a thicker oil like Amsoil 75w-110 or Redline 75w-140 helps the Torsen LSD hook up better.
SXE10 is offline   Reply With Quote
Old 11-27-2012, 10:01 PM   #6
000 Racing
000 Racing's Avatar
The Traction / Stability control are out of the game due to the removal of the ring sensor for the removable racing wheel.. with the cage I found it very hard to get in and out.. I am 6'2" but not fat.. the first seat with head wings had to go.. that was costly !!
So I guess I am looking for a new diff after I run it in but before the race season starts in March 13..
Thanks for the education guys..
Old 11-27-2012, 10:05 PM   #7
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
TRD make a 1.5 mechanical LSD. Not as expensive as I thought it would be, either.
Gir is offline   Reply With Quote
Old 11-27-2012, 10:37 PM   #8
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
TRD Diffs are fantastic. I had a 2way TRD in my AE86.. Best money I spent on that car!@
Nafe is offline   Reply With Quote
Old 11-28-2012, 12:14 AM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I don't have an opinion (never having fitted an aftermarket diff) but OS Giken diffs seem to have a loyal following.
Old 11-28-2012, 12:15 AM   #10
Xauterus
Drives: GTS 86 Galaxy Blue
If you are going to change the diff centre then its probably worth changing the ratio at the same time. Also for the track, look at removing the rear sway bar to give you some more droop.
Xauterus is offline   Reply With Quote
Old 11-28-2012, 12:36 AM   #11
caldine
Drives: Verossa VR25 Turbo Manual
I've got a couple of TRD 2 way Mechanical LSD's if anyone is interested .
$NZ 1200 shipped .
caldine is offline   Reply With Quote
Old 11-28-2012, 01:25 AM   #12
Captain Snooze
Drives: Red Herring
Why would you want to do that? You would be upsetting f/r roll stiffness balance introducing understeer. Why would you want more droop anyway?
Old 11-28-2012, 01:40 AM   #13
Xauterus
Asssuming it has been set up for track, the spring rates will be stiffer. Also a rear wheel drive car works much better when the wheels are on the track, especially running a torsen type diff. The Torsen is a great diff that doesnt drag horsepower like a plate type LSD does.
This is a car with limited horsepower, so every bit counts.
Rememeber a race car typically runs stiff springs with sway bars set for minor adjustments. Its not a wrx or fwd that suffers badly from understeer.
A road car typically runs fairly soft springs with large sway bars so its comfortable for passengers.
Since fitting coilovers I havent felt the need for larger sway bars.
Old 11-28-2012, 03:16 AM   #14
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
eh...harder coils doesnt mean you can eliminate the sway bar...
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Is the Limited slip differential identifiable? jabbajaw99 Engine, Exhaust, Transmission 10 09-14-2012 07:23 AM
Video: FR-S / BRZ Torsen Limited Slip Differential Explained Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 06-29-2012 07:22 PM
Scion's Explanation of BRZ FR-S Limited Slip Differential stalon320 Engine, Exhaust, Transmission 5 06-22-2012 11:26 AM
Scion FR-S, Limited slip dif (LSD)? Dbringer Scion FR-S / Toyota 86 GT86 General Forum 20 06-13-2012 03:02 AM
Torsen limited slip BMWDavid BRZ First-Gen (2012+) — General Topics 41 06-12-2012 09:04 PM
