Old 11-04-2013, 01:33 PM   #15
coastertrav
Drives: Whiteout FRS
I've had this problem lately and it has been driving me nuts!
I finally fixed it last Friday and after holding my breath all weekend and my drive to work today, I can say the noise is gone. I found that the three nuts holding the tophats to the strut towers were about 1/2 turn to 1 turn loose. Gave them the goodntite and the noise is completely gone. YMMV, but this turned out to be my problem.
coastertrav is offline   Reply With Quote
The Following User Says Thank You to coastertrav For This Useful Post:
fazm (11-13-2013)
Old 12-08-2013, 10:46 AM   #16
Wilcats
Drives: Toyota 86
The three nuts? Imma check this out tomorrow. Hope to get good results...
Eight - Six
Wilcats is offline   Reply With Quote
Old 12-08-2013, 11:49 AM   #17
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
These nuts have a very low torque spec be careful or you will shear the heads off. Iirc it's something like 14.5 ft/lbs (you should go look it up).
robot is offline   Reply With Quote
Old 12-10-2013, 09:41 PM   #18
Wilcats
Drives: Toyota 86
Originally Posted by Gords_zenith View Post
I get this sound and feeling in the steering when driving on gravel (parking lot, road, drive way). The only thing that comes to mind is maybe some excess back lash in the rack and pinion and electric power steering mechanism? It's not noticeable on pavement. So I don't know for sure what it is.
I kinda feel like this has something to do with the gearbox...
Eight - Six
Old 12-12-2013, 03:06 AM   #19
Poodles
Drives: 2015 Series.Blue
Gravel constantly shifts under a car's weight, making the steering feel a bit....indirect. It's especially noticeable on cars like this (Miata does the same thing with feeling like it's loose)
The sound, no idea, but could easily be normal.
Old 12-12-2013, 10:08 PM   #20
Ozzman
Drives: old
I have the same issue, have checked for anything loose on the front suspension, from swaybar endlinks to subframe bolts and have found nothing. My old Honda with 250,000 miles on it doesn't do anything like it.
I have suspicions that the skid plate may be "oilcanning" and my try taking the plate off to see if the noise/feeling persists.
Ozzman is offline   Reply With Quote
Old 01-04-2014, 02:05 AM   #21
Wilcats
Drives: Toyota 86
Any new update on this issue? I still have this on my unit. Can't figure out where it is coming from. Dealership checked everything and is all tight down there.. sigh..
Eight - Six
Old 01-05-2014, 05:50 PM   #22
araines2010
Drives: 86 GTS
Any updates? I get this also, both on corrugated surfaces and very heavy braking. My 86 only has 2000 km.
araines2010 is offline   Reply With Quote
Old 01-08-2014, 10:45 AM   #23
Wilcats
Drives: Toyota 86
I will try taking off the plates next week. Let's see what happens...
Eight - Six
Old 02-14-2014, 09:28 AM   #24
AJ
Drives: ’13 Asphalt FR-S
Well? did that work?
AJ is offline   Reply With Quote
Found Loose wire...?? IDK what it is rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 34 06-10-2020 01:42 PM
Borla UEL headers + HKS Front pipe + Greddy SP AxleBack = music sounds to my ears. NoFear99 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 09-23-2013 12:02 AM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 02:16 PM
Loose Glove Box Spd229 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-06-2012 02:53 PM
Loose Floor Mats mact Issues | Warranty | Recalls / TSB 0 09-15-2012 12:53 AM
