Old 12-10-2013, 03:34 PM   #29
MAPerformance
Drives: Asphalt FRS
Originally Posted by cslntuee View Post
I remember that the stock throttle body is 65 mm.
Will that gain something from increase the diameter to 68mm which can directly match the stock intake manifold or do you mean there is almost no benefit there ?
Will you still plan to show the dyno result?
Thanks again
Correct, the stock TB is 65mm. And that's exactly what we are planning on doing. We don't know if there is going to be a benefit or not. However, we have a core coming in from Trust Automotive. He will be testing it on a couple of FA20Club turbo cars, and an Innovate supercharged car. Hopefully he will find some good data. Stay tuned
MAPerformance is offline   Reply With Quote
Old 12-10-2013, 04:09 PM   #30
cslntuee
Drives: Subaru BRZ Limited
How about NA?
Will you test the big throttle body on the NA car or have already assumed
no benefit?
Thanks again.
cslntuee is offline   Reply With Quote
Old 12-10-2013, 04:13 PM   #31
MAPerformance
Drives: Asphalt FRS
How about NA?
no benefit?
Thanks again.
We will be testing it on N/A as well. Our fabricator has a bone stock auto FRS that we will bolt it on to see what happens. We just don't have a way to test one with some tuning on an N/A car, which might actually show better gains. But maybe someone can help us out there as well.
The Following User Says Thank You to MAPerformance For This Useful Post:
cslntuee (12-10-2013)
Old 12-12-2013, 12:34 AM   #32
86drift
86drift's Avatar
Drives: Toyota 86 GT
PM'd. I've got a tuned NA and all the gear needed to test it.
86drift is offline   Reply With Quote
The Following User Says Thank You to 86drift For This Useful Post:
MAPerformance (12-12-2013)
Old 12-12-2013, 02:05 AM   #33
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by FR-S Matt View Post
Now would something like this paired with the 3" Perrin CAI yield increased results as N/A or would it be slight? I can see FI benefiting from this heavily.
In for results.
Done this already on my car already.
Perrin silicone intake hose mated with a TODA big throttle body(68mm.. 'big' as in relative terms obviously.. not really that much bigger)
Hose is blinging with some Reflect-A-Gold heat wrap added too. Didn't know there was a 70mm TB released either, but as someone mentioned, a bit silly going that route when the stock intake manifold is 68mm.. derp.
Here are some comparison pics of my TODA vs the STOCK intake.
As can be seen the stock TB finish is quite rough and the taper has a little knuckle before the shaft. Not meaning to thread hijack here, but post-installation of the TODA definitely made the car feel more responsive. The P&P of that must have made an effect.. or maybe it was a placebo effect.
The butt dyno usually doesn't lie though.
TODA Racing TB
STOCK TB
(more pics can be found on my build thread: www.tinyurl.com/Perth86)
PS, never bothered to do a Pre and Post dyno run with the TB installed. Might do it next week or fortnight if I have some spare time.
Also, for anyone contemplating this mod.. $250 is CHEAP. Sometimes I wish I lived in the states..
TODA set me back $1k.
stevo_12v is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
Hawk77FT (01-09-2014), MAPerformance (12-12-2013)
Old 12-12-2013, 03:17 AM   #34
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
@stevo_12v
Ok u didn't dyno b4 or after but what's your impression? Any difference even by butt dyno?
Old 12-12-2013, 03:30 AM   #35
stevo_12v
Originally Posted by OICU812 View Post
@stevo_12v
Feels good! Butt Dyno reckons its at least 5kw increase.
kw as in Killa Wasps
But seriously, feels just a tad punchier.
Old 12-12-2013, 08:04 AM   #36
cslntuee
Did you see (or feel) lose torque at low RPM compared with stock one?
Did TODA throttle body match stock ecu or need to tune?
Thanks.
Old 12-12-2013, 08:23 AM   #37
cslntuee
I am still debating which throttle body I should go.
They are all pretty expensive and I never see any dyno result.
TODA one looks like a taper design from 72mm to 68 mm (pic1)
http://www.todaracingusa.com/catalog/pc/viewCategories.asp?idCategory=198
The image (pic2) shows the taper structure can push the air flow.
The revolution on is 70 mm, but there is one red adapter in the end.
I am not sure that will be same function as taper or is useless
How do you think? Thanks.
http://revo-tune.jp/catalogue/detail.php?id=294
Old 12-12-2013, 09:06 AM   #38
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
MAPerformance 68mm throttle body
I'll wait for @MAPerformance
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 2 Users Say Thank You to ecko04 For This Useful Post:
MAPerformance (12-12-2013), RehabJeff86 (12-19-2013)
Old 12-12-2013, 09:34 AM   #39
stevo_12v
Maybe a sort of sleeve?
Yeah I saw that red adaptor. Maybe that may act as a type of sleeve and bypass the stock intake size? I'm not 100% sure so can't comment on that.
Whilst at the workshop during changeover of the TB's we never got around to measuring the difference in sizes - in hindsight we should have.
I'll most probably be doing that next week or next fortnight if I can book something in before the xmas holidays.
Old 12-13-2013, 07:00 AM   #40
cslntuee
When you plan to show the dyno result on NA?
Thanks.
Old 12-13-2013, 09:56 AM   #41
MAPerformance
Drives: Asphalt FRS
Thanks.
As soon as we finish the one we have in house. I think we just got the throttle plate finished, so once we put it back together, we can throw it on our fabricator's bone stock FRS. We don't have any tuning available however, so I don't know if I will have results of what it can benefit with a tune. But hopefully we can have someone try that out as well.
cslntuee (12-18-2013)
Old 12-13-2013, 10:20 AM   #42
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
im just glad to see a manufacturer trying something different. im sick of everyone posting catbacks and intakes like a new pipe is gonna help us catch a 370z on a road course lol
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following 2 Users Say Thank You to Grip Ronin For This Useful Post:
MAPerformance (12-13-2013), zohare (09-04-2014)
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 10:58 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
