| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: 2004 Subaru Forester 2.5XT
I think BRZY is onto something.
![]() There is no such thing as "7.5w-27" in SAE J300. The first number represents cold cranking viscosity and is only tested for 0W, 5W, 10W, 15W, 20W, and 25W. Period. http://www.pqiamerica.com/coldcrank.htm There is also no such thing as "27". There is 20, 30, 40, etc. and 16 is right around the corner. http://www.tribology-abc.com/abc/viscosity.htm#SAE Before dumping this unknown oil into a car, I would at least do a virgin oil analysis including TBN and viscosity at 40C. There are so many mistakes on their web site it's not even funny (actually it is very funny). Here's one for starters: What they have embarked on is the reduction of SAPZ. This is Sulfated Ash, Phosphorous and Zinc. This is wrong. It is called SAPS - Sulphated Ash Phosphorous and Sulfur (although sulfur is part of ZDDP). http://www.lubrizol.com/EngineOilAdd.../LowerSAPS.pdf Of course, they fail to mention that there are non-metallic organic additives being used due to the reduction of ZDDP. There is also an increase in multi-functional additives such as old and new forms of molybdenum and boron. Note that the BRZ/FR-S does not have flat tappet cams. More reading: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=245760 http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=641544 I anxiously await the uoa's. -Dennis Last edited by bluesubie; 11-25-2013 at 10:24 AM. |
#16 |
Drives: WRB BRZ, Monte Carlo SS
I'm glad this forum is reopened thank you moderators. I received my blackstone oil test kit but it was crushed in the mail I'm waiting for another one to come in sorry for taking so long.
#17 |
Are you doing a virgin oil analysis or only a uoa? Please get TBN as well.
Also, can you drive up to Central NJ so that I can witness the sampling procedure to make sure you don't cheat and add some Mobil1 to your sample? I also need to put a lock on the oil fill cap. ![]() Thanks, Dennis |
#18 |
I am doing a virgin oil analysis , UOA, and TBN because you asked. I'll even post a video of me sucking the oil out and sticking it into the bottle.
#19 | |
Drives: FR-S 6MT
#20 |
The Answer
Drives: Mazda 2
This just voided the warrenty.
| The Following User Says Thank You to Rayme For This Useful Post: | NickFRS (01-31-2014) |
#21 |
i received the Blackstone kit in the mail today i will be shipping it out tomorrow for analysis. Thank you for your patience.
#22 |
Found a recent uoa on a Quantum Blue blend at bitog:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3210926/Quantum_Blue_/_5W-30/8,459_mi/#Post3210926 I'm really amazed at the levels of phosphorus in this oil. It's more than any racing oil that I've seen. This is much higher than MPT Thirty-K, Amsoil Dominator, Motul 300V, Red Line Street oil, Red Line Race oil, Mobil1 Racing Oil, etc. Hopefully yours won't be that high, unless you don't have cats. Otherwise, you may have a dead kitty if you burn any oil. -Dennis |
#23 | |
#24 |
I'm running catless. Would the extra phosphorous in this oil be a good thing?
I know when I had air cooled Porsches the best oils had the most ZDDP because it helped with the higher pressures. My car is getting a turbo kit and catless exhaust installed presently, planning on running Motul oils. |
#25 | |
Mobil1 actually recommends their 0W-40 or 15W-50 for street cars that see track use and for applications that call for those viscosities. The 0W-40 has 1,000 ppm's of phosphorus and the 15W-50 has 1,200 ppm's. Motul 300V 0W-20 uses around 900-1000 and I believe that Red Line Street oil uses a bit more phosphorus at 1300-1400. Brad Penn uses around 1,300 as well. Motul and Red Line use a lot of molybdenum as well, which is a great friction modifier. Although there hasn't been much of a uoa trend (these cars are still relatively new), there are some good random uoa's on this forum showing that the phosphorus levels in Red Line and Motul 300V 0W-20 appear to be fine for forced induction, tracked applications. Like I said above, maybe the phosphorus levels in the OP's blend will come in a bit lower than the bitog uoa. -Dennis |
#26 |
Good news I'm sending the oil out today through ups. Bad news is my dad accidentally dropped the drain nut so I drained all my oil out and replaced it with Mobil 1 for now. I will post the results when they come in.
#27 |
I know when I was racing Porsches, that Brad Penn and Swepco were very recomended because of the extra ZDDP and their formulas. This was for air cooled engines though, and these are Dino oils.
Our twins run on synthetic, and I'm changing the oils to Motul presently, but if there's a better oil brand to run I'd run that of course. Has anyone ever heard of, or run Klotz oils? |
#28 | |
I would stick with Motul though. Even though they make non-API certified race/street oils, they also make oils that meet the most demanding specs, builder approvals, and certifications in the world (same goes for Mobil1 and many other brands. No offense to Quantum Blue ). I can't really tell by the pic, but it looks like the Klotz has sort of a rip-off logo of the API starburst on the front of their bottle. -Dennis Last edited by bluesubie; 12-19-2013 at 02:31 PM. |
| Tags |
| blackstone, bnd, oil |
| AT owners only, custom CF paddle shifters, pin stripe custom color | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 80 | 02-03-2016 10:35 AM |
| FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! | Diode Dynamics | Interior Parts (Incl. Lighting) | 155 | 11-19-2014 11:42 AM |
| Perrin Pulley review? Invidia Q300 exhaust review? | ScionFrsFan | Engine, Exhaust, Transmission | 4 | 12-10-2012 08:27 PM |
| AutoExpress BRZ Review - Follow up to the GT86 Review | Zgrinch | BRZ First-Gen (2012+) — General Topics | 3 | 12-13-2011 08:03 AM |
