Old 12-10-2013, 07:26 AM   #43
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Originally Posted by civicdrivr View Post
You sure you didn't install the bushing upside down or backwards? I'm running the Perrin shifter bushing and it didn't change the position of the shifter one bit.
Sent from my Nexus 4 using Tapatalk 2
Do you also have the kartboy short shifter? It only goes in one way. I don't have the Perrin one I have the kartboy one so there might be some difference there.
Mad_Mike is offline   Reply With Quote
Old 12-10-2013, 08:11 AM   #44
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
No, I'm running the BPS short shifter and Perrin shifter bushing. I haven't had the Kartboy shifter in my hands, but it looks very similar to the BPS unit.
Depending on how much slop your stock shifter bushing had in it, that could play a part in 2nd no longer being where it should be. If the shifter arm (the arm that the bushings slides onto and then secures to the body) is now much sturdier, the shifter will no longer have as much lateral movement, making it seem like second is no longer where it needs to be when in reality you just need to move the reverse lockout plate over slightly to make the 2nd gear gate more defined.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
SirBrass (12-10-2013)
Old 12-10-2013, 08:16 AM   #45
modena
modena's Avatar
Drives: BRZ Limited WRB MT
Running around with the Kartboy shifter for about 100 miles now,
Works great, no issues with 2nd gear, reverse lockout works the way it should be and just checked, no problems shifting from neutral into second gear...
I have not installed the bushing yet.
KartBoy SS | BlackVue DR550GW | Valentine1
GrimmSpeed MC Brace | GrimmSpeed Hood Struts
OEM Armrest | OEM STI Badges | 20% Tint
Rydeen duo | Halo's as DRL
Rexpeed Wide Mirrors
modena is offline   Reply With Quote
Old 12-10-2013, 08:25 AM   #46
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
I have the Kartboy SS and the rear stay. I had the shifter in for about a month before the bushing and my shifts are 10x better than before now that the bushing is in there. Granted, I did change to Amsoil in the transmission at the same time as the bushing. Positive shift kit bushing is going in the end of the month, but I don't expect to feel much of a change.
lickitysplit is offline   Reply With Quote
Old 12-10-2013, 11:28 AM   #47
Mad_Mike
Mad_Mike's Avatar
Well I'm glad you like the shifter feel now. For me I loved it with just the short shift. Installing the bushing just made it way too notchy. I just put in the shifter springs and I haven't fully made up my mind on them.
Old 12-10-2013, 02:50 PM   #48
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
It might be a few more days before I get back into this, but I think I'll start with the reverse lockout plate. If that doesn't work, I'll switch the Perrin out with the stock "bushing," although that thing is pretty much just a bracket and not a bushing from what I remember. If neither of those work, then I'll just start adjusting things until something happens.
...2nd was no longer all the way to the left and straight down but more in between where 2nd used to be and 4th.
That is exactly the situation. Which gives me hope that maybe all I need to do is switch that back to stock and I'll be good to go.
This is why you don't install 4+ things all at once. I already knew, but was trying to make a deadline.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 12-10-2013, 03:00 PM   #49
wparsons
wparsons's Avatar
Originally Posted by FR-S Matt View Post
lol, when I took mine off, I looked at it again and said, "Yeah right"
Trash can.
I kept the stock catback though. That's valuable.
The stock front pipe is probably worth more than the stock cat back... OEM cats aren't cheap parts at all (some cars are $1000+ for just the OEM cat), even wreckers pay good money for a used cat.
flickr
Old 12-10-2013, 04:51 PM   #50
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Except the rear bushing ships with the KB short shifter. Tom@Kartboy intended the 2 to be used together, and this is the first I've heard of the issue, so there's got to be more to it than that the bushing is not right.
That's what it felt like in my STI with KB short shifter and front/rear bushings. Then my car put about 1k miles onto the bushings or so... and over that distance the bushings broke in and.... perfection. Once those new harder bushings break in, it's great. Way more firm than stock, but with just the right amount of give.
^GT5 Replay Photo Mode^
Old 12-10-2013, 05:21 PM   #51
Anthony
Weight Nazi
Anthony's Avatar
That sounds about right. I bought my shifter used and the seller didn't include the bushing. I figured they would all be about the same, so I went with Perrin because it was like $2 or $3 cheaper.
If the stock one feels good, I'll just use it. I think it's lighter, anyway. Between the shifter, the springs, the positive shift bushing, and my new tranny oil, my shifting feels incredible. It snaps into place with such authority. It's awesome. But holy balls, 2nd is easy to miss.
Old 12-10-2013, 05:26 PM   #52
SirBrass
SirBrass's Avatar
That's the thing... it shouldn't be easy to miss. It should still be where it has always been.
Old 12-11-2013, 11:33 AM   #53
FearBoy
Drives: 2013 BRZ Limited
I forgot about this thread. Did you try repositioning the lockout plate and running through all gears? Make sure that all gear changes are possible before putting the interior back together. The short shifter and MTEC springs can increase shift effort quite a bit.
I've noticed in my car that 2nd gear is a real pain to get into when the transmission is cold. I have to double clutch most times until things warm up.
FearBoy is offline   Reply With Quote
Old 12-11-2013, 01:14 PM   #54
SirBrass
SirBrass's Avatar
What are MTEC springs? From what FearBoy is saying, it doesn't sound like they're suspension springs...
Old 12-11-2013, 05:16 PM   #55
FearBoy
They are springs that help center the shifter in the neutral position. Basically, they should improve 2nd-3rd and 4th-5th shifts by guiding you through neutral.
Old 12-11-2013, 05:22 PM   #56
OrbitalEllipses
Drives: Attitude
How many miles on the box, how many miles on the fluid, and what trans fluid? I had this issue last winter, but it's colder than it was now than when I was having issues last year...and I'm not having any issues with 2nd gear lockout.
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 03:02 PM
CounterSpace Garage || Jackson Racing Oil Cooler | Motul Engine Gear Oil Packages || CounterSpace Garage Engine, Exhaust, Bolt-Ons 41 07-08-2016 04:19 PM
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 226 01-19-2015 01:46 PM
No Motul Gear 300?? markmatley Hawaii 14 04-17-2013 08:59 PM
