#29 |
Drives: 13 BRZ Limited WRB
I would skip it then. It will only provide benefit in mid to extreme driving situations - Otherwise it's just a $150+ bar for dress up.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#30 |
Drives: 2013 Firestorm FR-S
I do track the car occationally, so the car being more neutral in terms of handling is not a bad thing.
2013 Firestorm FR-S, MTX, build date 1/13.
#31 |
Drives: 2013 FRS, 2008 R32
Installed mine lastnight. Love, love, love the feel.
Same coils as you gopher but different alignment settings. -2 all around. No particularly glaring signs of understeer but the car is certainly less "tossable" due to the reduced body roll. Granted, our setups are different. I'm sitting with -2 camber all around with 265/35 Michelin PSS. Car hooks like crazy. I love it. |
| The Following User Says Thank You to mfbmike For This Useful Post: | boredom.is.me (12-12-2013) |
#32 | |
Custom User Title
Drives: Asphalt FR-S MT
| The Following User Says Thank You to boredom.is.me For This Useful Post: | mfbmike (12-12-2013) |
#33 | |
Yea - when my car wakes up for the year in March, or you know, July with our weather here in Fargo - I'll have it realigned. I put my stock wheels and tires on a few weeks before I put the car away, and I will say it felt more light on it's feet than with my 17x8 245's. But, meh.
#34 | |
In my sti, I have equal amounts of fun on 225/45 'street tires', 255/40 RS-3 and 225/45 R-Compound slicks. I think that they each have their procs and cons. The sharpness and resolution that the narrower tires offer is awesome and the car is certainly more 'tossable. On the stickier 255's, it's just big, fat, dumb grip with less 'sharpness'. The slicks, of course, are a whole different ballgame and I find them to actually be less fun. Any pics? Matt Beenen Engineering |
#35 | |
http://www.ft86club.com/forums/showp...&postcount=114 |
#36 |
Drives: AE86, 2x GT86, TE27
Do you need to drop one of the shocks to install this, or is there enough slop or a slotted holes on the bar?
Cheers Edit - I see that you don't need to drop the shock. PM'd. |
#37 |
#38 | |
Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | mfbmike (12-13-2013) |
#39 |
I thought I'd resurrect this thread for fun and a couple of questions.
1) How much does this weigh (don't see it on the mnfr web site) 2) I've read it's important to get the front wheels off the ground before installing a strut tower brace, this appears to bolt on without and since there's no adjustment I guess it wouldn't matter if the front end's off the ground anyway. Does that make it less effective than another type like the Tanabe that has some adjustment and suggests unloading the front suspension first? |
#40 | |
In my experience, there's no reason to lift the front of the car to preload it. I figure you'd want to bolt it to the car with normal load on the towers anyways. There's a reason they made a solid bar instead of a adjustable bar through all their testing...
| The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post: | Dake (06-10-2015), GrimmSpeed (06-11-2015) |
#41 | |
However: 1. The strut bar weighs 3.95lbs 2. The mounts are slotted to allow for a little movement during install because the studs are not straight up and down relative to the plane of the bar, and when measuring the distance between towers for the initial design we always used the cars on the ground. Leaving the car on the ground to install is the same as pre-loading the bar. And as Gopher said, we designed it solid for a reason, because it is extremely effective. So much so that it has a noticeable decrease in low speed NVH, which is attributed to it's stiffness: ![]() This shows the cyclic nature of the movement between strut towers. They move both towards each other, and away from each other. So being able to adjust preload to push the towers against each other starts to make less sense compared to simply locking them together. Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | phobos512 (06-11-2015) |
#42 |
I see - makes sense thanks!
| Password JDM Ultimate Strut Tower Brace Package Review and Photoexplosion | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 06-16-2015 03:05 PM |
| BRZ/FR-S Strut Tower Brace - Any Interest? | GrimmSpeed | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1224 | 05-10-2015 06:40 PM |
| NPA: GrimmSpeed Strut Tower Brace for SCION FR-S & Subaru BRZ now available | 86_Insider | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 09-30-2013 10:21 PM |
| FT-86 SpeedFactory Strut Tower Brace Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 01-07-2013 04:31 AM |
| DIY - Strut Tower Brace - FT-86 SpeedFactory | F1point4 | DIY (Do-It-Yourself) Guides | 4 | 10-28-2012 04:30 PM |
