Old 12-09-2013, 09:21 PM   #1
Mister
Mister's Avatar
Drives: Firestorm FRS
Drivers Side Window (Not Seal)
My drivers side window was behaving erratically and now it appears to be seriously broken.
First off is that it no longer goes up and down an inch when opening and closing the door. It is just stuck a little bit down, just enough for melting snow and a good downpour to get in
To make it more fun are the drivers side window switches. The switches are blinking...indication of a problem? The auto-up/auto down feature are not working when I try to use them for the drivers side. The passenger side will not respond at all to the drivers side controls (it works fine from its own controls).
I tried bringing it the rest of the way up with the door wide open in case it was catching on the seal, and that still will not bring it up.
OH and the crickets returned this week :-).
Anyone else have an issue like this? I'm trying to find something out before I bring the car in for the 4th warranty item.
Mister is offline   Reply With Quote
The Following User Says Thank You to Mister For This Useful Post:
Charky (12-10-2013)
Old 12-09-2013, 09:43 PM   #2
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Your window probably froze and the window modules needs to be reset. You have to roll down the window all the way down while holding the buttons for a few seconds, then up again and once it reaches the top hold the button for a few more seconds. The door has to be closed. If it worked the blinking will have stopped.
Rayme is offline   Reply With Quote
The Following 6 Users Say Thank You to Rayme For This Useful Post:
Cahue (12-10-2013), Hachiroku14 (12-10-2013), humfrz (12-10-2013), Mister (12-09-2013), Steve201brz (12-10-2013), Trap63 (12-10-2013)
Old 12-09-2013, 11:29 PM   #3
Mister
Mister's Avatar
Hmm interesting. I wonder why it would get messed up just from being frozen. I'll try it in the morning and report back.
Old 12-10-2013, 12:30 AM   #4
There ya go @Mister, Rayme nailed it for you ... hopefully.
Sometimes the auto window things get confused if the battery has been disconnected.
OR ...... maybe, the "crickets" ate through the wiring .... or the cricket poop gummed up the window switches....
Mister (12-10-2013)
Old 12-10-2013, 01:40 AM   #5
kALMIGHTY
Drives: TRD Ultramarine '13
Same thing happened to me a few days ago after a really cold day. It's because your windows freeze shut, and when that little window up/down feature when you open and close the doors tries to work when it's frozen, the window doesn't move and the servo motor basically goes out of sync and gets confused, so it starts to blink.
Rolling it down all the way and holding it and then pulling it up all the way and holding it resets the servo and syncs it back up to the window. Nothing to be alarmed about.
Old 12-10-2013, 04:10 AM   #6
Hachiroku14
Drives: 2014 BRZ World Rally Blue
got my car today with this, thanks for the help! This should be a sticky!
Hachiroku14 is offline   Reply With Quote
Old 12-10-2013, 07:56 AM   #7
Mister
Mister's Avatar
Thank you @Rayme!
Tried the fix this morning, that does indeed work.
I was alarmed, I thought there was a loose connection in the door.
Old 12-10-2013, 10:06 AM   #8
Yep, the sticky could say "read page 53 of the owners manual" ....
Old 12-10-2013, 05:21 PM   #9
Cahue
Cahue's Avatar
Man, I was getting pretty nervous and angry at my windows and the blinking of the window switches.
Thanks Rayme. You're a life saver.
Cahue is offline   Reply With Quote
Old 12-10-2013, 05:56 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Mister View Post
Thank you @Rayme!
http://techinfo.subaru.com/proxy/712...316DSTIS_3.pdf
Page 70.
-alex
Old 12-10-2013, 06:38 PM   #11
Originally Posted by mav1178 View Post
page 72 (BRZ); page 53 (FR-S) .....
Old 12-11-2013, 01:49 PM   #12
Steve201brz
Had this issue this morning when my window froze. Window wouldn't go down and switches were flashing.
Blasted the heat for a while to thaw out the windows before trying the fix. Just posting to say that it works.
Steve201brz is offline   Reply With Quote
Old 12-11-2013, 03:38 PM   #13
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
So does no one read the manuals to their products anymore? That's the first thing I do.
Evil Jesus is offline   Reply With Quote
The Following 2 Users Say Thank You to Evil Jesus For This Useful Post:
humfrz (12-11-2013), WRXGuy1 (12-17-2013)
Old 12-11-2013, 05:04 PM   #14
Steve201brz
I read it front to back but some of it wasn't as straight forward as I thought it should be. Then again I have terrible reading comprehension I've always learned faster being shown then told... Sometimes someone else explaining it just sinks in a lot better
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Cant find passenger window wire from drivers side remote.. help? luv85 Electronics | Audio | NAV | Infotainment 2 11-03-2020 09:13 AM
Window Seal Leaves Marks on Windows AsianStyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-22-2013 03:28 PM
Rattle in drivers side headliner-help! meadowz06 Issues | Warranty | Recalls / TSB 5 09-18-2013 10:44 PM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 05:32 AM
