Old 12-06-2013, 01:32 PM   #533
fatoni
Hah I know that car... I've coached Matt a bit over the last year and half or so. He's gotten pretty quick.
I didn't know you were on the flat out forum. Whats your handle?
i think its the same as here. i dont really post that often because for the last five years or so, school has really kept me from going to the track. now that im done with that im really looking for a track car. seeing cars that just seem sorted and fairly priced makes me cry a little when i just bought the brz.
I definitely recommend an alignment, at the very least with the factory camber bolts. Hell I'd do that off the showroom floor. But for the bare minimum for safety it's just brake pads and fluid IMO.
- Andy
yeah thats what i do with my miatas. i just havent been to the track in anything that wasnt well sorted but this car seems pretty purpose built. i dont care about making the car fast. i just want sustainable fun. thanks.
Old 12-08-2013, 11:21 PM   #534
Hawk77FT
Drives: GTS 86
i have lowered my car with Eibach Sportlines. I have also added the roll centre/bump steer correction kit from Whiteline, SPC rear lca's and front camber bolts (16mm) with factory wheels. What are the correct alignment specs that:
1. will not wear the tires unevenly
2. give me a decent grip (i know is in the tires but the camber will help me a bit too) for street use and some very rare track/skid pan days.
cheers
Hawk77FT is offline   Reply With Quote
Old 12-17-2013, 01:45 PM   #535
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
thinking of winter specific setup..
where would i be able to source taller and softer springs to go over the OEM dampers, and how much extra height could the OEM dampers handle.
Old 12-31-2013, 12:15 PM   #536
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Hey CSG and RCE.
Was wondering if either of you have any experience with MCA suspension, specifically the blue series. They are a pretty big brand down here in Aus, not sure about over there though.
http://mcasuspension.com/blue-series/
Im considering a set for my 86, due to the reputation they have down here.
Cheers.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 12-31-2013, 12:44 PM   #537
CSG Mike
CSG Mike's Avatar
Originally Posted by Khorne View Post
Hey CSG and RCE.
Cheers.
Not I, said the fly.
They do seem to have a great reputation though.
Old 12-31-2013, 12:46 PM   #538
CSG Mike
CSG Mike's Avatar
cheers
I'd recommend you align for the street, and then just accept the wear from track/skidpad days, since it's primarily a track car.
0 to 1/16" total toe-in front
0 to 1/16" total toe-in rear
Max out your front camber using camber bolts; it should be around -1.5 or so.
run about -1 in the rear.
This will work for spirited street driving, and not destroy your tires on track, and also give you good life.
Keep in mind, everything about that alignment is compromised. It's not the best of any thing, but it does everything okay.
Old 12-31-2013, 01:13 PM   #539
Hey CSG and RCE.
Cheers.
I've not tried them but have heard good things as well.
- Andy
Racecomp Engineering is online now   Reply With Quote
Old 12-31-2013, 01:13 PM   #540
Eibach can make one-off custom springs, but it's not cheap.
- Andy
Old 12-31-2013, 01:20 PM   #541
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
You two are quick haha, i'll give them a go they do have a great reputation.
Happy 2014 from Australia, its 2am 1/1/2014 here
Build thread
Old 12-31-2013, 01:46 PM   #542
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
PM sent @Racecomp Engineering
shaunsweeney is offline   Reply With Quote
Old 12-31-2013, 02:57 PM   #543
Malt
Drives: 2015 WRX
I'd have a similar questions. I don't have adjustable LCA's but I do have caster/camber plates up front. What alignment would you suggest for a daily driver that also see a couple HPDE a year (2-3). Ideally I'd set the camber up front for either the track or street and then adjust with the plates back to the ideal camber setting for the opposite of what the car was originally set at. I know this affects Toe but I'm curious if there was some setting that I could do with my camber plates to avoid changing the toe every single time I want to do an event. Suggestions?
Malt is offline   Reply With Quote
Old 12-31-2013, 03:09 PM   #544
CSG Mike
CSG Mike's Avatar
You won't have any rear camber adjustability.
Use camber bolts to "max" the front camber via the bolts. Then use camber plates to fine tune. Mark them. Then adjust them for about -3 in the front, and mark them again. Those will be your two settings. As you get more experience, you'll get a better idea of what you prefer.
Keep in mind you'll have more front than rear grip under cornering, so that camber stagger will result in a looser car.
Old 12-31-2013, 03:21 PM   #545
Malt
Drives: 2015 WRX
Thats what I was planning on doing but wont the toe change when adjusting the camber through the plates? Is that a cause for concern?
If so, should I set the toe on the track setting or the street setting and then adjust back to other setting through the plates? Basically I don't want something that is going to be dangerous or absolutely destroys the tires. If that means I have to adjust the toe each time then I guess I should learn how to do it.
Old 12-31-2013, 03:23 PM   #546
CSG Mike
CSG Mike's Avatar
The toe does change, but not a HUGE amount.
Set the toe for street use.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
