| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 | |
Drives: 2004 Subaru Forester 2.5XT
![]() In the context of the original post, because the factory fill has higher levels of some anti-wear additives (like molybdenum and zddp) than the oil that you can get from the dealer and it is beneficial to follow the OEM's recommendations during break-in instead of going by how an oil looks or because someone thinks there's a lot of metal in the factory fill. And in the context of changing oil too early in general, because the SAE has written papers on how used oil can be better than new. It can take mileage, time, and heat for the additives in oil to activate. Used oil better than new? This can be seen in cases where someone does uoa's at say 1,000 mile intervals but does not change the oil. The first few uoa's can show higher wear metals than the uoa's towards the end of the interval. And because it's just a waste to change oil too early. http://www.edmunds.com/car-care/stop...-your-oil.html -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | Suberman (11-25-2013) |
#30 | |
Drives: Skoda Yeti DSG diesel 4x4
If that is correct we should only replace 50% of the old oil to protect the engine until the new oil starts doing its job properly. |
#31 | |
Drives: Subaru BRZ Sport Tech Satin White
#32 | |
My first cars were all early fords with the 1172cc side valve engine, 3 speed box and cable brakes. Amazingly I only destroyed one engine, it was winter, with no heater and I was wearing one of those Russian style fur lined hats with a tranny tucked inside one of the ear flaps. I didn't hear it start to rattle and give it a top up with used sump oil and it was terminal when it lost power and stopped. It was almost more fun in those days because it was an adventure into the unknown going anywhere! |
#33 |
Drives: 2014 Subaru BRZ
Subaru recommends the first oil change at 3,000 miles, then at 7,500, and every 7,500 miles after. You can stick to that and you'll be fine.
| The Following User Says Thank You to PERRIN_Chris For This Useful Post: | SirBrass (12-04-2013) |
#34 | |
Guy on internet
Drives: Slowly
Here's what I did. I drove the car pretty aggressively the first 500 miles. Making sure I don't stay in consistent RPM, to set the rings. Change the oil at 500, to get all the break in shit out, which there was some. Then follow the 7500 interval. If you drive like I do, I do it every 5000. Not saying that's the golden rule, just what I did. |
#35 |
Drives: CBS Subaru BRZ
I want to change oil filters without replacing the oil. If I unscrewed the filter without emptying the oil, will the oil spurt out?
#36 |
#37 |
Drives: Thee Argento Cricket
I did mine around 3500. Let's just say that the oil was DIRTY. If Toyota "recommends" 7500, I seriously doubt they care about the longevity of their customer's cars. Basically if the engines blow, more sales.
#38 | |
Drives: WR Blue BRZ, 240Z
You may have a hard time believing this, but there are a team of engineers at Toyota that conduct direct testing to determine the longevity of the engine. THIS INCLUDES HOW OFTEN TO CHANGE OIL. If you are unsure how often or when to change oil, here's a little hint: READ THE OWNERS MANUAL. Toyota has a vested interest to ensure that your engine meets its design life. That design life is around 250,000 miles! BTW, oil color has nothing to do with the condition of the oil.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#39 | |
The reason the owners manual doesn't say that is because it is just a fact that engine oil needs to be changed by mileage or time, whichever comes first. "Dirty oil" claims is a technique used by oil change places to sell more oil. Engine manufacturers are very conservative in recommending oil changes. In reality the oil lasts much longer in the majority of cases. The change interval is set for the more severe conditions usually expected. Only if you really punish your oil frequently driving very hard on a track or by multiple short trips to the grocery store where the engine never gets hot, stick with the factory's recommendations. |
#40 |
Regardless of what you say there is no way I would continue to use engine oil that was black.
It's contaminated and getting replaced. |
| The Following User Says Thank You to sierra For This Useful Post: | ndsleep612 (12-08-2013) |
#41 | |
So if you track your car roughly once a month and your mileage is below 7500, don't tell me that you won't change your motor oil just because the service manual said so. If the oil is black and contaminated, therefore it is "dirty". |
#42 | |
| Tags |
| some idiots post here, stock oil is synthetic |
| Almost at 1000 miles. Oil change when? | TheGuyWithTheFireStorm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-08-2013 12:31 PM |
| oil change at 1000 miles! thoughts? | ric342 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 23 | 05-23-2013 10:37 AM |
| Oil change at 1000 miles. | Dorb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 03-08-2013 04:18 PM |
| Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) | R2RO | Issues | Warranty | Recalls / TSB | 3 | 02-04-2013 10:06 PM |
| When to change the oil | Capstan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 10-11-2012 02:41 PM |
