Old 12-08-2013, 11:18 AM   #15
Mikem53
Drives: FR-S 6MT
Originally Posted by Weeber View Post
How many miles are you at now? Has it used significantly less?
Just went out in the garage and checked the oil level.. Just barely above the top dot where it was 700 miles ago when I changed it..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Weeber (12-08-2013)
Old 12-08-2013, 12:26 PM   #16
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Hi guys,
Just last month I checked my engine oil level on 1000 Miles and the second dot was filled with oil but just today I saw it wasn't covered in oil at 1530 Miles?
It is still factory oil with none ever added.
Only difference is that I measured oil last time when engine was fairly warm and this time It was cold and haven't been driven for 9 or so hours.
Could I possibly be burning oil this early?
Here are some pics showing both sides of the dip stick:
Perfectly normal for an engine to use this much oil during break in.
That dipstick doesn't look like it's showing the level correctly. I'd wait until the engine is cold, parked level and check again before I added any oil.
As long as you're absolutely sure you checked the level correctly just top up and drive. Check it again in 500 miles. Because the dipsticks in these cars are so hard to use accurately I'd add only half a quart and drive for 200 miles before checking again and doing a final top up. Engines run fine a quart low.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Weeber (12-08-2013)
Old 12-08-2013, 02:51 PM   #17
mike the snake
If you take some fine sandpaper or emery paper and scuff the dipstick from the tip to about an inch above the top fill hole, it will make reading the levels much easier and accurate.
The Following 2 Users Say Thank You to mike the snake For This Useful Post:
Suberman (12-08-2013), Weeber (12-08-2013)
Old 12-08-2013, 06:38 PM   #18
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I never lost any (noticeable amount) oil within the break in period.
Muaddib is offline   Reply With Quote
Old 12-09-2013, 03:30 AM   #19
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
in the first fifth month/first service I lost half liter (half the dipstick), now I am in 9th month and the oil only moved a bit from the top level.
I believe oil consumption will improve after some time.
gzpermadi is offline   Reply With Quote
Old 12-09-2013, 10:48 AM   #20
Suberman
Every engine is different. Also, every driver breaks in the engine slightly differently. The key is does it keep using oil or start using oil after the break in is fully complete: about 10,000 miles.
Only the first 1,000 miles involves any special driving. For the next 9,000 and forever actually, the engine benefits from hard use. It continues to loosen up for at least 10,000 miles.
JB86'd (12-09-2013)
Old 12-09-2013, 11:06 AM   #21
DarkSunrise
DarkSunrise's Avatar
If your engine is still breaking in, I wouldn't worry about it. Also cold vs. hot engine will make a difference.
2022 BRZ Build
2013 FR-S Build
Old 12-09-2013, 12:50 PM   #22
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
For the truly paranoid: drain and measure. Refill with the same oil you drained to not waste.
-alex
Old 12-09-2013, 08:58 PM   #23
Suberman
-alex
Same oil? Or same quantity of new oil?
Old 12-09-2013, 09:11 PM   #24
mav1178
mav1178's Avatar
Well, fill with the same oil you drained. I don't see why it can't be done if you use clean containers to measure and refill. I only suggested this as a fix for the person who is paranoid about engine oil levels and whether the car is burning oil at 1530 miles or not.
-alex
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 05:26 PM
2013 Scion FRS Engine, Transmisison, harness 9k miles! JoeDrifter Engine, Exhaust, Bolt-Ons 4 12-10-2013 10:08 AM
Car Dies at 170 Miles Check Engine Limp etc CASE CLOSED learnerspermit Issues | Warranty | Recalls / TSB 38 11-06-2013 03:51 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
Check engine light now on at 2995 miles Marshman Issues | Warranty | Recalls / TSB 2 12-17-2012 08:41 PM
