Old 12-08-2013, 12:05 AM   #1
Weeber
Burning engine oil already? 1530 Miles
Hi guys,
Just last month I checked my engine oil level on 1000 Miles and the second dot was filled with oil but just today I saw it wasn't covered in oil at 1530 Miles?
It is still factory oil with none ever added.
Only difference is that I measured oil last time when engine was fairly warm and this time It was cold and haven't been driven for 9 or so hours.
Could I possibly be burning oil this early?
Here are some pics showing both sides of the dip stick:
Weeber is offline   Reply With Quote
Old 12-08-2013, 12:10 AM   #2
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Subaru considers normal a quart of oil every thousand miles I believe but don't quote me on that. My brz burns oil too but maybe less than half a quart every 3000 miles.
cjsporl1996 is offline   Reply With Quote
Old 12-08-2013, 12:13 AM   #3
Weeber
Seems odd that many people seem to have not lost any oil for their cars even 5000miles +?
Old 12-08-2013, 01:21 AM   #4
Gen
Drives: Scion FR-S
Might be leaking from the cam plate if this is a MT.
Gen is offline   Reply With Quote
Old 12-08-2013, 01:29 AM   #5
Weeber
Auto
Old 12-08-2013, 01:34 AM   #6
toeout
Always measure oil under the same conditions or you're going to drive yourself nuts. I measure mine in the morning, before I start it. And make sure it's level where you park it.
toeout is offline   Reply With Quote
Old 12-08-2013, 03:28 AM   #7
suaveflooder
Weird. I change mine around 5k miles and it looses a little, but nothing crazy. It starts at the top hole and is about 1/2 way down to the bottom hold after 5k miles.
suaveflooder is offline   Reply With Quote
Old 12-08-2013, 04:20 AM   #8
Originally Posted by Weeber View Post
Hi guys,
Just last month I checked my engine oil level on 1000 Miles and the second dot was filled with oil but just today I saw it wasn't covered in oil at 1530 Miles?........
I wouldn't worry about that much loss during the first few thousand miles.
However, keep an eye on the level. Like said, make sure your car's engine is cold and the car is level when checking the oil.
Mine "used" about a quart during it's first 2,000 mile. Now, at 8,000 miles it hasn't used a significant amount.
Hint: If you have a hard time reading the dip stick, lay it down on a paper towel ....
Old 12-08-2013, 04:40 AM   #9
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
poor run-in will have the engine burning oil like an EZ30R.
JP is offline   Reply With Quote
Old 12-08-2013, 09:13 AM   #10
Weeber
How much is a quart of oil in the dip stick reading?
I am about 1/4 way down from the top dot,
Also I did try break in with engine load as much as I could,
Is this normal?
Old 12-08-2013, 09:46 AM   #11
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Is this normal?
I believe from the bottom hole to the top is 1 litre=~1 quart. So just divide that distance by four and you will have 1/4. I have noticed that it takes a few minutes for all the oil to reach the sump, so wait a bit longer before taking a reading. Also, I'm not sure if you know this but make sure to ignore the first reading, wipe, try again, wipe and take another reading this will most accurate. Good luck and it sounds like your engine should be broken in just fine.
Gords_zenith is offline   Reply With Quote
The Following User Says Thank You to Gords_zenith For This Useful Post:
Weeber (12-08-2013)
Old 12-08-2013, 10:01 AM   #12
Mikem53
Drives: FR-S 6MT
As some have mentioned.. I wouldn't be too concerned about oil consumption on the factory fill. Give it some time. Keep an eye on it and check it often.
I was down about 3/4 of a quart when I changed it out at 4300 miles.. I've been running it hard after breakin too.. It will probably be fine..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Weeber (12-08-2013)
Old 12-08-2013, 10:11 AM   #13
Weeber
How many miles are you at now? Has it used significantly less?
Old 12-08-2013, 10:37 AM   #14
Mikem53
Drives: FR-S 6MT
I have about 700 miles on it since I changed the oil.. Haven't checked it since I changed it a few weeks ago.. Will check it and report back..
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 05:26 PM
2013 Scion FRS Engine, Transmisison, harness 9k miles! JoeDrifter Engine, Exhaust, Bolt-Ons 4 12-10-2013 10:08 AM
Car Dies at 170 Miles Check Engine Limp etc CASE CLOSED learnerspermit Issues | Warranty | Recalls / TSB 38 11-06-2013 03:51 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
Check engine light now on at 2995 miles Marshman Issues | Warranty | Recalls / TSB 2 12-17-2012 08:41 PM
