Old 12-05-2013, 01:27 PM   #15
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Good info, can't wait to see the section on fuel mods.
Ny Brz is offline
Old 12-05-2013, 09:31 PM   #16
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by troek View Post
does your new tuner kit that sells for 4199.99 still need to have a fitting welded into the oil pan?
The tuner kit is actually less we just didnt set the presets yet on it. But it will come with no base map of fueling from us. This will be for those interested in doing more on their own end.
FA20Club.com is offline
The Following User Says Thank You to FA20Club.com For This Useful Post:
troek (12-06-2013)
Old 12-05-2013, 10:45 PM   #17
Victor Draken
Drives: Toyota Gt86
Can you please give more information on spooling time of all the kits?
Victor Draken is offline
Old 12-05-2013, 11:15 PM   #18
FA20Club.com
W provided as much as we could to this point. The t3t4 all use the same turbine wheel so spool doesnt vary much just power out put.
Old 12-06-2013, 09:32 AM   #19
Ryan P
So what would it take in order to organize a 'dyno day' trip like your Houston trip to DC/MD/VA area. A shop w/dyno, obviously, 10 - 15 participants? Perhaps Element would be interested in hosting? Just feeling the idea out, I'm partial to in person tuning over e-tunes and South Florida is a hell of a drive from here haha.
Ryan P is offline
Old 12-06-2013, 11:28 AM   #20
Andy@FA20Club
Drives: FA20Club.com
Pm sent
Andy@FA20Club is offline
The Following User Says Thank You to Andy@FA20Club For This Useful Post:
Ryan P (12-06-2013)
Old 12-07-2013, 09:40 PM   #21
DeBiase
Drives: 2005 GMC Canyon
If you aren't going for top hp would that make the 57 trim better for either transmission being that it produces a bit more torque, such as a sub 400hp application? And I see that the boost response is only a few hundred RPM in difference but does the turbo size affect the rate at which RPM's rise? For example would a 60 trim get to 3500 RPM in the same amount of time that it would take the 50 trim? Thank you.
DeBiase is offline
Old 12-07-2013, 09:52 PM   #22
jamesm
the difference between various size (and design) turbos can't be quantified in such a straight forward way. it's far more subjective and it's all about feel. also tuning plays a huge part in how a turbo feels. suffice to say a 60-trim will feel less responsive than a 60-trim. whether or not that matters or if it is worth the trade-off is up to you.
jamesm is offline
Old 12-07-2013, 10:21 PM   #23
DeBiase
I meant all other variants held the same and it's a general question I guess I mean it more specifically does the compressor size affect how quickly the engine speed rises, everything else held constant, and the same if the only variable is the turbine size, would the RPM's rise at a different speed (sub boost as I know post boost it will vary). I am asking BC if boost response take a second longer in one turbo than another (or at any rate not consistent with the difference in engine speed variance ie 3600 response rpm vs 3800 response rpm) then wouldn't that render RPM speed as the benchmark for boost response as not-the-most precise way? I know tuning can make a world if difference. And I am just curious as I would personally go with the GTX30 series, I just like learning these things. And you meant a 60 trim is less responsive than a 50 trim correct? You said 60 twice.
DeBiase is offline
Old 12-07-2013, 10:23 PM   #24
DeBiase
I wish I had the resources to test my questions myself but I do not. Any tuner shops hiring
DeBiase is offline
Old 12-07-2013, 10:30 PM   #25
DeBiase
Not the most precise way of measuring the speed of boost response. Of course RPM's would still be used for so many other tuning reasons. I'm just relating it to measuring response times of the engine/performance.
DeBiase is offline
Old 12-07-2013, 10:31 PM   #26
jamesm
yes i did mean that, sorry for the confusion. basically, how fast engine rpms rise depends on how fast the car is accelerating, so if we're talking about off-boost then the only thing turbo-related that would effect that would be exhaust backpressure. so what we really want to know is does the size of a turbo effect off boost power, and if so how. i'm not sure of the answer to that.
jamesm is offline
The Following User Says Thank You to jamesm For This Useful Post:
DeBiase (12-07-2013)
Old 12-07-2013, 10:55 PM   #27
DeBiase
It was nice conversing with someone who can understand what I was trying to say. And I'm guessing that a turbo turbine with less back pressure would equal better power which would equal faster RPM climb. But yes your questions are spot on.
DeBiase is offline
Old 12-07-2013, 10:56 PM   #28
FA20Club.com
The 50 trim is going to be the largest variance in spool time of all the t3/t4 options. What you will see is minimal difference at lower boost levels. Once you actually start turning the boost up to about 10-12+ psi you start to see the spool time window widen vs what you would experience at lower moderate boost levels.
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
Scalzo's Turbo'd FRS Scalzo Member's Car Journals 139 02-06-2017 10:51 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Official New England random discussion thread! PRORICAN New England 503 07-24-2014 04:08 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
