Old 12-07-2013, 06:36 PM   #645
Tiremonkey0824
Drives: 2013 Argento 6mt
Just installed the OFT and have a question. When I originally installed my borla uel I used a spacer on my o2 sensor to avoid a CEl. Would I need to remove this spacer now that the vehicle is tuned?
Tiremonkey0824 is offline   Reply With Quote
Old 12-07-2013, 06:43 PM   #646
Rombinhood@OpenFlash
Drives: FRS
You shouldn't need to use any spacer with Vishnu's Stage 2 tune since it disables the catalyst inefficiency diagnostic routine in the ROM. But I don't see any harm in leaving it in there if you choose to.
Rombinhood@OpenFlash is offline   Reply With Quote
Old 12-07-2013, 06:50 PM   #647
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
Can I disable the tpms sensor light with this tablet?
Plxdjake89 is offline   Reply With Quote
Old 12-07-2013, 06:51 PM   #648
Drives: FRS
At this time, no.
Old 12-07-2013, 06:53 PM   #649
Plxdjake89
Plxdjake89's Avatar
Originally Posted by Rombinhood@OpenFlash View Post
At this time, no.
Damn! Hopefully in time
Just finished installing this right now, didn't realize the launch control feature was active right away, lovin it!
Haven't gone for a test drive but hope to soon
The Following User Says Thank You to Plxdjake89 For This Useful Post:
Rombinhood@OpenFlash (12-07-2013)
Old 12-07-2013, 08:36 PM   #650
Tiremonkey0824
Are you using the stage 2 map? For some reason my tune does not have the launch control feature. Either that or it is set really high and I haven't revved high enough to find it.
Old 12-07-2013, 10:43 PM   #651
Plxdjake89
Plxdjake89's Avatar
I'm using the stg1 map, I believe mine is set to 5500 or so, go try it out the sound is addicting lol
I'm curious on how we set that up :/
Old 12-07-2013, 11:07 PM   #652
Tiremonkey0824
Just tried 2 step and FFS and i can confirm that the stage 2 map does not have either of these. I guess the guys running the stage 2 map are going to have to set it up themselves using Tunerpro.
Old 12-07-2013, 11:31 PM   #653
Drives: FRS
The 2 step is indeed functional in the OTS maps. You can test this by free revving the engine in neutral with vehicle stopped. It will rev to 6000rpm and bounce rapidly.
FFS is not enabled in the OTS however because it doesn't make a good daily driving feature. You can enable it if you want to go drag racing though.
Old 12-08-2013, 12:03 AM   #654
Tiremonkey0824
Man that is set pretty high up there. I'll have to bring it down some for myself, i dont like breaking axles.
Old 12-08-2013, 12:31 AM   #655
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Is there a way to make the launch control only in effect when the clutch is pushed in? Right now I have launch control set at 4k, and I can't rev higher than that in neutral because of it. Obviously it's doing it's job, but some times I wanna rev the engine (testing new exhaust for example)
Old 12-08-2013, 01:36 AM   #656
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
From what I was told. The 2 conditions for launch control with the oft works is that the car is under 10mph and the clutch is pressed. So maybe if you just leave it in neutral and don't press the clutch. You should be able to rev past the limiter.
RC51ed is offline   Reply With Quote
Old 12-08-2013, 04:33 AM   #657
continuecrushing
I'll try again, but after installing my ARK exhaust the other day, I went to rev the engine and was greeted by the awesome 4k rpm setting I currently have set for my launch control! Foot was not on the clutch, from my recollection haha. I'll try again tomorrow.
Old 12-08-2013, 04:43 AM   #658
1086
1086's Avatar
Drives: UM86 - 6MT
Can the open flash tablet show horsepower and torque?
1086 is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
