Old 12-07-2013, 03:15 PM   #2857
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
Originally Posted by fenton View Post
That's awesome if your car has 190 HP on 91 octane that is quite the accomplishment congrats. Certainly one of the highest I have seen.
What did your car get for peak torque with those mods?
Sent from my HTC One using Tapatalk
I've seen several setup similar to mine here that goes everywhere from 181WHP to 189WHP.
I may have 180whp it is not impossible but if my car accelerate faster or equal to your car that have 210WHP on paper Houston we have a problem...
Like I said I do the 0-190KMH in about 22 seconds and on your video you are clearly doing it in 23 seconds. Even if I was driving your car and shifting faster than you I could save about 1 or 2 seconds only for the 0-190 run.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 12-07-2013, 03:21 PM   #2858
fenton
Like I said I do the 0-190KMH in about 22 seconds and on your video you are clearly doing it in 23 seconds. Even if I was driving your car and shifting faster then you I could save about 1 or 2 seconds only for the 0-190 run.
I'm not sure what to tell you then. Ive raced butang and he had full exhaust and stage 2 tune. It was destruction....
You will be faster with the esc that is for sure. Especially considering you are at sea level.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
NoFear99 (12-07-2013)
Old 12-07-2013, 03:59 PM   #2859
NoFear99
NoFear99's Avatar
Well for your defense, I spended about 3.5K to get there and your setup cost 2K and you have the same power level.
Old 12-07-2013, 04:15 PM   #2860
fenton
What people are really paying for is to go from 120 to 180 ft pound of torque in the dip. The 30 HP on the top end is the icing on the cake!
Old 12-07-2013, 04:57 PM   #2861
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
I just had to post a little piece on the arguament between 5.5 & 6.5 seconds in 0-60. Back a few years ago, I had a cute "Charlies Angels", Mustang II, 4.9L, V-8 4spd. manual car. It started at about 8.5 seconds in this run, and after a set of 1968 cylinder heads (9.7:1 vs 8.2:1), a compu. cam, matching 4bbl. Holley and intake, plus a dual exhaust system with a cross-over... It would do the 0-60 in around 6 seconds, unless you did a heat-up burn out first, then it would drop to the low 5 second range.
I have to gush a little over the FRS doing this kind of performance, with a 2.0L engine, and a few mods, or a mild amount of boost! This is phenomenal, and it sounds great doing it too! Now the Mustang also had torque. lots of it pushing around about 2700lbs, and that was a big part of what made it fun to drive. Peeling rubber off the line is always a nervous proposition, but rolling the tach out in a freeway merge, or dusting off a minivan to get to your lane, is much more like regular daily fun. Sounds to me like the ESC route is a pretty neat way to get there.
silent runner is offline   Reply With Quote
The Following User Says Thank You to silent runner For This Useful Post:
DAEMANO (12-07-2013)
Old 12-08-2013, 01:09 PM   #2862
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Quick question regarding launch control and having full boost while the valve is fluttering. How difficult would it be to wire in a switch to keep the charger from spooling while holding at the desired rpm and then just let go when you would launch?
bee_are_zee is offline   Reply With Quote
Old 12-08-2013, 02:07 PM   #2863
fenton
People have already talked about this a simple switch on the clutch would work.
Problem is unless you have better wider tires you will just spin to redline.... But I guess that's everyone's problem with more power.
Old 12-08-2013, 02:38 PM   #2864
fenton
Actually I just remembered something. Depending on the type of lc used you don't have to do anything. With brz edit I have a limiter set at 4500...I go to 85percent throttle (right before the sc switch engages). It bounces of that and I let the clutch out. As soon as I let the clutch out I go 100 percent throttle.
Remember 85 percent physical throttle is really 100 percent to the ecu.
bee_are_zee (12-08-2013)
Old 12-08-2013, 07:16 PM   #2865
bee_are_zee
Drives: GBS BRZ
Good point, I guess every time i'm messing around with the lc it's just foot to the floor. Nothing a simple leg recalibration cant fix.
Old 12-09-2013, 02:22 AM   #2866
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
when r they making this kit available?
a month? a few months? a year?
i need more power, im about to spend my money somewhere else if its not coming out anytime soon.
NYCsubaruBRZ is offline   Reply With Quote
Old 12-09-2013, 07:24 AM   #2867
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Good point. I'm surprised no one has asked this yet.
Old 12-09-2013, 07:34 AM   #2868
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
It's just a few months away.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 12-09-2013, 08:09 AM   #2869
bfrank1972
Drives: 2013 FR-S Argento
Lol
Sent from my iPad using Tapatalk - now Free
Old 12-09-2013, 09:03 AM   #2870
NYCsubaruBRZ
so a few months....
not 1
2 is a couple
3-4 months is a few?
5-6 months is not a few in my book
so 3-4 months?
im gonna say march 23 2014
lets talk price now.........
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
