Old 11-12-2013, 01:55 PM   #155
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
SORRY GUYS! Allen is right, we were all at SEMA. Just getting back into it this morning. Matt, you have a pm in your inbox.
Thanks!
Brian@Vortech is offline   Reply With Quote
Old 12-06-2013, 08:25 PM   #156
MATTrocity
Winter Is Coming
Drives: 2013 Scion FR-S Ultramarine
were the two screws for the valve supposed to be included?
MATTrocity is offline   Reply With Quote
Old 12-07-2013, 10:10 AM   #157
DJCarbine
Thupercharged
DJCarbine's Avatar
There should be 2 allen head bolts and a gasket
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 12-07-2013, 05:46 PM   #158
MATTrocity
Winter Is Coming
Definitely didn't include them
Old 12-07-2013, 07:00 PM   #159
DJCarbine
Thupercharged
DJCarbine's Avatar
Either you can request that they send them (you are in Hawaii.....) or go to the local hardware store to source some bolts. It might be easier just to source the bolts yourself and pay the 10 bucks IMO
2013 FRS
Vortech V3 11psi
Old 12-21-2013, 04:19 PM   #160
Frs32907
Drives: Asphalt grey, manual Fr-S
So i just installed the vortech full kit with the max blow off valve my shop did a minor adjustment because it was going off alittle early but im def not getting a nice sexy pssssh like in the video has anyone found the sweet spot for this bov
Frs32907 is offline   Reply With Quote
Old 09-05-2014, 05:50 AM   #161
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Bringing this thread back!
Can I request the BOV with a new kit, rather then forking over more $$$?
Carlitoz3 is offline   Reply With Quote
Old 02-05-2015, 09:10 AM   #162
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I'm gonna bump this since I'm curious... Has anyone else had any experience or want to share any impressions about this BOV?
Old 02-06-2015, 10:43 PM   #163
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
I went with Turbosmart 25mm, love it!
Jman1759 is offline   Reply With Quote
The Following User Says Thank You to Jman1759 For This Useful Post:
zoth (02-07-2015)
Old 12-07-2015, 01:38 PM   #164
sirsol66
Drives: 2013 FRS- Hot Lava
Cross posting and bumping an old thread, but I'm wondering if my fuel trim issues are due to the BOV. Anyone have logs of their car with of the OFT300+ this BOV that can share with me?
Setup:
Open Flash OFT300 package
Vortech supercharger (standard pulley)
Open Flash Header
Stock catback
Vortech Maxflow BOV
Logs: http://datazap.me/u/sirsol66hotmailc...data=1-2-10-11
Car is showing very very high fuel trims (25+) at idle and low RPM areas. Car is running completely fine but the trims are not settling. No knock at WOT pulls.
Exhaust has been leak checked and no issues. I will leak check the intake side this week.
One thing I noted is that the BOV is completely open at idle and moving A LOT of air. I never ran the normal vortech bypass valve so I am not sure how the maxflow compares with it. Can this be contributing to the high fuel trims?
sirsol66 is offline   Reply With Quote
Old 08-07-2018, 11:06 AM   #165
BRZ086
BRZ086's Avatar
Drives: 2012 BRZ Limited
Hi Guys
i Just installled my maxflow race bov and i need to get rid of that whistle sound.
Anyone managed to find sweet swot with the spring adjustments.
thanks
BRZ086 is offline   Reply With Quote
Old 08-07-2018, 02:44 PM   #166
toast
Drives: 14 BSP Edelbrock BRZ
Setup:
Open Flash Header
Stock catback
Vortech Maxflow BOV
I'm surprised your car will even run in this state. You need to adjust the spring with the threaded rod on top of the valve. It should not be open at idle. It should only open when it senses boost on one side (the side connected to the charge pipe) and vacuum on the other (nipple) side.
toast is offline   Reply With Quote
Old 08-07-2018, 05:29 PM   #167
Icecreamtruk
Drives: Track preped NA FRS
Holy necro batman.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Leonardo (08-07-2018)
Old 08-08-2018, 11:01 AM   #168
toast
Originally Posted by Icecreamtruk View Post
Holy necro batman.
Yeah I have a bad habit of not looking at dates. Once the thread came to the top I just figured it was recent
vortech pissing bov, wastegate option?
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 04:42 PM
Tial Q Blow off valve Gen Engine, Exhaust, Bolt-Ons 1 11-01-2013 09:34 PM
**Visconti Tuning Vortech ProCharger Spring Blow-Out Sale** Rich@ViscontiTuning Forced Induction 133 05-10-2013 02:31 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
