Old 11-29-2013, 09:03 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Ohlins R&T max amount of low (front)?
I've read lots on how they can go lower then the 20mm reccomend as per instructions but has anyone ever tested how much lower exactly? Backs is easy if you use Stance LCA or Raceseng or robispec extended hat mounts.
I realize these are NOT coilovers for slamming or real low I got that. But just trying to find out if a total of 35-50mm range lower then front is 100% possible?
Old 11-30-2013, 04:20 PM   #2
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
i think the absolute maximum is -35mm in the front and -30mm in the rear. i could be wrong though
FreshFRS is offline   Reply With Quote
Old 11-30-2013, 08:41 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
On my car:
Stock BRZ springs + stock wheels, ~665mm ground to top of fender (measured in straight line through center of wheel)
Ohlins + 245/35-18 Toyo Proxes T1 Sport, ~645mm ground to top of fender (same measurement), with about 5mm left of lowering left.
Total amount in the front you can lower is somewhere in the neighborhood of 25mm. 30mm max.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
FreshFRS (12-01-2013), OICU812 (12-01-2013)
Old 12-01-2013, 06:16 AM   #4
OICU812
Just a dude
OICU812's Avatar
Thanks again Alex just wanting to ensure on my setup ideas here. Appreciate that.
Old 12-06-2013, 05:08 PM   #5
mav1178
mav1178's Avatar
BTW I am in discussion with @Raceseng on their Cascam upper mounts. I will let you know what I find out, but it may be possible to get more front adjustment with their upper mounts.
-alex
Old 12-06-2013, 06:25 PM   #6
PRORICAN
PRORICAN's Avatar
-alex
Are you trying to see if they allow for more shock travel or lower the car? If so that'll be great cause I could use those for the Bilstein's I'm installing.
PRORICAN is offline   Reply With Quote
Old 12-06-2013, 06:28 PM   #7
mav1178
mav1178's Avatar
Sorry, it's ride height adjustment
As it stands, the Ohlins suspension won't allow more than 25mm of ride height adjustment. With the Raceseng upper mount, I may be able to get another 5-10mm depending on final upper perch design.
-alex
PRORICAN (12-06-2013)
Safe amount of boost on stock engine? Octane Forced Induction 51 12-06-2017 07:25 PM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
Lowest $ Amount Someone Has Thought You Paid For Your FR-S? DMDominator Scion FR-S / Toyota 86 GT86 General Forum 103 09-22-2013 08:57 PM
Safe/reliable amount of Hp range for BRZ Howardwei Forced Induction 74 07-29-2013 03:50 AM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
