Old 12-06-2013, 02:54 PM   #1
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Can't Get Into 2nd Gear (Just installed Kartboy, MTEC, Motul 300, and Whiteline)
Alright, my car is still up on the jacks, so I haven't driven it yet. But even before I cranked it, I could not get it into 2nd gear. Now that it's cranked, it's still not going into second.
I just installed: SPEC aluminum flywheel, Kartboy short shifter, Whiteline positive shift bushing, Perrin rear shifter bushing, MTEC Springs, and filled 'er up with some new Motul Gear 300 oil.
Everything seems great. Flywheel's chattering like a little punk ass kid, but that's to be expected. All shifts are super clean, mechanical, and snap into place with authority. But I cannot for the life of me get the shifter to even almost go into 2nd gear. It's like that whole direction is mechanically blocked off. Like the shifter is hitting solid metal.
Any ideas?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 12-06-2013, 02:57 PM   #2
pche
Guy on internet
Drives: Slowly
Would it go in second with the stock shifter? Hard to tell what went wrong because you had the whole tranny out so it could be anything.
pche is offline   Reply With Quote
Old 12-06-2013, 02:58 PM   #3
mad_sb
Drives: 2013 Asphalt FR-S
Any ideas?
Is the perrin bushing installed with the lettering facing the ground? Next thing i would check is the short throw install...
Old 12-06-2013, 02:58 PM   #4
FearBoy
Drives: 2013 BRZ Limited
Check the reverse lock out plate.
FearBoy is offline   Reply With Quote
The Following User Says Thank You to FearBoy For This Useful Post:
DAMotorsports (12-06-2013)
Old 12-06-2013, 03:02 PM   #5
Anthony
Weight Nazi
Anthony's Avatar
I know. I wouldn't normally install so many things at once, but I'm trying to get this together for a meet on Sunday.
Yes. That's how it goes, huh?
Is that the thing the four bolts go through that hold the shifter in place? If so, I thought the reverse lockout itself was hitting one of the bolt heads at first. Then I pulled up on the reverse lockout and it didn't change anything. I then shifted into all of the other gears while holding the lockout up, and confirmed it can go into those gears with the lockout being held up. But still won't go into second.
Old 12-06-2013, 03:04 PM   #6
Anthony
Weight Nazi
Anthony's Avatar
The short throw install seems to be the most probable suspect. It seems good though. As far as the shifter itself, you either install it right or completely backwards, which would be obvious. It's not in backwards.
Old 12-06-2013, 03:04 PM   #7
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
This ^^. Most likely the lockout plate is too far to the right. Loosen the bolts on the lockout plate with the motor off, and push the shifter as far left as you can without using the lockout ring and put it into second. Make sure the shifter will then slide right into 1st without hitting the edge of the gate. Tighten the bolts. Reassemble interior center console.
^GT5 Replay Photo Mode^
The Following 2 Users Say Thank You to SirBrass For This Useful Post:
Anthony (12-06-2013), DAMotorsports (12-06-2013)
Old 12-06-2013, 03:05 PM   #8
Anthony
Weight Nazi
Anthony's Avatar
Ah! Thank you, sir. Let me give that a try. Back in 5-10...
Old 12-06-2013, 03:05 PM   #9
Malt
Drives: 2015 WRX
Is your parking brake set? If so release it and try to shift into second.
Sent from my SCH-R970C using Tapatalk
Malt is offline   Reply With Quote
Old 12-06-2013, 03:06 PM   #10
SirBrass
SirBrass's Avatar
Why would having the parking brake set matter?
Old 12-06-2013, 03:07 PM   #11
raytrix
Drives: Series 10 FR-S
I suspect the short shifter portion of the install. I know for a fact that Motul 300 does make second gear a little harder to get into when the fluids is cold but should be butter smooth once it's warmed up. The fluid should noway completely lock you out of 2nd gear. This is most likely mechanical alignment of some sort.
raytrix is offline   Reply With Quote
Old 12-06-2013, 03:09 PM   #12
Malt
Drives: 2015 WRX
I've had something similar happen when I was putting my car up on stands. Something got bound up and prevented it from going into gear. Releasing the brake allowed it to go in. Worth trying as it will only take a few seconds.
Old 12-06-2013, 03:10 PM   #13
mkivsoopra
Yah this is most likely your issue. I just did my clutch and flywheel last weekend and ran into the same thing. What you think is first gear is actually reverse.
mkivsoopra is offline   Reply With Quote
Old 12-06-2013, 03:14 PM   #14
Anthony
Weight Nazi
Anthony's Avatar
Ok, I figured it out. Apparently, you can't slide the shifter all the way to the left and then down anymore. There's a tiny window between the void to the left of 2nd and 4th where 2nd actually exists. Before I could go all the way left, then straight down and it would go into 2nd. Now I just have to go exactly straight down from 1st and it goes right in. Not sure if that's normal or not. Seems like it'll make my driving a lot sloppier unless I'm more precise than I've always been.
I just played with the lockout plate, and it doesn't really affect the ability to get into second. I even tried sliding it as far to the right as possible to block out R, 1, and 2, but was still able to get into them. You've just got to be spot damn on to get into 2nd now.
Maybe it'll change as it breaks in? Or maybe once the car's on the ground and I'm actually shifting and accelerating under load it'll feel more natural. With the car as is though, it's like a game at the fair. No giant stuffed animals for me just yet...
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 03:02 PM
CounterSpace Garage || Jackson Racing Oil Cooler | Motul Engine Gear Oil Packages || CounterSpace Garage Engine, Exhaust, Bolt-Ons 41 07-08-2016 04:19 PM
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 226 01-19-2015 01:46 PM
No Motul Gear 300?? markmatley Hawaii 14 04-17-2013 08:59 PM
