Old 12-02-2013, 02:41 AM   #71
KayC
Drives: 2013 whiteout FRS 6mt
Just ordered these! Before I pulled the trigger, my top 3 choices were STs , RCEtarmac zeros, and these Bilstein PSS14. This is my DD with some occasional spirited back country cruises and occasional track use. Since they are priced so low on ft86speedfactory right now it's really hard to pass on them. Can't wait till I get them on!
KayC is offline
Old 12-02-2013, 03:12 AM   #72
coolaron
Are you installing it on your 9.5 width wheels?
Can you please let us know how it goes in terms of clearance?
Thank you!
Originally Posted by PRORICAN View Post
Ordered these last night, @FT-86 SpeedFactory has them priced pretty low right now for those of you interested! Can't wait to try them out!
coolaron is offline
Old 12-02-2013, 09:16 AM   #73
PRORICAN
PRORICAN's Avatar
Thank you!
Yup, after looking at them closely it looks like the spring perch is narrow enough to clear. The part that rubs on wide wheels is the wide stock spring perch and these are only wide after the first coil on the springs. I'll let you guys know for sure after installation.
PRORICAN is offline
Old 12-02-2013, 09:05 PM   #74
mid_life_crisis
Drives: FR-S 10 #103 AT
The Bilstein is a monotube with decent gas pressure so you get a little more response and more precise reaction from the dampers.
IMO the Bilstein will lend itself better to bigger bumps while the KW, ST, or our RCE T0 will be smoother on smaller bumps. That's generally the case with a good monotube vs. a good twintube. It's going to be good ride quality either way.
- Andy
Which is best on deep potholes? Seriously. I live near Raleigh, where potholes have to be deep enough to bottom out in before they'll fill them.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline
Old 12-02-2013, 10:59 PM   #75
MyEvilMonkeys
Drives: 2013 Scion FRS
Looking at the threaded adjustments there isn't a preload adjustment. Is this because even at its most conservative setting the spring needs to be compressed much like stock springs? Or because progressive springs or both? I don't want the clunking normally associated with lack of or incorrect preload. thanks for the clarification.
MyEvilMonkeys is offline
Old 12-02-2013, 11:52 PM   #76
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes the springs are progressive instead of linear like on most other coilovers. My drop is 1" lower (from factory height) and even though there is some preload on the springs at this setting I don't get any clunking whatsoever, ride is controlled and very well damped.
Clunking is normally associated with incorrect installation. All suspension systems generally have some amount of preload....even the stock suspension does. If you didn't have preload, the springs will become 'loose' when fully extended. Not really an issue unless you get airborne often.
Fizz is offline
Old 12-06-2013, 06:47 AM   #77
FR-S Matt
Are the new Bilstein B14's very similar to the Tarmac 0's? Springs look a bit bigger on the Bilstein's. I was curious to how they ride on the street while lowered. I'm on the last thread on the front of my 0's and all I get is that long bump travel over small "hill-like" bumps. Otherwise a very smooth ride.
FR-S Matt is offline
Old 12-06-2013, 07:41 AM   #78
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Interested to hear your thoughts on these.
OICU812 is offline
Old 12-06-2013, 09:16 AM   #79
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
I'm also interested in how these fit on your wheel setup. When do you plan on installing?
Anomie is offline
Old 12-06-2013, 10:52 AM   #80
PRORICAN
PRORICAN's Avatar
Should be coming in today so I'll have them on this weekend! I'll let you guys know what I think soon after.
PRORICAN is offline
The Following User Says Thank You to PRORICAN For This Useful Post:
OICU812 (12-06-2013)
Old 12-06-2013, 11:08 AM   #81
RYU
RYU's Avatar
Drives: really slow...
Give it about a week of driving so they can settle in. Interested to hear your thoughts!
RYU is offline
The Following User Says Thank You to RYU For This Useful Post:
PRORICAN (12-06-2013)
Old 12-06-2013, 06:48 PM   #82
PRORICAN
PRORICAN's Avatar
Didn't get my Bilstein's today . It required a signature and my wife and I were stuck working so now I have to wait until Monday for either a second delivery attempt or pick up at their customer center. I thought ups delivered on Saturdays but I guess not.
PRORICAN is offline
Old 12-09-2013, 10:48 AM   #83
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
@FT-86 SpeedFactory or anyone else; how do these compare with the RCE Tarmac Zeros, besides the linear vs. progressive springs?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline
Old 12-10-2013, 12:48 PM   #84
Krispeee
Looking at a set of B14s to purchase, so a review on how they perform would be great. Subscribed!
Krispeee is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
