#71 |
Drives: 2013 whiteout FRS 6mt
Just ordered these! Before I pulled the trigger, my top 3 choices were STs , RCEtarmac zeros, and these Bilstein PSS14. This is my DD with some occasional spirited back country cruises and occasional track use. Since they are priced so low on ft86speedfactory right now it's really hard to pass on them. Can't wait till I get them on!
#72 | |
Are you installing it on your 9.5 width wheels?
Can you please let us know how it goes in terms of clearance? Thank you! Quote:
#73 |
Yup, after looking at them closely it looks like the spring perch is narrow enough to clear. The part that rubs on wide wheels is the wide stock spring perch and these are only wide after the first coil on the springs. I'll let you guys know for sure after installation.
BeastCoast.US feature http://beastcoast.us/2013/11/28/all-the-right-moves/
Build Thread http://www.ft86club.com/forums/showthread.php?t=8204 ![]() |
#74 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#75 |
Drives: 2013 Scion FRS
Looking at the threaded adjustments there isn't a preload adjustment. Is this because even at its most conservative setting the spring needs to be compressed much like stock springs? Or because progressive springs or both? I don't want the clunking normally associated with lack of or incorrect preload. thanks for the clarification.
#76 |
Senior Addict
Drives: 86 GT
Yes the springs are progressive instead of linear like on most other coilovers. My drop is 1" lower (from factory height) and even though there is some preload on the springs at this setting I don't get any clunking whatsoever, ride is controlled and very well damped.
Clunking is normally associated with incorrect installation. All suspension systems generally have some amount of preload....even the stock suspension does. If you didn't have preload, the springs will become 'loose' when fully extended. Not really an issue unless you get airborne often. |
#77 |
Are the new Bilstein B14's very similar to the Tarmac 0's? Springs look a bit bigger on the Bilstein's. I was curious to how they ride on the street while lowered. I'm on the last thread on the front of my 0's and all I get is that long bump travel over small "hill-like" bumps. Otherwise a very smooth ride.
#78 | |
Just a dude
Drives: Scion FR-S 2013
#79 | |
Drives: 2014 BRZ Limited
#80 |
Should be coming in today so I'll have them on this weekend! I'll let you guys know what I think soon after.
| The Following User Says Thank You to PRORICAN For This Useful Post: | OICU812 (12-06-2013) |
#82 |
Didn't get my Bilstein's today
. It required a signature and my wife and I were stuck working so now I have to wait until Monday for either a second delivery attempt or pick up at their customer center. I thought ups delivered on Saturdays but I guess not.
#83 |
Drives: 2013 SWP BRZ
@FT-86 SpeedFactory or anyone else; how do these compare with the RCE Tarmac Zeros, besides the linear vs. progressive springs?
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#84 |
Looking at a set of B14s to purchase, so a review on how they perform would be great. Subscribed!
| Bilstein Damptronic pics. | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 202 | 10-08-2014 08:13 PM |
| Anyone ETA on Bilstein coilovers? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 01-31-2014 11:26 AM |
| Bilstein Damptronic on an FRS | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-10-2013 12:15 AM |
| All Bilstein and Muteki 10% off during month of July! | Infamous Performance | Brakes, Suspension, Chassis | 24 | 07-31-2013 01:52 PM |
| Bilstein Shocks | wahsaihin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-23-2013 03:12 PM |
