Old 11-05-2013, 02:54 PM   #15
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
looks like i need to get one soon.
Old 12-05-2013, 02:46 PM   #16
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Is it necessary to jack the car up to remove the strut tower bracing? I would assume that that at rest there is some tension placed on the brace, making jacking up a safer situation (for both car and person working on it). I am just curious though. Also, if there is not a DIY for intalling on an auto, i'll do a write up once I get my car back.
Turkish is offline   Reply With Quote
Old 12-05-2013, 08:00 PM   #17
White64Goat
Can the brace be installed without removing the tower to firewall brace? I assume it was only removed for better pictures?
Old 12-05-2013, 08:25 PM   #18
modena
modena's Avatar
Drives: BRZ Limited WRB MT
You can install it without removing the brace.
That said, removing it, (just a couple of bolts), gives you a little bit more room to install the brace...
So no, no need to remove it if you don't want to.
modena is offline   Reply With Quote
The Following User Says Thank You to modena For This Useful Post:
amram (03-28-2014)
Old 12-05-2013, 08:37 PM   #19
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
It was super easy for me to install with out removing the brace as well. All I needed was an extension for my rachet. Takes maybe 5min to install.
FRSfan111 is offline   Reply With Quote
Old 12-06-2013, 02:36 AM   #20
mfbmike
Drives: 2013 FRS, 2008 R32
Sweet. Received mine a few days ago. Anxious to get it installed.
mfbmike is offline   Reply With Quote
Old 12-06-2013, 10:30 PM   #21
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
You will be just fine removing the strut tower bracing without jacking up the car. Nothing to worry about! Just be careful not to torque them down too tight when re-installing. The factory torque spec is only 12ft-lb!
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
amram (03-28-2014), Turkish (12-06-2013)
Old 12-06-2013, 10:54 PM   #22
White64Goat
Old 03-28-2014, 04:40 PM   #23
amram
amram's Avatar
Drives: 2013 FR-S AT
Great write-up as always F1point4! Thank You!
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
amram is offline   Reply With Quote
Old 03-29-2014, 05:11 AM   #24
RacerX
Drives: Subaru BRZ
Does the MSB make a difference in daily driving? Or is it only noticeable in high performance situations?
RacerX is offline   Reply With Quote
Old 03-29-2014, 07:47 AM   #25
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Makes a noticeable difference in daily driving as well. The brake pedal just feels firmer period. I love it.
malave7567 is offline   Reply With Quote
Old 06-20-2014, 01:23 PM   #26
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Does the strut tower and/or firewall not flex enough under hard driving or over bumps/a pothole/or driveway curb/speed bump/etc to cause damage at some point by having an object pushing on the firewall from teh strut tower?
I'm throwing it out there because I don't know if strut tower doesn't move at all, ever, or if it does.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following User Says Thank You to sluflyer06 For This Useful Post:
Tristor (02-22-2018)
Old 06-20-2014, 04:24 PM   #27
CoupedUpSubie
Drives: 2013 BRZ Limited
If the strut tower was moving enough to cause damage to the firewall from using a master cylinder brace then there would be damage to the braces that run to the center of the firewall. Just don't put a ton of pressure on the master cylinder and you will be fine. It took very little pressure to make a difference.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
Old 05-28-2018, 03:35 PM   #28
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Does anyone know what the bracket for the AT wire harness is called? I lost it and need to get another.
-EDIT- Got it I think! Part SU003-02205 Bracket for ATM
V_86 is offline   Reply With Quote
brakes, diy, grimmspeed, master cylinder brace, stopper
Cusco FSB with master cylinder brace - A heads up for AT owners CircuitJerk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 03-15-2014 07:25 AM
Master Cylinder Brace Development - Any Interest? GrimmSpeed Brakes, Suspension, Chassis 411 05-14-2013 05:04 PM
