Old 09-21-2012, 12:08 AM   #1
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Cusco FSB with master cylinder brace - A heads up for AT owners
FYI
Got my Cusco front strut bar with the Master Cylinder brace today and upon installation found that the MC side requires removing a wiring harness clip and bracket and relocating a small harness.
I basically had to shove it underneath the MC piston chamber and zip tie it for now until I can come up with a better way. I probably should have just left it floating which I may do. I don't think it would do any real harm, I just didn't like the idea of it resting on the brake lines.
I can't imagine it's going to be any different for the BRZ.
I apologize if this has been covered previously. I did do a cursory search.
A top view of the clip and bracket.
Moving the harness under the master cylinder piston chamber.
Here you can see, even after relocating the harness, the strut mount/MC brace will not sit flat without removing that little metal bracket.
*UPDATE*: As requested, I took some photo's of how/where I located the wiring harness for the AT. It ain't pretty, but it works.
Last edited by CircuitJerk; 03-14-2014 at 09:43 PM. Reason: I can't grammar. I have the dumb...
CircuitJerk is offline   Reply With Quote
Old 09-21-2012, 12:19 AM   #2
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Thanks for the post. Mine arrived today, with the catch can... I went to install it then i remembered i left my socket set at my buddies house from when i was tearing down a yaris... FFFFFFffffffffffff lol.
Ravenlokk is offline   Reply With Quote
Old 09-21-2012, 12:29 AM   #3
schtebie
Drives: CBS BRZ Limited
Hmm, there doesn't seem to be any mention of having to relocate anything on the BRZ...
[ame="http://www.youtube.com/watch?v=zOAF2i5OWLo"]Cusco Strut Tower Bars - Unboxing, Install and Review - 2013 Subaru BRZ | Scion FR-S | Toyota 86 - YouTube[/ame]
schtebie is offline   Reply With Quote
Old 09-21-2012, 12:34 AM   #4
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I have the same bar with MC on my BRZ. No issues as mentioned above.
Sent from my GT-I9300 using Tapatalk 2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 09-21-2012, 12:43 AM   #5
CircuitJerk
Pull my finger...
The plot thickens....
Old 09-21-2012, 12:44 AM   #6
CircuitJerk
Pull my finger...
Is that wiring harness even present on the BRZ?
Ohh ghaaawd I hope this doesn't result in a derp moment....
Old 09-21-2012, 01:29 AM   #7
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
That is odd. On ours we had no issues at all.
Let us know if you have any questions.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-21-2012, 01:31 AM   #8
RallySport Direct
I'm guessing it does not. Never noticed that before..
Hope it's an easy fix for you though
Thanks,
Rick
Old 09-21-2012, 01:39 AM   #9
CircuitJerk
Pull my finger...
Yeah it only delayed the install like 10 minutes.
I need to identify what it is.
It may have something to do with the automatic trans.
Old 09-21-2012, 01:52 AM   #10
msile
msile's Avatar
Drives: ISF
I installed it in my FRS (6MT) and no issues. Like you said perhaps it is on auto.
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 09-21-2012, 02:00 AM   #11
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Mine is one the way and I have an AT. I hope there won't be any surprises. BTW, did you guys have to cut anything for the rear bar?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 09-21-2012, 02:13 AM   #12
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
i believe you do have to cut your trunk mat a bit
Old 09-21-2012, 02:41 AM   #13
zoomzoomers
I have a BRZ AT and there is a bracket and line that, indeed, needs to be moved/relocated, but from what I can see it doesn't seem to be too bad. I can probably use some zip ties to get it out of the way, but it does seem that the bracket has to be removed.
I guess most tuners just don't test their gear for AT's.
Old 09-21-2012, 06:14 AM   #14
CircuitJerk
Pull my finger...
Okay, then it's settled. Must be for the AT trans.
Yeah, it was no big deal.
It was a WTF moment, and then it took all of a few minutes to test the possibilities, take a few pics and move on.
TRD brace set, or Cusco? TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 01-12-2016 11:58 AM
Master Cylinder Brace Development - Any Interest? GrimmSpeed Brakes, Suspension, Chassis 411 05-14-2013 05:04 PM
Group Buy - Cusco transmission mount + Beat Rush master brake cylinder stopper Nardi330 Australia Classifieds 74 10-28-2012 01:08 AM
OptionJDM - Cusco Chassis Brace OptionJDM Brakes, Suspension, Chassis 6 07-25-2012 01:01 AM
