Old 12-05-2013, 08:30 AM   #43
s2d4
s2d4's Avatar
Originally Posted by Suberman View Post
So, how much extra power is produced and at what temperature does this imaginary power show up?
This would be why your fuel economy improves in winter. Not.
@Fast_Freddy, you guys would get along like a house on fire.
Old 12-05-2013, 08:34 AM   #44
n2oinferno
Praise Helix!
n2oinferno's Avatar
The Following User Says Thank You to n2oinferno For This Useful Post:
trekkie (12-05-2013)
Old 12-05-2013, 11:52 AM   #45
For our highly tuned engines cold intake air can make no discernible difference in power output. I am happy for anyone to show this to be wrong by dyno or other means: increase in too speed observed or quicker acceleration times.
So, Suberman, are you saying that an aftermarket CAI for the FR-S/BRZ is a waste of money .. ??
Old 12-10-2013, 10:44 PM   #46
SpeedR
First86 / boat thief
Drives: MKIV Supra
If cooler air dose not mater whats the point of an intercooler?
I am sorry but you appear to have no idea what your talking about.
SpeedR is offline   Reply With Quote
The Following 2 Users Say Thank You to SpeedR For This Useful Post:
Mikem53 (12-12-2013), Rayme (12-11-2013)
Old 12-11-2013, 10:46 AM   #47
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It makes more power. All engines make more power with colder air as the computer dumps more fuel to keep the air fuel ratio.
Rayme is offline   Reply With Quote
Old 12-11-2013, 11:13 AM   #48
ZDan
ZDan's Avatar
Drives: '23 BRZ
There are a few reasons why cars get worse mileage in the winter, one being winter fuel formulations having less energy content, another being that colder/denser air creates more aerodynamic drag.
Another secondary effect is that since colder air *does* give more power, then at a given cruise speed, you'll have a smaller throttle opening to make the same power. This gives greater losses as the engine has to do a tiny bit more work to draw the air past the smaller throttle opening.
Believe it or not, there is a HOT air intake mod for mid-90s Honda VX cars that improves fuel efficiency for this reason (wider throttle opening required for a given speed/power setting)!
That said, I would guess that most CAI mods for this car won't necessarily improve performance much, if at all. That has been the case with a lot of S2000 intake mods...
Suberman (12-11-2013)
Old 12-11-2013, 05:43 PM   #49
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Good lord, isn't basic chemistry a requirement for high school graduation? Questions like the OP's make we weep.
Old 12-11-2013, 06:10 PM   #50
Suberman
Drives: Subaru BRZ Sport Tech Satin White
The intercooler cools the intake charge after it has been compressed by the supercharger. That's why. I do know what I'm talking about. You apparently do not. But now you know a little more than you did before.
Suberman is offline   Reply With Quote
Old 12-11-2013, 06:12 PM   #51
Suberman
Well, it would be simple if stochiometric ratio is all that was at play here but because the engine controls are now very sophisticated that isn't all that's involved.
Zdan's covered all the bases I think. His post is the most useful answer in this thread. That's just IMHO of course.
The Following User Says Thank You to Suberman For This Useful Post:
WolfpackS2k (12-12-2013)
Old 12-11-2013, 06:16 PM   #52
Suberman
Well, no, see that's the point. That's the easy answer and probably incorrect if the bmep is limited by a knock sensor system.
It's torque that matters, bmep at its highest level. Power is just a multiple of bmep. Mind you, bmep is a calculated number but it represents real force.
If colder air results in more fuel being added then superficially higher bmep should result. However, the engine can't take more bmep than the detonation limit allows. Since the knock sensor operates at peak bmep already and at all temperatures then colder air can't make more power. The ECU retards ignition (or reduces boost) so the supposed more powerful air fuel mixture develops exactly the same bmep as the thinner air fuel mixture at higher temperatures.
It seems simple to figure out but it actually gets quite complicated.
Old 12-11-2013, 06:18 PM   #53
Suberman
Yes I am. The only economically sensible power modification to make to this engine is supercharging. Because of fuel economy considerations factory engine builders just don't leave free hp on the table any longer. An extra 4 or 5 hp at peak rpm just isn't relevant, assuming that's what these CAI actually achieve, which is doubtful. You never use that "extra" power. "Free flow" exhausts aren't worth the money either for similar reasons although at least you might get useable improvement in peak torque from one of those, but only with a lot more noise.
I don't think the chassis design will be able to use much extra torque without considerable driving skills.
At a minimum I'd also fit much better tires and an easily adjustable rear roll bar. Of course you'd need to know how to adjust that roll bar so were back to driving skills again. Fun car but tricky handling.
humfrz (12-11-2013)
Old 12-11-2013, 09:39 PM   #54
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Say it in simpler terms, are you saying the ecu pulls timing when it sucks in colder air? Are you saying the ecu doesn't use the colder air charge to extract more power out of it?
It sounds like if you are saying is true, the opposite also should be, the warmer the air intake, the more ignition timing it advances then, right?
EDIT:
You know what, fuck it, you're just a troll on here. You go one about the car's handling again (which seems to be the only thing coming out of your mouth) in this thread which has nothing to do with making more power in colder weather anyway.
Old 12-11-2013, 11:18 PM   #55
SpeedR
Drives: MKIV Supra
And why would you bother if colder air dose not make more power?
and now were done troll
Old 12-11-2013, 11:23 PM   #56
1086
1086's Avatar
Drives: UM86 - 6MT
/thread
/thread
/thread
/thread
/thread
did it work yet?
1086 is offline   Reply With Quote
TPMS IN COLD WEATHER Scionshaun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 11-20-2016 06:27 AM
Power window fault in cold weather Suberman Issues | Warranty | Recalls / TSB 5 01-09-2014 09:24 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
This car really hates the cold weather Craig Issues | Warranty | Recalls / TSB 55 01-28-2013 06:42 PM
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 09:32 AM
