#2829 |
Drives: Subaru BRZ
How do I tell which controller I have?
#2830 |
The 5kw is about 50 percent bigger. Its more square looking. It has more expensive electronics in it and different programming to handle the additional load. I believe DR is also more sensitive... I actually had to turn mine down initially.
It will look like this: Sent from my HTC One using Tapatalk |
#2831 |
Drives: Subaru BRZ
I must have the older controller. Has one heat sink and a fan.
#2832 |
She said member
Drives: fr-s firestorm
Count me in when it releases! Already have header, tune, and just did E85 swap today!
In reading over the last few days... ● someone said launch control and flat foot shift would cause problems, another pedal switch in series at top of clutch pedal will fix that, maybe we could tap into the original clutch switch? ● if batteries are mounted in trunk, how heavy gauge wire is needed for the 24v battery? Can both battery packs (12v and 24v) use common chassis ground? ● I believe the control box would be best placed in front of the radiator as high as possible |
#2833 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Did someone on here say they had an odyssey battery with the system?
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#2834 |
Drives: Subaru BRZ
I have an Odyssey PC 925 battery for the starter.
#2835 | ||
Drives: WR Blue BRZ, 240Z
This has been discussed and I believe Rob supports the idea of this location. The down-side is that you have to remove the bumper cover to gain access. If you're comfortable doing that you should be good to go.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
| The Following User Says Thank You to Gary in NJ For This Useful Post: | Robftss (12-06-2013) |
#2836 |
She said member
With a second switch (in series with WOT switch) mounted at top of clutch pedal travel, it would deactivate compressor as soon as you press the clutch.
#2837 |
I don't see a down-side to this approach.
#2838 | |
She said member
lesser of 2 evils: add ~15 lbs to the already heavy front end OR drop ~25 lbs from the heavy front end and add ~50 lbs to the light rear end |
#2839 |
How do you like it? On the cold starts for e85 its already starting to take 2 starts before the car rumbles to life. Little worried about the little battery if I have to do 5 starts in a row. What was the cost?
#2840 |
Drives: 2013 FR-S Argento
Yet another great aspect to this rig - the overall setup is so simple, you can probably customize it how you like (though I'm sure at that point whatever warranty Rob provides may well be null and void).
#2841 | |
http://www.atbatt.com/ps-12350.asp This is also a Power-Sonic 12V SLA battery with NB terminals but this one is a 35ah battery vs. the 21ah of the PSH-12180FR. While I don't really need the extra starting power, I do have concerns with parasite losses while parking the car at an airport for a weak. This battery fits a little better with the boost batteries (closer in size) and is half the price of the Odyssey PC 925 and has about the same output.
| The Following User Says Thank You to Gary in NJ For This Useful Post: | Sojhinn (12-05-2013) |
#2842 | |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
