Old 12-04-2013, 08:16 PM   #15
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Thanks for the link to the log file web page. Saves me doing my own spreadsheet!
FRSFirestorm is offline   Reply With Quote
Old 12-04-2013, 10:41 PM   #16
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Just did some little logging on my end
http://datazap.me/u/burn/normal-driv...?1-2-7-9-11-12
Burn is offline   Reply With Quote
Old 12-04-2013, 10:45 PM   #17
Rombinhood@OpenFlash
Drives: FRS
There is never a need to make your own spreadsheet. In addition to datazap (which requires internet connection to view logs), Vishnu has their own datalog viewing software which can be downloaded from their website
Rombinhood@OpenFlash is offline   Reply With Quote
Old 12-04-2013, 10:49 PM   #18
Drives: FRS
I didn't see any full throttle runs captured in the log. Only partial throttle which don't give too much info I'm afraid. Also, what ROM type do you have? I'm guessing it's international since Advance Multiplier isn't logging properly yet (displaying 0). That logging channel only seems to work USDM ECUs at this time. It's something we are working on at this time. But you can pretty much figure out your real Adv Mult by looking at your knock correction values. If they are the same that you see in the Ignition Advance table, your Adv Mult is 1.0 which it looks to be
Old 12-04-2013, 11:10 PM   #19
Burn
Slack Bum
Burn's Avatar
Drives: FT86
I didn't have much chance to do full throttle on street roads and I'm currently on stage 2 1.34B with EU ROM ZA1J700G.. Will try to do full throttle logging soon. Overall I'm quite pleased with the improvements from 1.34B with my rev is much more smoother and linear. Not as rough and edgy as before.
Old 12-05-2013, 02:03 AM   #20
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi!
You just told that Ignition Advance and KC learned values suppose to be the same (!?) in order to have Adv Mult considered as 1.0 - that makes me
confused a bit. I have G-series ROM too, but it reads different values
of Ignition advance and KC learned values - like IA = 27 and KC = 3.88 or
IA = 28 and KC = 5 at the same time of the pull:
http://datazap.me/u/ondreiko/3-4-5-gear-pull-wot?1-7-8
please kindly explain should i consider these values as the same or did you mean just the graphs suppose to change the same way on the different values of the each scale?
Thank you in advance.
Ondreiko is offline   Reply With Quote
Old 12-05-2013, 02:09 AM   #21
Drives: FRS
Originally Posted by Ondreiko View Post
Hi!
I think you may be confusing the Ignition (Base) table with the Ignition Advance table. The latter is what you will see perfectly reflected in Knock Correction values with Adv Mult is 1.0.
In summary, Ignition Advance value (in the data logs) is going to be equal to the value in the Ignition (base) table + (value in Ignition Adv table)*Adv Mult + various temp compensations/corrections.
The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post:
akyp (12-05-2013)
Old 12-05-2013, 03:09 AM   #22
Indestruct
Drives: 2013 SWP Limited BRZ, MT
Originally Posted by Tromatic View Post
Vishnu needs their own forum.
Seriously! How hard is it to add a forum to their procedeturning website... not that hard at all! That way they won't get banned for being better than the competitors w/more $$$.
Indestruct is offline   Reply With Quote
Old 12-05-2013, 08:11 AM   #23
vgi
Drives: frs
here's a bit more detailed explanation. while looking through the doc keep in mind that our engine in na so our afr should be what vishnu said at 12-12.5
https://sites.google.com/site/asubie...edirects=0&d=1
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
s2d4 (12-05-2013)
Old 12-05-2013, 03:33 PM   #24
Ondreiko
RWD addicted
Ondreiko's Avatar
My AFR always shows 11.25 at WOT pull. 1.34B Stage 1 OTS.
What suppose to be wrong there - software, hardware or fuel?
Old 12-05-2013, 05:25 PM   #25
jeebus
Running a bit on the rich side...what is the octane of the fuel in Moscow? Also, how friggen cold is it?
jeebus is offline   Reply With Quote
Old 12-05-2013, 05:35 PM   #26
Drives: FRS
Most likely a difference in fuel formulation. Stock intake/MAF housing?
Old 12-05-2013, 05:37 PM   #27
Drives: FRS
...and the first bit of this video shows a good example the kind of runs you want to capture in an OFT datalog:
[ame]http://youtu.be/V-v3VK9Lgl8[/ame]
Basically, a few 3rd gear full throttle runs from low rpm to max revs (~1500rpm to 7600rpm).
normancw (12-07-2013)
Old 12-05-2013, 06:53 PM   #28
jeebus
great post!
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Now Available: OpenFlash Datalog Viewer and DataZap! Shiv@Openflash Software Tuning 36 12-31-2014 05:59 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
