Old 08-03-2012, 02:25 PM   #15
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Well, it turns out I'm not going to go through the trouble of hardwiring my Escort. The package with the kit came today, but when I went searching for the fuse panel (which I never found) I found a 12v power plug hiding at the back of the glove box! I'm going to use the stock power cord for now and return the hardwire kit to Amazon. Pics in my journal.
Now after re-reading the OP I should have known there was a power source in the glove box!!!
Old 12-04-2013, 05:51 PM   #16
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
where did you get the cable, and does it works to put into the 12V power outlet in the glove box? are you able to close the glove box?
Old 12-04-2013, 05:59 PM   #17
TM
TM's Avatar
Drives: DGM BRZ 6MT
I have an Escort Passport 8500 with a short phone cord power cable with cigarette lighter power adapter. It not work well in my BRZ if at all. Since I don't have homelink to tap into a power source by the mirror, I've just ordered this: http://amzn.com/B0003NN83U
Hopefully it will do the job
I don't have a homelink mirror either, but I still used an invisicord and wired it to the unused mirror connector above the dome lights.
I just like the idea of having an extra power outlet available in case I need it.
TM is offline   Reply With Quote
Old 12-04-2013, 06:11 PM   #18
ATL BRZ
ATL BRZ's Avatar
http://amzn.com/B006G1PHLY
Works fine in the glove box outlet
Old 12-04-2013, 06:14 PM   #19
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
that is fast response..
thank you man.
I will order it and try. I just got the Escort 8500 X50 last weekend, and really don't like the wire hanging in the center between the seats.
@ATL BRZ are you able to close the glove box after the direct cord is installed into the 12V outlet?
Old 12-04-2013, 07:42 PM   #20
ATL BRZ
ATL BRZ's Avatar
thank you man.
Yes it closes fine, just keep the excess cord tucked away.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Lverasky (12-05-2013)
Old 12-05-2013, 08:16 AM   #21
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Why wouldn't you just hard wire it ? use the smart cord. It's a very simple task... the smart cord comes with T taps and you can tap into the 12v in the center console. Wiring thru the headliner or front dash is simple as you just need to stuff it in there.
86-tundra is offline   Reply With Quote
Old 12-05-2013, 11:08 AM   #22
subwaynm
subwaynm's Avatar
Drives: Scion FR-S Coupe
Originally Posted by rikdrt1 View Post
i got you a much better idea -- get the SOLO S3 -- wireless and the battery lasts for weeks (2AA) -- great unit also and very decent reviews - and the best deal you can put it anywhere since no cables !
Thanks I like this suggestion and on Amazon it gets good reviews.
subwaynm is offline   Reply With Quote
Old 12-05-2013, 11:16 AM   #23
utekineir
blowhard
Drives: frs, project forester
I've run a hardwired smart cord from fuse box snaked up a pillar and over and the 12v plug from valentine 1 in glove box outlet snaked up and over.
Both were fantastic.
utekineir is offline   Reply With Quote
Old 12-05-2013, 06:43 PM   #24
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
So who has experience running detectors in VA?
I know this was a post from July but the guy I bought my STI from (years ago) was in VA and he had his V1 under a hat (mounted in foam) sitting at the bottom of the rear windshield. He had the power cable running all the way from the 12v cig lighter in the front. He also had pins holding the hat down.
Said he had a state trooper stop him once and search his car (because he slammed on his brakes the trooper said he had probably cause to search for a detector) and never found it. I guess he unplugged it and pocketed the 12v plug before the trooper made it to his window.
As far as the rest of the thread goes: I run a blend mount with invisicord wired into my autodim mirror. No Issues. Same V1 from the above story
EvilBeaverFace is offline   Reply With Quote
Old 02-06-2014, 12:39 PM   #25
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
This is old, but for anyone else who is struggling to find a CLA adapter to a RJ11 cable. You can always use the original radar power cable plugged in the glove > RJ11 coupler > long phone cable > radar.
mmmcambelsoup is offline   Reply With Quote
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 02:48 PM
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 12:01 AM
What radar/laser detectors do you use? sa1126 Electronics | Audio | NAV | Infotainment 131 12-16-2013 09:39 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
