Old 11-27-2013, 09:17 AM   #29
makinen
makinen's Avatar
Drives: Toyota 86
Hello,
I have lower spec brakes also.
With EBC yellow-stuff front and rear pads, whole track event in hot summer day wasn't a problem.
But I have good, cheep and effective cooling aids there .
Actually I've prepared to upgrade to the upper spec because the front caliper difference is only its bracket (the thing between knuckle and caliper). But current setup is so well with 205/55R16 BS RE01R so I've postponed at least until front discs broken.
@troek may want to know about the bracket. Just try to get second hand Legacy/Forester calipers with discs. It will just fit.
Regards,
Hanjo
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
troek (01-12-2014)
Old 11-27-2013, 10:17 AM   #30
troek
troek's Avatar
Drives: 2012 Toyota 86
Yeah I looked into it. It's the same as elsewhere. When I heard bracket I thought of something u use to adapt a 4 pot or something. I considered what is being called the bracket as part of the caliper. I'm not use to this style calipers. When my rotors go ill upgrade probably.
troek is offline   Reply With Quote
Old 12-03-2013, 03:14 AM   #31
yenvy4
Drives: GT86
From my understanding the calipers are the same between the GTS and GT so will GTS sized rotors fit on GT base model?
yenvy4 is offline   Reply With Quote
Old 12-03-2013, 07:50 PM   #32
TRD GT
Drives: Toyota 86 GT
I cooked my lower spec brakes with TRD front pads in a couple of laps of my local track....What type of pads would people recommend for tracks that are notoriously hard on brakes?
I would like to reduce my stopping distance, but more importantly at this stage, I would like to stop overheating them, so I actually have SOME brakes!
TRD GT is offline   Reply With Quote
Old 12-04-2013, 02:52 AM   #33
troek
troek's Avatar
i run trd pads on the lower spec brakes with brake ducts and have had no pad problems. are you sure its not the fluid boiling? ive boiled fluid from time to time but pads are ok. the project Mu hc 800 will be my next pad though as my friend has such good look with them on his gt-r.
Old 12-04-2013, 09:01 AM   #34
350matt
Drives: toyota mr2/ Toyota GT86
So just ot confirm the front brakes off a WRX will fit a GT86 / FRS?
As I can get a good price for a WRX big brake kit
350matt is offline   Reply With Quote
Old 12-04-2013, 09:04 AM   #35
makinen
makinen's Avatar
Drives: Toyota 86
Rotors can be used.
But you should use GTS caliper bracket(supporting plate or whatever it called).
Old 12-05-2013, 07:23 PM   #36
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I have the entry level GT86 as well.
I have an Alcon BBK on now but when zi had the stock brakes on I ran Ferodo DS2500 pads front and rear with SS lines and AP Racing 600 fluid. Brakes held up fine on the track performance wise. Very consistent feel, no real pad or fluid fade. The front rotors wore down pretty quick though.
Anyhow, I had to do the same research when trying to find the right pads for my car and I basically found that our cars use WRX brakes front and rear. Rears are unventilated but that doesn't seem to be such a big deal. For me it was the front brakes that took a real pounding.
I've listed the caliper/pad part numbers as well.
Brakes info:
FRONT- Subaru WRX 2008-2011
D929
Pic on my car:
http://db.tt/OxYWXYEr
REAR - Subaru WRX 2008-2011
D1114
Pic on my car:
http://db.tt/Xucf1m8z
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 12-06-2013, 11:15 AM   #37
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
I ended up buying a whole bunch of Endless Stuff. and I'm still Waiting for them to arrive
My final setup will be:
Endless RF650 Brake Fluid (I've been reading good reviews on that stuff)
Endless E-Slit Discs (Front ventilated and solid rear)
Endless SS lines (Swivel Steel Braided Lines)
Carbotech XP12 Brake Pads (Front and rear)
and while I was at it, I bought myself an exhaust and a diffuser (cause it wouldn't be christmas if I didn't get myself something nice... lol)
Looking forward to trying it out on the track.
OnionTou is offline   Reply With Quote
Old 05-14-2014, 02:57 AM   #38
Dihudaxia
Drives: 86
Bro, sorry to dig up an old thread. But i am facing the same 16", smaller, different brake setup here in Singapore.
Was planning to order front and rear brake pads from the US online stores.
From your experience, will the USDM rear brake pads for the larger disc diameter setup fit our smaller disc setup? Looking at Stoptech or Ferodo.
Dihudaxia is offline   Reply With Quote
Old 05-14-2014, 08:12 PM   #39
OnionTou
OnionTou's Avatar
Some people have asked me this a few times over, so no problem.
I have friends who have bought the USDM (upper spec) rear pads without knowing about the difference and installed them in their cars without a hitch.
Old 05-14-2014, 10:47 PM   #40
Dihudaxia
Drives: 86
Thanks mate, much appreciate your feedback
Awesome!
Old 02-24-2016, 09:15 AM   #41
sam69
Drives: GT 86
Bringing this back to life as just did a GT86 with GTS front rotor upgrade.
When doing the swap I happened to measure the caliper pistons on both to find that the base GT runs bigger 43mm pistons than the GTS 40mm.
Why Subaru would do this is beyond me but figured that they should be better than the GTS brakes with the bigger pistons and gts rotors .
sam69 is offline   Reply With Quote
Old 03-16-2016, 01:56 AM   #42
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Not sure if you ever got an answer but I think MRT has it for you:
[ame="https://www.youtube.com/watch?v=7Q9gS4vtCUQ"]Toyota 86 Brake options, GTS vs GT model - YouTube[/ame]
cheers
PWBRZ is offline   Reply With Quote
** PRE-ORDER ** Nur Spec GT86 Aero Kit ** From Carson Toyota Carson Toyota Exterior Parts - The Rest 91 01-20-2016 11:15 PM
UK Spec Toyota GT86 2.0M lordgrover FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 10-18-2012 09:38 AM
First UK Spec GT86 Delivered! Keszki Member's Car Journals 9 07-27-2012 03:51 PM
New Zealand to receive TRD Spec GT86 Priced from $63,486 ($50,841US). CozmoNz Scion FR-S / Toyota 86 GT86 General Forum 31 07-22-2012 10:00 AM
please explain the different lower front lights on US spec BRZ torquemada BRZ First-Gen (2012+) — General Topics 30 12-04-2011 01:18 AM
