Old 12-03-2013, 04:00 AM   #1
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Code P0351 Trouble shooting?
Been getting CEL upon reaching 7800-8000RPM on Stg 2 pump gas map. The code is P0351. I understand that this code is related to coils. However, I tried to identify the faulty coil via logging misfire on cylinders. There was no misfire shown on any!
I thought of taking the car to the dealer to inspect the issue, but I couldn't reproduce the code on stock tune even after driving her hard for half a tank. Everything was smooth and fine.
My next 2 steps in this pursuit are gonna be:
1- Use a higher octane gas (VP MS019) on stage 2 tune to determine if this is related to our crappy 91oct PG
2- Switch back to Stg 1 tune and use pump gas and rev her past 8000rpm and know if it's a tune or a mechanical related issue
My tuner suggested that it's most probably a mechanical issue. But I want to make sure of that before deciding to remove coils or inspect injector seals.
The car is running just fine with a bit of rough idle on STG 2 map, stock tune and stg 1 are both idling very smooth.
I appreciate any feedback and any suggestions
p.s. This is not another tuner-war thread, just a guy with some issues
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 12-03-2013, 10:11 AM   #2
celica73
subscribed
Old 12-03-2013, 10:15 AM   #3
stugray
Drives: 2013 GBS BRZ Limited
Ummm.... How could you possibly attempt to reproduce a problem seen only at "7800-8000RPM " with a stock tune?
Old 12-03-2013, 10:29 AM   #4
andrew20195
Drives: 2013 Subaru BRZ
The last digit of misfire codes identifies the cylinder. In your case, it's coil #1, the passenger side front coil.
The code itself is an electrical fault, most commonly caused by a coil starting to fail. If you had failiing injector seals, you would hear a loud popping, and I believe would be more likely to set a P030x code rather than a P035x code.
Easy way to check is to swap coils #1 and #3, and if the code goes away or moves to #3, it's a faulty coil.
andrew20195 is offline   Reply With Quote
Old 12-03-2013, 11:05 AM   #5
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Thanks... I guess I'll do so
Old 12-03-2013, 11:06 AM   #6
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
I thought with hard driving I might succeed
Old 12-03-2013, 11:32 AM   #7
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I was getting this as well. For me it happens when doing 0-125mph pulls. I had it happen on the stage 2 tune and the stock tune. They just replaced it under warranty.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-03-2013, 01:53 PM   #8
stugray
It is just that you cannot GET to 7800-8000 RPM with the stock tune.
You will be bumping against the rev limiter @ ~7400
Old 12-03-2013, 09:24 PM   #9
s2d4
s2d4's Avatar
Coils have their ratings, once you go beyond that they could be damaged. To make it work at load levels not seen at stock or bypass issues with even more aggressive ignition will do it too.
Otherwise there would be no need for aftermarket coils to support higher engine load/power levels.
Old 12-03-2013, 10:01 PM   #10
s2d4
s2d4's Avatar
Originally Posted by xomp View Post
Other makes and models don't have these problems even when heavily modified (boosted, high RPM, whatever). OEM coil packs/COPs are usually recommended over aftermarket ignitions for reliability.
At least for my case, an ignition coil should not fail after 3000 miles of revving a stock engine to redline. It's just another cheap, low duty part on this car.
Well, for his case, if the redline is 600 rpm higher, that would mean that at the highest load, also requiring the highest amp draw would need to fire 10 times more per second?
Yes, you could be right.
Old 12-04-2013, 05:42 AM   #11
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
So, I started the trouble shooting last night. CEL came back on stg 2 with Race gas, this meant that it wasn't a fuel related issue.
However, a dramatic change to the scenario occurred when I started hearing BACKFIRE in the engine bay during part throttle tapping under load. It was loud and scary! It came on all maps (STG 1, 2 and stock). It's a clear indication (IMO) of injector seal failure. It did not pull a CEL tho.
Car taken to the dealer's for further inspection
Old 12-04-2013, 10:18 AM   #12
andrew20195
Let us know what they find.
Old 12-05-2013, 12:17 AM   #13
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
So far, they confirmed that it's an injector seal issue. They had a similar issue with another car from my production batch.
Old 12-05-2013, 02:29 AM   #14
s2d4
s2d4's Avatar
Did they tell you why the injector seal failed?
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
U0115 OBD trouble code vtmike Issues | Warranty | Recalls / TSB 4 08-31-2013 01:24 PM
First Time Out Shooting Forgetful FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 07-23-2013 11:12 AM
86 shooting brake Freeman Scion FR-S / Toyota 86 GT86 General Forum 44 12-07-2012 08:27 PM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 01:04 PM
