Old 12-03-2013, 09:29 PM   #183
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by sw20kosh View Post
Uh is that anything like a NPT?
Also, how did you guys seal those intercooler nipples that were leaking? DId you use any glue or anything? Bill @DeliciousTuning is saying that I should check the rubber O-ring seals and glue them in.
Are you referring to the grey L connectors at the back?
We pulled out and applied Teflon tape and screwed them back supper tight. We used red rubber grease on the nipples when applying the pipes back on to prevent leaks.
The other point the Technician pointed out, is do not use any gasket sealer on the kit as it comes with rubber seals on all necessary parts. The idiot mechanic who installed first time used gasket sealer and we could notice it creates areas where the charger would eventually leak.
Bill is the one who told me exactly what was wrong with my kit and how to seal. He know this kit so well what ever advise he gives is worth taking.
Ryan86 is offline   Reply With Quote
Old 12-03-2013, 09:46 PM   #184
xxscaxx
Drives: 2013 SWP BRZ
He is referring to the connectors for the intercooler connection, not the grey fittings in the back of the charger.
It might just be me, but my car seems to run smoother now that i've replaced those fittings and used teflon on them.
xxscaxx is offline   Reply With Quote
Old 12-03-2013, 09:53 PM   #185
sw20kosh
Drives: 2013 Black FR-S
no. im referring to the coolant nipples on the intercooler.
Old 12-03-2013, 10:00 PM   #186
Ryan86
Road Warrior
Ryan86's Avatar
I did not see any nipples when we took apart, maybe your term nipple and mine are different.
You get the two connectors which fit into each end of the cooler, these have 3 O rings to seal the coolant and the boost? This is where I had a leak, the last O ring was left off by the technician, so my air was flowing freely.
We just applied small amount of red rubber grease and the two pipes went in and sealed perfect.
If the above is not it, put a pic up.
Old 12-04-2013, 01:28 AM   #187
sw20kosh
You get the two connectors which fit into each end of the cooler, these have 3 O rings to seal the coolant and the boost? This is where I had a leak, the las to rings where left off by the technician, so my air was flowing freely.
Yes those are the ones. I will have to find red rubber grease...Did you put the red rubber on the O-rings or on the pipes or both?
Also, did you get those dyno charts where you made ~250 whp? Would love to see those!
Old 12-04-2013, 03:26 AM   #188
Ryan86
Road Warrior
Ryan86's Avatar
Fit the O rings, then apply small amount of red rubber grease around the 3 O rings to create a better seal when you fit. You will feel them nice an snug if you try Pull them back slowly.
I personally would not put any glue or sealant in there, as this could cause blockage if any had to come loose.
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! Xero-Limit Forced Induction 12 03-10-2014 08:56 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 01:06 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 10:13 AM
