Old 10-03-2013, 11:35 PM   #29
FR-Sizzle
Drives: brz
Originally Posted by jflogerzi View Post
Skip the intake. Here is what I would do in this order:
Tune
Header
Exhaust(sound purposes only)
Everything else can stay stock. The front and overpipe won't get you much.
Some vendors have said most of the gains are had at the front/overpipe. Just look at the Nameless Axle Back and Front/Over pipe combo. They said the mid pipe didnt get any gains when they did their R&D. I dont think it would be any different for any other systems. If I just bought my car I would do it in this order
Tune
Front/Over Pipe
Nameless Axle Back
Header
Perrin Silicone Tube/CAI or Drop In Filter/Perrin Silicone Tube/HKS Intake Duct
Mid Pipe for peace of mind and just to complete the whole system
FR-Sizzle is offline   Reply With Quote
Old 12-03-2013, 07:39 AM   #30
cslntuee
Drives: Subaru BRZ Limited
Tune
Front/Over Pipe
Nameless Axle Back
Header
I thought(or heard) the major gain is from header, isn't it?
Thanks.
cslntuee is offline   Reply With Quote
Old 12-03-2013, 08:01 AM   #31
FR-S Matt
Tune + Header -> Overpipe + Front pipe > Drop-in/CAI > (Pick your flavor of catback). That's the best N/A performance and the order it goes in but they all work together even better when they are tuned together.
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
Anthony (12-03-2013), cslntuee (12-03-2013)
Old 12-03-2013, 10:07 AM   #32
jonbonazza
As a side note, in order to install the overpipe, you will need to drop the header, so you might as well grab one of those while you are at it. You should at LEAST grab a new header gasket.
jonbonazza is offline   Reply With Quote
Old 12-03-2013, 10:35 AM   #33
Foobar
SLO NO MO
Foobar's Avatar
I installed my Perrin OP without dropping the header or lifting the engine. I did have to remove the stock head shields first though. Then it was a simple matter of snaking the stock OP through and the aftermarket one back in.
Old 12-03-2013, 12:16 PM   #34
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I didn't touch the header either. First I loosened the front pipe by dropping it off that bracket that's towards the rear of the front pipe. Then I took the shielding off the factory over pipe, completed the puzzle of getting it out, and puzzled the new one back in. No clearance issues or rattling. And I have USED Borla headers. People talk so much shit about them, but I've had zero problems in the 300 miles or so I've driven with them. PLM over pipe is doing just fine too. No CELs. Haven't even flashed with my OpenFlash Tablet yet.
Oh and the PLM over pipe came with two nice gaskets, so didn't have to reuse any of the oldness.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 12-03-2013, 12:39 PM   #35
jamesm
if power is the primary concern i would just buy the largest diameter exhaust you can and plan to go FI in the future. you're pissin' in the wind trying to make real power NA.
if you don't plan on going FI then which brand of exhaust you buy, which components etc will have little impact on performance, good or bad. the gains to be had are within the margin of error. we're talking single-digit HP gains here, maybe teens with a tune.
as always the amount of power you make, and how consistently you make it, has more to do with your tune than anything else.
i'll note that i saw only minor gains with my turbo setup replacing the exhaust until the final piece was in place, then it was night and day. the whole thing had to be upgraded before the gains were even noticeable.
Old 12-03-2013, 12:48 PM   #36
bfrank1972
Drives: 2013 FR-S Argento
^ this, FI or E85 + tune makes the biggest difference, header helps with the dip and maybe a little on the curve but best bang for the buck aside from FI is E85 + a good tune if you have E85 conveniently vailable to you.
Old 12-03-2013, 12:53 PM   #37
OrbitalEllipses
Drives: Attitude
I TRIED to remove the heatshield, but the last bolt was heavily rusted AND hard to reach. Gave up and raised the engine and the OP just dropped out.
Old 12-03-2013, 01:57 PM   #38
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Originally Posted by m.wood0213 View Post
Its a good idea and common plan but then you have to deal w/ the repercussions of the CEL.
It is fairly simple to manage CEL with no tune. $20 o2 spacer from Ft86speedfactory.com , a $5 app on iPhone or $15-$20 torque app on android, $25-30 on one of those Bluetooth receiver things that plug into your car so you can clear codes.
CodyFRS is offline   Reply With Quote
Old 12-03-2013, 05:00 PM   #39
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Yes but the power comes mostly from the tune....
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
Old 12-03-2013, 05:24 PM   #40
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
For your health.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
Old 12-03-2013, 05:33 PM   #41
charged86
charged86's Avatar
yes buy over pipe plus catless midpipe and get a tune asap and only a panel filter
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 12-03-2013, 05:51 PM   #42
ramiram1984
Drives: 2016 STi DGM
And the sound will be little more aggressive with OP installed as opposed to stock.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Sway Bars..Do they really make a difference for a DD? jmkv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 08-26-2013 02:54 PM
Tires Make a Big Difference poudre Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-16-2012 10:58 PM
Little details . . . make a difference avusblue Cosmetic Modification (Interior/Exterior/Lighting) 27 08-10-2012 08:53 AM
Do intake systems really make a difference? Echo Engine, Exhaust, Transmission 36 07-26-2012 07:09 PM
Little details . . . make a difference avusblue Scion FR-S / Toyota 86 GT86 General Forum 1 07-21-2012 12:00 PM
