Old 10-01-2013, 09:21 PM   #1
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Does the overpipe really make a difference?
I'm looking at getting the Perrin exhaust system and I'm weighing up whether to get it with the over pipe, or to just get the catted front pipe and the cat back components.
My question is, does the overpipe really do anything? Perrin quotes a 3rwhp gain but that's pretty negligible on a dyno and wouldn't even be noticed when driving. How does it increase flow being such a small part of the system?
Does anyone have any experience comparing these two setups?
Wise is offline   Reply With Quote
Old 10-01-2013, 09:24 PM   #2
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
the stock one is 2.16" and has some bumps and dents in it. its probably the biggest restriction in the exhaust system as far as piping goes. the overpipe is definitely worth it! there are a few threads about it already just do a search.
FreshFRS is offline   Reply With Quote
Old 10-01-2013, 09:43 PM   #3
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
absolutely... nameless has an incredible op?downpipe combo piece that I am strongly considering. What it does is combine the two exhaust pieces together and reduce some of the arc or degress that the op into the downpipe with otherwise create stock.. this improves flow and increases power.
the op is so damn close to the headers.. improving this piece will absolutely create power power than say changing your muffler or midpipe.
Boofneenee is offline   Reply With Quote
Old 10-01-2013, 09:54 PM   #4
avp1
Drives: Traded BRZ for Supra
It won't add you even 2 hp. Not worth to spend money on snake oil. If you want to mod exhaust, you have to go with high flow cat or just straight pipe. Though it wont be streat legal in most states.
avp1 is offline   Reply With Quote
The Following User Says Thank You to avp1 For This Useful Post:
Aaronimoe (01-10-2017)
Old 10-01-2013, 10:06 PM   #5
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
Im in the same boat. I PM'd Nameless and they said it will make a difference but when i PM'd FA20Club about theirs they said no not really, don't worry about it until you do headers. Im currently waiting on JDL to see what they say about it.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 10-01-2013, 10:30 PM   #6
Wise
Circle Work Clerk
Haha thanks for the responses guys. Seems like opinions are divided here.
I wasn't planning on doing headers for awhile. My initial plan was just to do Header back + intake + tune.
Old 10-01-2013, 11:01 PM   #7
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
dood,
i am not sure what you have on your car or what your planning to purchase 1st but its a waste of your efforts, money and time to just get an OP alone
either do a header/OP combo or the nameless OP/downpipe combo and headers later. this will get you a bang for your buck.. if you do just the headers alone (no OP) your still going to get nice gains but your choking the flow with a stock OP
while the OP is a crucial part of the exhaust system.. being so close to the engine and an intriquite piece.. it accounts for like 8% of the length of the entire exhaust piece and is nothing more than a single flow pipe.
Old 10-01-2013, 11:13 PM   #8
jflogerzi
jflogerzi's Avatar
Skip the intake. Here is what I would do in this order:
Tune
Header
Exhaust(sound purposes only)
Everything else can stay stock. The front and overpipe won't get you much.
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
KalbiCool88 (08-27-2017), kuhlka (12-03-2013), Roneezy (05-10-2016)
Old 10-01-2013, 11:36 PM   #9
Wise
Circle Work Clerk
Tune
Header
I've already got a Takeda Intake installed on the car.
So do you think Perrin Cat Back + Borla UEL headers would be a better option than just Perrin Header Back?
I want to keep at least one of the cats in the car and not be too loud. I was thinking of getting the resonated catback.
Old 10-01-2013, 11:42 PM   #10
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Its a good idea and common plan but then you have to deal w/ the repercussions of the CEL.
My BRZ
Old 10-01-2013, 11:45 PM   #11
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Start on the engine side of your exhaust and work backwards. Muffler is mostly for sound change but doing headers and/or OP/FP will change your sound anyway.
Plus a tune to maximize benefits and fix torque dip/cel if you can.
EvilBeaverFace is offline   Reply With Quote
The Following 2 Users Say Thank You to EvilBeaverFace For This Useful Post:
Anthony (10-02-2013), StormTrooper (12-03-2013)
Old 10-01-2013, 11:56 PM   #12
Wise
Circle Work Clerk
Is the cel a prevalent issue with changing the headers or is it only isolated cases?
Old 10-02-2013, 12:17 AM   #13
jflogerzi
jflogerzi's Avatar
Get the revworks. Better quality. I would get the tune first before you get the header. Tune is what will unlock the most from any header. Also it will help and disable the CEL from removing the cat in the header where the main O2 senzors are. Keep the stock front pipe with the cat.
Old 10-02-2013, 12:17 AM   #14
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Yes. Headers first. Then over pipe. Then front pipe. Then catback.
The ideal thing would be to do it all at once and tune right then. That way you're not driving around with all this without a tune, or trying to tune your stock car before you get all this stuff.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
EvilBeaverFace (10-02-2013)
Sway Bars..Do they really make a difference for a DD? jmkv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 08-26-2013 02:54 PM
Tires Make a Big Difference poudre Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-16-2012 10:58 PM
Little details . . . make a difference avusblue Cosmetic Modification (Interior/Exterior/Lighting) 27 08-10-2012 08:53 AM
Do intake systems really make a difference? Echo Engine, Exhaust, Transmission 36 07-26-2012 07:09 PM
Little details . . . make a difference avusblue Scion FR-S / Toyota 86 GT86 General Forum 1 07-21-2012 12:00 PM
