Old 12-01-2013, 03:10 AM   #631
akyp
Drives: 2012 86
Originally Posted by BRZmeMR2 View Post
Do you have any tunes on this tablet that work with 98ron european fuel?
Here we also have 98 RON fuel and my car is running great on the stage 1 93 oct tune.
akyp is offline   Reply With Quote
Old 12-01-2013, 07:43 AM   #632
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Basicly 98Ron is us 93 (r/m)2 or AKI.
95ron would be equivalent to 91AKI
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 12-01-2013, 10:09 AM   #633
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
I was a little in doubt because cirquit motorsports said when they tuned on 93us and 98eu they found 98eu was a little better than 93us and could get a little more gains out of it :-)
GT86meMR2 is offline   Reply With Quote
Old 12-01-2013, 10:30 AM   #634
StormTrooper
I imagine that depends on atmospheric conditions or additives than the actual octane rating...
Maybe one car liked the tune or mods better. Noticed that with my wrx and my friends. Same yr same fuel same conditions same mods same tuner I made almost 15 more HP...
Just examples. Could be slight difference in fuel
GR86 MT premium
Old 12-01-2013, 11:09 AM   #635
Victor Draken
Drives: Toyota Gt86
We have 100 Ron as well in europe. Very easy to find around.
Victor Draken is offline   Reply With Quote
Old 12-01-2013, 01:58 PM   #636
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Malt View Post
You'll have to excuse my ignorance on the subject but is there anywhere I can read up on what to change and by how much to resolve this issue?
Our do you have any tips on where to start at?
I just left the house an hour ago and had to attempt to crank three times before I got it started and it's only 45 degrees out atm. If I can't get this resolved I'm just going to put the BRZ in the garage and drive my other car on days I have to work because I can't risk not being able to start the car in the morning when it's time to goto work.
You will need to use romraider for now, or wait till shiv updates the xdf to include the 3d cranking pulse width tables.
Start by setting the Cranking RPM table back to all 0.00 then multiply all the of 68*F (20*C) columns by 1.2, all of the 50*f columns by 1.25, and all of the columns from -40*f to 32*f by 1.3. Then you can just tweak the cranking table as needed. I was a little more aggressive with my rom..
In atlanta all i needed was the cranking rpm table setup as shiv has it in the base rom, but here in socal it was not sufficient to crank on the first try. Td-d was kind enough to find these 3d tables for me and they work great. It seems there is a limit to the amount of enrichment the rpm based table will provide.
The Following 8 Users Say Thank You to mad_sb For This Useful Post:
DAEMANO (12-02-2013), elopez (12-02-2013), jamesm (12-01-2013), Malt (12-01-2013), Rombinhood@OpenFlash (12-01-2013), s2d4 (12-01-2013), unsurety (06-14-2014), WRB5titch (12-02-2013)
Old 12-02-2013, 02:07 PM   #637
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
I'll be receiving my OFT this week (and header in January!)
Working on a three phase performance improvement
Base (already installed) - K&N filter, Nameless Combo pipe, Nvidia Q300 Exhaust
1 - Add OFT (this week) - Stage 1 tune
2 - Change to E85 (next week) - Stage 2 E85 tune
3 - Add OFT Header (January) - Stage 2 E85 Header tune
And somewhere in there I will modify my intake inlet
While doing this, I'm looking for what parameters I need to keep an eye on to make sure I'm within acceptable ranges and tolerances given the off-the-shelf tunes. I've read most of the threads and watched Shiv's videos but I'm looking for the primer for dummies on what parameters should be within what ranges.
Parameter X should be between y - z, etc..
If this was already posted somewhere that I can't locate, a link would be much appreciated.
Thanks in advance!
nlowell is offline   Reply With Quote
The Following User Says Thank You to nlowell For This Useful Post:
Rombinhood@OpenFlash (12-02-2013)
Old 12-02-2013, 02:22 PM   #638
Drives: FRS
Thanks in advance!
Shiv and the guys at Vishnu can't post here for a week so will be trying to bridge the communication gap during this time. Just getting caught up with things right now. Working on more sound clips or the OpenFlash Header as well as a video tutorial for Romraider. I'll also be posting up about a special OpenFlash Tablet holiday sale for all users who currently have non-user programmable flash tunes
Rombinhood@OpenFlash is offline   Reply With Quote
The Following 5 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post:
DAEMANO (12-02-2013), jamesm (12-02-2013), nlowell (12-02-2013), PoorMansRacing (12-18-2013), ReThink (12-04-2013)
Old 12-02-2013, 06:10 PM   #639
StormTrooper
The site has no information on order status.... I ordered the day before Thanksgiving.
GR86 MT premium
Old 12-02-2013, 06:29 PM   #640
Drives: FRS
Just call or email them and they can give you a tracking number/order status. Their offices were closed on Thursday and Friday for the holidays so I believe today they are catching up on all orders since then
Old 12-02-2013, 09:03 PM   #641
StormTrooper
Just got tracking info lol....
GR86 MT premium
Old 12-02-2013, 10:57 PM   #642
cnk
Drives: '13 DGM BRZ Limited
Just a head's up for folks that don't check the OFT website. ROMRaider tuning software and definition files are now posted so you can use ROMRaider to edit maps now if you want.
The Following User Says Thank You to cnk For This Useful Post:
Old 12-02-2013, 11:01 PM   #643
Drives: FRS
Yes, Shiv just put those up a few minutes ago. But he suggests hanging tight until the tutorial video is done and posted up. Most likely tomorrow. There are some important bits of info to know with regards to some of the XML files. Consider this for experimental use only for the time being
The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post:
cnk (12-02-2013)
Old 12-02-2013, 11:06 PM   #644
Tromatic
Ordered mine. Had to call after a paypal SNAFU, got my confirmation about 15 minutes later!
The Following User Says Thank You to Tromatic For This Useful Post:
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
