#631 |
Drives: 2012 86
#632 |
Drives: Pavement MT GR86
Basicly 98Ron is us 93 (r/m)2 or AKI.
95ron would be equivalent to 91AKI
GR86 MT premium
#633 |
Drives: MR Spyder/GT86
#634 |
I imagine that depends on atmospheric conditions or additives than the actual octane rating...
Maybe one car liked the tune or mods better. Noticed that with my wrx and my friends. Same yr same fuel same conditions same mods same tuner I made almost 15 more HP... Just examples. Could be slight difference in fuel
GR86 MT premium
#635 |
Drives: Toyota Gt86
We have 100 Ron as well in europe. Very easy to find around.
#636 | |
Drives: 2013 Asphalt FR-S
Start by setting the Cranking RPM table back to all 0.00 then multiply all the of 68*F (20*C) columns by 1.2, all of the 50*f columns by 1.25, and all of the columns from -40*f to 32*f by 1.3. Then you can just tweak the cranking table as needed. I was a little more aggressive with my rom.. In atlanta all i needed was the cranking rpm table setup as shiv has it in the base rom, but here in socal it was not sufficient to crank on the first try. Td-d was kind enough to find these 3d tables for me and they work great. It seems there is a limit to the amount of enrichment the rpm based table will provide.
~Namaste~ |
#637 |
Drives: 2013 Scion FRS
I'll be receiving my OFT this week (and header in January!)
Working on a three phase performance improvement Base (already installed) - K&N filter, Nameless Combo pipe, Nvidia Q300 Exhaust 1 - Add OFT (this week) - Stage 1 tune 2 - Change to E85 (next week) - Stage 2 E85 tune 3 - Add OFT Header (January) - Stage 2 E85 Header tune And somewhere in there I will modify my intake inlet While doing this, I'm looking for what parameters I need to keep an eye on to make sure I'm within acceptable ranges and tolerances given the off-the-shelf tunes. I've read most of the threads and watched Shiv's videos but I'm looking for the primer for dummies on what parameters should be within what ranges. Parameter X should be between y - z, etc.. If this was already posted somewhere that I can't locate, a link would be much appreciated. Thanks in advance!
| The Following User Says Thank You to nlowell For This Useful Post: | Rombinhood@OpenFlash (12-02-2013) |
#638 | |
Drives: FRS
| The Following 5 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post: | DAEMANO (12-02-2013), jamesm (12-02-2013), nlowell (12-02-2013), PoorMansRacing (12-18-2013), ReThink (12-04-2013) |
#639 |
The site has no information on order status.... I ordered the day before Thanksgiving.
GR86 MT premium
#640 | |
Drives: FRS
#642 |
Drives: '13 DGM BRZ Limited
Just a head's up for folks that don't check the OFT website. ROMRaider tuning software and definition files are now posted so you can use ROMRaider to edit maps now if you want.
| The Following User Says Thank You to cnk For This Useful Post: | ReThink (12-04-2013) |
#643 | |
Drives: FRS
| The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post: | cnk (12-02-2013) |
#644 |
Ordered mine. Had to call after a paypal SNAFU, got my confirmation about 15 minutes later!
| The Following User Says Thank You to Tromatic For This Useful Post: | Rombinhood@OpenFlash (12-02-2013) |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
