Old 02-17-2012, 05:17 PM   #15
delongedoug
Drives: 2.5 RS daily, Evo 8 track
Location: A little town called none of your goddamn business
Any sort of roll bar = no more rear passengers. Period. Also, you're not going to want to be installing and uninstalling it, especially with no rear doors to get access. It's good that you can remove it at some point in the future as opposed to a weld in, but with a roll bar, your car's essentially track dedicated and you won't want to drive it anymore. Especially since you'll probably be running harnesses and racing seats. Ask me how I know.
delongedoug is offline   Reply With Quote
The Following User Says Thank You to delongedoug For This Useful Post:
housecat (04-17-2014)
Old 02-17-2012, 05:20 PM   #16
coyote
coyote's Avatar
Drives: Slowly
Firstly, I don't think there's a lot of point in caging a car unless you strip it back to nothing and weld in a proper cage and further think that once you are considering a weld in cage, you should also be considering a dedicated race car.
However, the bolts that hold a joining tube are not there to provide strength in an impact. It is the overlap of the two tubes that provides the strength. The bolts just hold the tubes in place, but aren't even needed once impact forces are applied.
coyote is offline   Reply With Quote
Old 02-17-2012, 05:25 PM   #17
oneday
Opinionated
oneday's Avatar
Drives: Something Red
Originally Posted by 7thgear View Post
i have been participating in motorsports for over 6 years and am still driving stock (see sig), however there are times when i think about my safety a little too much and start thinking of something along the lines of a roll bar...
If you are considering your safety, and thinking "rollbar" you should be thinking "complete safety package." By that I mean: SFI/FIA seat, SFI/FIA harness, head and neck restraint _AND_ a roll bar.
No one piece of that is much good without the rest.
A roll bar in a four-seater means you now have a two-seater. And, if you put a roll bar in your now-a-two-seater, you need to have equal safety gear for the passenger...so that "complete safety package" now requires two SFI/FIA seats, and two SFI/FIA harnesses.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Old 02-17-2012, 05:44 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
As usual I agree 100% with the above.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-17-2012, 06:52 PM   #19
delongedoug
I'm greatly anticipating the car to come out. Not because I'm going to buy one right away, but so we can finally get a dedicated motorsport subforum on here.
In general I agree, but not everyone is wheel to wheel racing in sanctioned events and is going to shell out a few grand for a rulebook spec weld in cage. With the speeds I hit and experiencing my first high-speed spin/off, I just wanted more safety on the track. Like everything, it's all a compromise.
I'd only say that a roll bar is fine without the rest.
Old 02-17-2012, 07:12 PM   #20
old greg
Rocket Surgeon
Drives: PSM GGA OMG
SFI padding isn't designed to stop a cracked skull...it's intended to prevent cracking a helmet.
Yes, which is why I wrote and instead of or.
old greg is offline   Reply With Quote
Old 02-17-2012, 08:56 PM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Your statement sounded like the sfi padding made it safe.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-17-2012, 08:58 PM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd disagree. I'm on my iPad do I don't feel like typing it in detail again but collapsible seats and 3 point harnesses really shouldn't be used with a rollbar.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-17-2012, 09:27 PM   #23
old greg
Rocket Surgeon
Drives: PSM GGA OMG
That was not my intention.
Old 02-17-2012, 10:05 PM   #24
oneday
Opinionated
oneday's Avatar
And if you tested that theory of yours you'd find out how very wrong you are....but you'd probably be dead or a vegetable so it wouldn't matter to you.
Old 02-18-2012, 03:07 AM   #25
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
That may be true, but there are cars that come with harnesses that do not have roll bars (or perhaps it is built into the actual chassis, so there is no apparent roll bar), and there are cars with factory roll bars that does not come with harnesses.
CyberFormula is offline   Reply With Quote
Old 02-18-2012, 06:32 AM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
Marginally more safety at the track (debatable) plus less safety on the street (no helmet) for front-seaters and enormously greater risk for rear-seaters (enough more that rear seat removal is warranted) is what you're considering. This car is going to provide a fair amount of rollover protection without a roll bar. My advice: forget about installing a roll bar.
Old 02-18-2012, 10:44 AM   #27
delongedoug
Why would you need a helmet on the street with a 4 point rollbar? Also, I already stated that rear passengers are non-existant with a rollbar. It's not something I'm considering, it's in my garage right now.
Old 02-18-2012, 11:19 AM   #28
ZDan
ZDan's Avatar
Drives: '23 BRZ
I didn't say "you need a helmet on the street with a 4 point rollbar", I said "less safety on the street". I.e., any tiny reduction in risk due to marginally greater rollover protection is likely offset by the (probably) less tiny risk of whacking the rollbar with your head in a greater number of types of accidents, including many more likely than rollovers.
FWIW, my Z, RX-7, and S2000 street cars all have 4-point roll bars. In the Z (minimal rollover protection stock) and the S2000 (convertible), they *might* be all-around safer street cars with the bars. For the RX-7, probably not, but required for its classification for track days ("prepared"). Otherwise I might remove it.
Anyway, I'm not jumping in and saying you MUST remove roll bars from street cars. I *am* recommending against installing a 4-point bar in a street car that already gives reasonable rollover protection. Costs time/money/effort and in all likelihood you'll be a smidge *less* safe for most of your usage.
NW Prospective Owners Roll Call WingsofWar Northwest 125 08-27-2012 01:48 AM
FT86 roll out video OFFICIAL Godzilla35 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 11-27-2011 03:02 AM
Proper Roll Cage CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 1 04-12-2010 04:51 PM
Ae86 roll cage in initial d? CyberFormula Off-Topic Lounge [WARNING: NO POLITICS] 8 03-14-2010 12:23 AM
