#127 | |
StatusLow
Drives: 2013 10 Series FRS
#128 |
Glorious BRZ Master Race
Drives: Subaru Libird
Ok, well I removed every bolt along the LCA from the knuckle on back up to that last far inside bolt (which I just loosened), retorqued everything back to spec, then got an alignment. But next time I'll try loosening the sway bar bolt (unless you're referring to the endlink bolt on the LCA which I did loosen?).
#130 |
Senior Addict
Drives: 86 GT
Hey guys, I was installing eibach springs on a friend's 86 today, and was kinda in a rush and I think I might have accidentally installed the front bump stops upside down? I did it with the words (which are embossed on the bump stops) right way up. So whats the correct orientation for the bump stops?
What kind of damage would happen if I left it this way? |
#131 |
Drives: GT86
Hi
I have just installed my sportline springs yesterday and I have just noticed that the rear passenger is a little lower than the rear driver side. Does anyone already had this issue? I checked twice all the installation and I find nothing wrong. Need some advice from you |
#132 | |
Senior Addict
Drives: 86 GT
You can easily check this prior to removing your rear shocks by looking closely through the hole where you'd insert the socket to remove top nut. |
#133 |
Here's my method to torque the top nut to the 41 ft-lb spec. Used a crow's foot socket on my torque wrench (easiest to position at 90 degrees according to http://www.motorcraftservice.com/ren...la_main_en.asp) which torqued the pass-through socket (pass-through extension as pictured may be needed for rear), and extra long hex bit to hold the rod. All tools were *in stock* at Harbor Freight for reasonably cheap.
Tagging @DarrenDriven in case this might be useful for others to see in the OP.
#135 |
Drives: GT86 DGM
I think #27 should be altered with a warning NOT to use an impact gun on the top nut. The guide specifically suggest using one, but threads around here indicate that this may likely blow your damper seals, as I did. I didn't read through this thread before doing the install, but followed the guide.
#136 |
Drives: 2014 Subaru BRZ Limited 6MT
Big tip for getting off the ABS connectors, the one in this picture can be removed from the plastic, by pushing in the big tab with a screwdriver (not where the arrow is pointing, but on the opposite side), and it will just release the wire. Makes removal WAY easier. I didn't have any issues with removing the lower connector with a flat-tip screw driver.
| The Following 2 Users Say Thank You to flashburn For This Useful Post: | amram (04-09-2014), DarrenDriven (12-08-2014) |
#137 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
#138 |
I used whatever sockets fit the front strut top nut and rear strut top nut. The socket on the bottom is attached to a 3/8" drive extension so any socket (14mm or 17mm) w/ 3/8" drive will fit. I had a set of crow feet and the 19mm crow foot happened to fit the top of the extension so I used it. All these tools were available at Harbor Freight.
#139 |
I'm about to do a Hotchkis spring installation and in their instructions they talk about resetting preload for the control arms. I tried searching on the DIY forum and haven't found anyone talk about this adjustment. I'm guessing this is why OP isn't hitting the advertised 1" drop.
Here's Hotchkis' installation PDF and you can find this on page 30. https://www.hotchkis.net/_uploaded_f...ns5218file.pdf can anyone elaborate on this? maybe as far as why people are not resetting the preload? also any alternative way to do this outside of how Hotchkis is prescribing? I don't have an alignment rack or 4 floor ramps to drive the car onto evenly. thanks all! |
#140 |
Drives: scion frs
so after doing my eibach sportline install, everytime i would drive and turn the wheel to the right it would make a horrible grinding/squeaking noise.
what would cause this to happen after installation? the car is only a year old. |
| Replacing the Scion FR-S seats | bloomy116 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 11-09-2012 12:41 PM |
| Installing TRD Parts / Locating a good shop | Re~Mix | Engine, Exhaust, Transmission | 9 | 06-12-2012 12:05 PM |
| T1R Coil-over suspension | AJ PwR | Brakes, Suspension, Chassis | 33 | 05-29-2012 10:07 PM |
| Handling: Camber Attainable with Struts. Your Experiences? | skeeler | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-09-2011 04:07 PM |
